Skip Navigation Links
Exit Print View
Sun Server X3-2 (formerly Sun Fire X4170 M3)
Product Notes, Version 1.2.1
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Support and Accessibility
Sun Server X3-2 Product Notes
Sun Server X3-2 Name Change
Supported Hardware
Supported Firmware Versions
Supported Operating Systems
Important Operating Notes
Operational Changes for UEFI BIOS Configuration
Single-Processor to Dual-Processor Upgrade Is Not Supported
Update Your System to the Latest Software Release
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Supported Operating System Limitations
Update HBA Firmware to Support UEFI BIOS
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Failure of a Single Server Fan Module Might Impact Performance
Standby Over-temperature Protection
MAC Address Mapping to Ethernet Ports
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing
Battery Module
Server Management Tools
Supported PCIe Cards
Resolved Issues
Resolved Issue for This Software Release
Resolved Issues for Previous Software Releases
Known Issues
Hardware Known Issues
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Oracle System Assistant Known Issues
Documentation Known Issues
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Table 6 Resolved Issue for This Software Release
BugDB
Description
15812479 (formerly CR 7194345)
In single-processor systems, fmtopo output is incorrect.
Issue:
In single-processor systems, /usr/lib/fm/fmd/fmtopo enumerates PCIe devices incorrectly. /usr/sbin/prtdiag and /usr/sbin/smbios report inaccurate status information for PCIe slot 1, which is nonfunctional in single-processor systems.
Affected software:
  • Oracle Solaris 10 8/11 and 11 11/11
  • Releases 1.1, 1.1.1, and 1.2
Fixed in:
  • Release 1.2.1
