Skip Navigation Links
Exit Print View
Sun ZFS Storage 7000 System Administration Guide
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Status
3.  Configuration
4.  Services
5.  Shares
6.  Analytics
Analytics
Introduction
Concepts
Analytics
Drilldown Analysis
Statistics
Datasets
Actions
Worksheets
Statistics
Introduction
Descriptions
Analytics
Advanced Analytics
Default Statistics
Tasks
Statistics Tasks
CPU Percent utilization
CPU: Percent Utilization
Example
When to check
Breakdowns
Further Analysis
Details
Cache ARC accesses
Cache: ARC accesses
When to check
Breakdowns
Details
Metadata
Prefetch
Further Analysis
Cache L2ARC IO bytes
Cache: L2ARC I/O bytes
When to check
Breakdowns
Further Analysis
Cache L2ARC accesses
Cache: L2ARC accesses
When to check
Breakdowns
Further Analysis
Data Movement NDMP bytes transferred tofrom disk
Data Movement: NDMP bytes transferred to/from disk
When to check
Breakdowns
Further Analysis
Data Movement NDMP bytes transferred tofrom tape
Data Movement: NDMP bytes transferred to/from tape
When to check
Breakdowns
Further Analysis
Data Movement Shadow migration bytes
Data Movement: Shadow migration bytes
When to check
Breakdowns
Further Analysis
Data Movement Shadow migration ops
Data Movement: Shadow migration ops
When to check
Breakdowns
Further Analysis
Data Movement Shadow migration requests
Data Movement: Shadow migration requests
When to check
Breakdowns
Further Analysis
Disk Disks
Disk: Disks
When to check
Breakdowns
Interpretation
Further Analysis
Details
Disk IO bytes
Disk: I/O bytes
When to check
Breakdowns
Further Analysis
Disk IO operations
Disk: I/O operations
When to check
Breakdowns
Further Analysis
Network Device bytes
Network: Device bytes
When to check
Breakdowns
Further Analysis
Network Interface bytes
Network: Interface bytes
Example
When to check
Breakdowns
Further Analysis
Protocol SMB operations
Protocol: SMB operations
Example
When to check
Breakdowns
Further Analysis
Protocol Fibre Channel bytes
Protocol: Fibre Channel bytes
Example
When to check
Breakdowns
Further Analysis
Protocol Fibre Channel operations
Protocol: Fibre Channel operations
Example
When to check
Breakdowns
Further Analysis
Protocol FTP bytes
Protocol: FTP bytes
Example
When to check
Breakdowns
Further Analysis
Protocol HTTPWebDAV requests
Protocol: HTTP/WebDAV requests
When to check
Breakdowns
Further Analysis
Protocol iSCSI bytes
Protocol: iSCSI bytes
When to check
Breakdowns
Further Analysis
Protocol iSCSI operations
Protocol: iSCSI operations
When to check
Breakdowns
Further Analysis
Protocol NFSv2 operations
Protocol: NFSv2 operations
Example
When to check
Breakdowns
Further Analysis
Protocol NFSv3 operations
Protocol: NFSv3 operations
When to check
Breakdowns
Further Analysis
Protocol NFSv4 operations
Protocol: NFSv4 operations
Example
When to check
Breakdowns
Further Analysis
Protocol SFTP bytes
Protocol: SFTP bytes
Example
When to check
Breakdowns
Further Analysis
Protocol SRP bytes
Protocol: SRP bytes
Example
When to check
Breakdowns
Further Analysis
Protocol SRP operations
Protocol: SRP operations
Example
When to check
Breakdowns
Further Analysis
CPU CPUs
CPU: CPUs
When to check
Breakdowns
Details
CPU Kernel spins
CPU: Kernel spins
When to check
Breakdowns
Cache ARC adaptive parameter
Cache: ARC adaptive parameter
When to check
Breakdowns
Cache ARC evicted bytes
Cache: ARC evicted bytes
When to check
Breakdowns
Cache ARC size
Cache: ARC size
When to check
Breakdowns
Cache ARC target size
Cache: ARC target size
When to check
Breakdowns
Cache DNLC accesses
Cache: DNLC accesses
When to check
Breakdowns
Cache DNLC entries
Cache: DNLC entries
When to check
Breakdowns
Cache L2ARC errors
Cache: L2ARC errors
When to check
Breakdowns
Cache L2ARC size
Cache: L2ARC size
When to check
Breakdowns
Data Movement NDMP file system operations
Data Movement: NDMP file system operations
When to check
Breakdowns
Data Movement NDMP jobs
Data Movement: NDMP jobs
When to check
Breakdowns
Disk Percent utilization
Disk: Percent utilization
When to check
Breakdowns
Notes
Disk ZFS DMU operations
Disk: ZFS DMU operations
When to check
Breakdowns
Disk ZFS logical IO bytes
Disk: ZFS logical I/O bytes
When to check
Breakdowns
Disk ZFS logical IO operations
Disk: ZFS logical I/O operations
When to check
Breakdowns
Memory Dynamic memory usage
Memory: Dynamic memory usage
When to check
Breakdowns
Memory Kernel memory
Memory: Kernel memory
When to check
Breakdowns
Memory Kernel memory in use
Memory: Kernel memory in use
When to check
Breakdowns
Memory Kernel memory lost to fragmentation
Memory: Kernel memory lost to fragmentation
When to check
Breakdowns
Network IP bytes
Network: IP bytes
When to check
Breakdowns
Network IP packets
Network: IP packets
When to check
Breakdowns
Network TCP bytes
Network: TCP bytes
When to check
Breakdowns
Network TCP packets
Network: TCP packets
When to check
Breakdowns
System NSCD backend requests
System: NSCD backend requests
When to check
Breakdowns
System NSCD operations
System: NSCD operations
When to check
Breakdowns
Open Worksheets
Worksheets
Graph
Quantize Plot
Show Hierarchy
Common
Background Patterns
Saving a Worksheet
Toolbar Reference
CLI
Tips
Tasks
BUI
Saved Worksheets
Introduction
Properties
BUI
CLI
Datasets
Introduction
BUI
CLI
Viewing available datasets
Reading datasets
Suspending and Resuming all datasets
7.  Application Integration
Glossary
Index
This statistic shows Fibre Channel bytes/sec requested by initiators to the appliance.
Example
See Protocol: iSCSI bytes for an example of a similar statistic with similar breakdowns.
When to check
Fibre Channel bytes/sec can be used as an indication of FC load, in terms of throughput. For a deeper analysis of FC activity, see Protocol: Fibre Channel operations.
Breakdowns
Breakdown
Description
initiator
Fibre Channel client initiator
target
local SCSI target
project
the project for this FC request.
lun
the LUN for this FC request.
See the SAN page for terminology definitions.
Further Analysis
See Protocol: Fibre Channel operations for numerous other breakdowns on FC operations; also see Cache: ARC accesses broken down by hit/miss to see how well an FC read workload is returning from cache, and Disk: I/O operations for the back-end disk I/O caused.
