Skip Navigation Links
Exit Print View
Sun Server X3-2 (formerly Sun fire X4170 M3)
Security Guide
search filter icon
search icon
Document Information
Sun Server X3-2 Security Guide
Basic Security
Using Server Configuration and Management Tools Securely
Planning a Secure Environment
Maintaining a Secure Environment
After the initial installation and configuration, use Oracle hardware and software security features to continue controlling hardware and tracking system assets.
Contact your IT Security Officer for additional security requirements that pertain to your system and specific environment.
Power Control
You can use software to turn power on and off to some Oracle systems. The power distribution units (PDUs) for some system cabinets can be enabled and disabled remotely. Authorization for these commands is typically set up during system configuration and is usually limited to system administrators and service personnel.
Refer to your system or cabinet documentation for further information.
Asset Tracking
Use serial numbers to track inventory. Oracle embeds serial numbers in firmware on option cards and system motherboards. You can read these serial numbers through local area network (LAN) connections.
You can also use wireless radio frequency identification (RFID) readers to further simplify asset tracking. An Oracle white paper, How to Track Your Oracle Sun System Assets by Using RFID, is available at:
http://www.oracle.com/technetwork/articles/systems-hardware-architecture/o11-001-rfid-oracle-214567.pdf
Updates for Software and Firmware
Security enhancements are introduced through new software releases and patches. Effective proactive patch management is a critical part of system security. For best security practices, update your system with the more recent software release, and all necessary security patches.
Network Security
After the networks are configured based on security principles, regular review and maintenance are needed. Follow these guidelines to secure local and remote access to your systems.
For more information about network security, refer to the Oracle ILOM Security Guide, which is part of the Oracle ILOM documentation library. You can find the Oracle ILOM documentation at:
http://www.oracle.com/goto/ILOM/docs
Data Protection and Security
Follow these guidelines to maximize data protection and security.
Log Maintenance
Inspect and maintain your log files on a regular schedule. Use these methods to secure log files:
