Skip Navigation Links
Exit Print View
Sun ZFS Storage 7x20 Appliance Customer Service Manual
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Hardware Maintenance
Maintenance
Introduction
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Electrical Specifications
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
7320 Storage Disk Shelf
See Also
7420/7720
7420/7720 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Boards
Components
CPU and Memory
Fan Modules
7420 Standalone and Cluster Controller Configurations
Standalone Base Options
Cluster Base Options
NIC/HBA Options
PCIe Options
7720 Cluster Controller Configurations
NIC HBA Options
SDD Options
PCIe Options
Attached Storage
Disk Shelf
7700 Cabinet
7700
7700 Hardware Overview
Cabinet Specifications
Front and Rear Panels
Cabinet Dimensions
External Components
External Cables
Fan Trays
Drive Cages
Leaf Controller Cards
Power Supplies
Root Controller Cards
Solid State Drives
Internal Components
Cabling
Interface Boards
See Also
7x20
7x20 and 7700 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Controller Replacement Tasks
7x20 Controller Replacement Tasks
HDD or SSD
Fan Module
Power Supply
Memory
Battery
Cabinet Replacement Tasks
7x20 Cabinet Replacement Tasks
HDD or SSD
Fan Tray
LCC
Power Supply
System Indicator Boards
Storage Expansion Upgrade
SAS2
Sun Disk Shelf Overview
SAS2 Sun Disk Shelf Overview
Power Supply Exterior
Drive Locations
Drive Assembly Exterior
SIM Board Exterior
Disk Shelf Configurations
Sun Disk Shelf
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Tasks
Shelf Tasks
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
HBA Expansion pt.1
Expanding from 2 to 3 HBAs
Cabling Diagrams
HBA Expansion pt.2
Expanding from 3 to 4 HBAs
Cabling Diagrams
3.  System Maintenance
Glossary
Index
Faults
Hardware Faults
This section describes connecting to the controller Service Processor (SP) and configuration considerations for maximum serviceability. In rare cases, faults associated with uncorrectable CPU errors are not diagnosable or displayed in the controller. These faults will be preserved by and observable on the ILOM. The following sections describe how to connect to and manage faults for these cases.
Connect to ILOM
Connect to the server ILOM (Service Processor) on the server platform to diagnose hardware faults that do not appear in the BUI.
In a cluster environment, an ILOM connection should be made to each controller.
The server ILOM provides options for (i) network and (ii) serial port connectivity. Network connection is the preferred choice, as the ILOM serial port does not always allow adequate means of platform data collection.
WARNING : Failure to configure ILOM connectivity may lead to longer than necessary hardware fault diagnosis and resolution times.
All standalone controllers should have at least one NIC port configured as a management interface. Select the Allow Admin option in the BUI to enable BUI connections on port 215 and CLI connections on ssh port 22.
All cluster installations should have at least one NIC port on each controller configured as a management interface as described above. In addition, the NIC instance number must be unique on each controller. For example, nodeA uses nge0 and nodeB uses nge1, so that neither may be used as a cluster data interface. In addition, these interfaces must be locked to the controller using the Configuration -> Cluster option in the BUI. In some cases, this may require installation of an additional network interface card on each controller in a cluster configuration.
If access to the appliance data interfaces is impossible for any reason, the management network interface will maintain BUI and CLI access. During a cluster takeover, interfaces are taken down on the failed controller. So, locked interface configuration is required to gather diagnostic information from a failed controller.
WARNING : Failure to configure locked management interfaces on a cluster may lead to longer than necessary fault diagnosis and resolution times.
Log in to the server as root using the ILOM CLI. To view server faults, type the following command to list all known faults on the system:
-> show /SP/faultmgmt
The server lists all known faults, for example:
SP/faultmgmt
  Targets:
      0 (/SYS/MB/P0)
  Properties:
  Commands:
      cd
      show
To clear the CPU fault, type the following command:
-> set /SYS/MB/Pn clear_fault_action=true
For example, to clear a fault on CP0:
-> set /SYS/MB/P0 clear_fault_action=true
Are you sure you want to clear /SYS/MB/P0 (y/n)? y
See Also
