Skip Navigation Links
Exit Print View
Sun ZFS Storage 7x20 Appliance Customer Service Manual
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Hardware Maintenance
Maintenance
Introduction
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Electrical Specifications
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
7320 Storage Disk Shelf
See Also
7420/7720
7420/7720 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Boards
Components
CPU and Memory
Fan Modules
7420 Standalone and Cluster Controller Configurations
Standalone Base Options
Cluster Base Options
NIC/HBA Options
PCIe Options
7720 Cluster Controller Configurations
NIC HBA Options
SDD Options
PCIe Options
Attached Storage
Disk Shelf
7700 Cabinet
7700
7700 Hardware Overview
Cabinet Specifications
Front and Rear Panels
Cabinet Dimensions
External Components
External Cables
Fan Trays
Drive Cages
Leaf Controller Cards
Power Supplies
Root Controller Cards
Solid State Drives
Internal Components
Cabling
Interface Boards
See Also
7x20
7x20 and 7700 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Controller Replacement Tasks
7x20 Controller Replacement Tasks
HDD or SSD
Fan Module
Power Supply
Memory
Battery
Cabinet Replacement Tasks
7x20 Cabinet Replacement Tasks
HDD or SSD
Fan Tray
LCC
Power Supply
System Indicator Boards
Storage Expansion Upgrade
SAS2
Sun Disk Shelf Overview
SAS2 Sun Disk Shelf Overview
Power Supply Exterior
Drive Locations
Drive Assembly Exterior
SIM Board Exterior
Disk Shelf Configurations
Sun Disk Shelf
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Tasks
Shelf Tasks
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
HBA Expansion pt.1
Expanding from 2 to 3 HBAs
Cabling Diagrams
HBA Expansion pt.2
Expanding from 3 to 4 HBAs
Cabling Diagrams
3.  System Maintenance
Glossary
Index
7320
Use the information in this section as a preparation and reference for servicing replaceable components of the 7320 system. Refer to the following for procedural instructions:
Chassis Overview
The Sun ZFS Storage 7320 System consists of either a single storage controller, or two storage controllers in a high availability cluster configuration, and one to four Sun Disk Shelves.
The 7320 controller base configuration includes two CPUs, built-in 4 x 1Gb/s front-end GigE ports, redundant power supplies, NIC options for expanded front-end support, tape backup, Infiniband, and dual port SAS HBA for storage expansion.
The CPUs are Intel Xeon 5600 series, 2.40GHz, 80W, 4 core processors. Standard memory configuration is 24GB, 3 x 4GB DDR3-1333 DR DIMMs and may be upgraded to 48GB using 6x4GB DDR3-1333 DR DIMMs per CPU or to 72GB using 9x4GB DDR3 DR DIMMs per CPU. The clustered configuration simply uses two servers and a cluster card in each server for a heartbeat connection between them.
All user-accessible storage is provided by one to four Sun Disk shelves external to the server(s). The RAID function is done by the software. Solid State 18GB SAS-1 drives (7320 SAS-2) which are used for high-performance write cache known as LogZilla or ZFS intent log (ZIL) devices, are in place of one to four of the 24 drives in the Disk Shelf, the remaining 20 drives are available for storage.
Refer to the http://www.sun.com/storage/disk_systems/unified_storage/7320/specs.xml for the most recent component specification.
The 7320 is a next-generation SAS-2 (Serial Attached SCSI 2.0) device that consists of a new HBA, new disk shelf, and new disks (1TB and 2TB SAS-2). The SAS-2 storage fabric supports greater number of targets, greater bandwidth, higher reliability and bigger scale.
Boards
The storage controller chassis has the following boards installed. Field-replaceable units (FRUs) should only be replaced by trained Sun service technicians.
Following is the complete set of replaceable system boards for the 7320 storage controller.
Part Number
Description
FRU/CRU
F541-2883-01
X8 PCIe Riser Card 1U
CRU
F541-2885-01
X16 PCIe Riser Card 1U
CRU
F541-4081-01
RoHS Motherboard and Tray
FRU
F511-1489-01
DB, Power Distribution Board
FRU
F511-1548-01
PCB, 8 Disk 1U Backplane
FRU
F541-4275-02
PCBA, Connector Board, 1U
FRU
Cables
Following is the complete set of replaceable cables for the 7320 storage controller.
Part Number
Description
FRU/CRU
F530-4228-01
Cable, Mini SAS
FRU (internal)
F530-3927-01
FRU,CBL,PDB,MB,1U+2U,RIBBON
FRU (internal)
F530-4431-01
Cable, Fan data
FRU (internal)
F530-4417-01
FRU Cable, Fan paddle
FRU (internal)
F530-3880-01
Cable, Assembly, Ethernet, Shielded, RJ45-RJ45, 6m
CRU (external)
F530-3883-01
FRU,2M,4X Mini SAS Cable
CRU (external)
7320 I/O Components
The I/O components of the storage controller are shown in the following figure and identified in the table. Image
Figure Legend
1 Top cover
2 Left Control Panel Light Pipe Assembly
3 Drive Cage
4 Solid State Drives
5 blank/USB Module
6 Right Control Panel Light Pipe Assembly
Following are the replaceable CPU and memory components of the 7320 system.
Part Number
Description
FRU/CRU
F371-4898-01
DIMM, 4GB, DDR3, 2RX4, 13
FRU
F371-4885-01
Intel E5620, 2.40G
FRU
The storage controller motherboard has 18 slots in two groups that hold industry-standard DDR3 DIMM memory cards. All sockets must be occupied by either a filler or a DDR3 DIMM. Image
The Power Distribution/Fan Module components of the storage controller are shown in the following figure and identified in the table.
Figure Legend
1 Fan Modules
4 Power Distribution/Bus Bar Assembly
2 Fan Board
5 Power Supplies
3 Paddle Board
The following list shows the electrical specifications for the 7320. Note that the power dissipation numbers listed are the maximum rated power numbers for the power supply. The numbers are not a rating of the actual power consumption of the appliance.
Connectors
Input
Output
Power dissipation
7320 Front Panel
The following graphic illustrates the front panel LEDs.
The table describes the LEDs.
Figure Legend
1 Locate Button/LED
2 Service Required LED (amber)
3 Power/OK LED (green)
4 Power Button
5 Rear Power Supply
6 System Overtemperature LED
7 Top Fan
The following graphic illustrates the 7320 front panel with drive locations described in the table. Two mirrored hard disk drives (HDDs) that store the operating system reside in slots 0 and 1. Up to four solid state drives (ReadZilla SSDs) that store the read cache fill slots 2 through 5, in order. Slots 6 and 7 are empty and must contain drive fillers.
Disk Drive Locations
HDD1
HDD3
HDD5
HDD0
HDD2
HDD4
HDD6
HDD7
Following is the complete list of replaceable power distribution, disk, and fan module components of the 7320 system. Note that power supplies, disks, and fan modules are hot-pluggable on the storage controller.
Part Number
Description
FRU/CRU
F300-2233-02
RoHS 760W Power Supply
CRU
F541-2075-04
Buss Bar Power, 1U
FRU
F542-0184-01
DR, 3Gb SATA
CRU
F542-0330-01
2.5" 512GB ReadZilla SSD
CRU
F541-276-01
ASSY,FAN Module
CRU
F541-4274-02
Fan Board (1U)
FRU
Following is the complete list of replaceable PCIe cards for the 7320 system.
Part Number
Description
FRU/CRU
F371-4325-01
8Gb FC HBA (PCIe)
CRU
F375-3609-02
PCA, SAS 6GBS 8 Port (PCIe)
CRU
F375-3606-03
Dual Port (x4) IB HCA (PCIe)
CRU
F375-3696-01
Dual Port CX2 4XQDR (PCIe)
CRU
F375-3617-01
2X10GbE SFP+, X8 (PCIe)
CRU
F375-3481-01
NIC Card Quad Port 1GigE Cu (PCIe)
CRU
F511-1496-04
Sun Fishworks Cluster Controller 200 (PCIe)
FRU
7320 Rear Panel
Following is an illustration of the 7320 storage controller rear panel. The Sun 375-3609 belongs in slot 2, cannot be installed in any other slots, and a second is not offered as an option.
Figure Legend
1 Power supplies
4 Network management port
2 SC summary status LEDs
5 Ethernet ports
3 Serial management port
6 PCIe slots
The single controller base configuration is 24GB RAM, 2x2.4GHz Quad-Core processors, one external SAS HBA, and four 10/100/1000 Ethernet ports.
This table describes base configurations for the 7320.
Mktg Part Number
Description
Mfg Part Number
TA7320-24A
S7320, 2xCPU, 24GB, Single
597-1060-01
TA7320-24A-HA
S7320, 2xCPU, 24GB, Cluster
597-1061-01
Following are the PCIe configuration options for a single controller. All PCIe cards are low-profile, and must be fitted with low-profile mounting brackets.
Slot
Type
Part Number
Vendor Part
Description
Note
0
PCIe
375-3617-01
Intel Niantic
DP Optical 10GE NIC
Optional Recommended Front-end
0
PCIe
375-3696-01
Mellanox
InfiniBand HCA
0
PCIe
375-3606-03
MHJH29-XTC
InfiniBand HCA
0
PCIe
375-3481-01
Intel EXPI9404PT
QP Copper NIC
0
PCIe
371-4325-01
QLogic
8Gb DP FC HBA
Optional FC Target or Initiator (Backup)
1
PCIe
375-3617-01
Intel Niantic
DP Optical 10GE NIC
1
PCIe
375-3696-01
Mellanox
InfiniBand HCA
1
PCIe
375-3606-03
MHJH29-XTC
InfiniBand HCA
1
PCIe
375-3481-01
Intel EXPI9404PT
QP Copper NIC
1
PCIe
371-4325-01
QLogic
8Gb DP FC HBA
2
PCIe
375-3609-03
Sun Thebe
External SAS HBA
Base Configuration
The 7320 cluster base configuration is 24GB RAM, 2x2.4GHz Quad-Core processors, one external SAS HBA, and four 10/100/1000 Ethernet ports, and a Cluster card. The Sun Storage 7420C Cluster Upgrade Kit (XOPT 594-4680-01) contains two cluster cards with cables for converting two 7320 or two 7420 controllers to a cluster.
The following options are available for clustered storage controllers. Note that both storage controllers in a cluster must be configured identically with regard to card configurations and all optional NIC/HBA card configurations chosen for clustered storage controllers must be identical in both chassis.
Slot
Type
Part Number
Vendor Part
Description
Note
0
PCIe
375-3617-01
Intel Niantic
DP Optical 10GE NIC
0
PCIe
375-3696-01
Mellanox
InfiniBand HCA
0
PCIe
375-3606-03
MHJH29-XTC
InfiniBand HCA
0
PCIe
375-3481-01
Intel EXPI9404PT
QP Copper NIC
0
PCIe
371-4325-01
QLogic
8Gb DP FC HBA
1
PCIe
542-0298-01
Sun
Fishworks Cluster Card 2
Cluster Base Configuration
2
PCIe
375-3609-03
Sun Thebe
External SAS HBA
The serial management connector (SERIAL MGT) is an RJ-45 connector and a terminal connection to the SP console.
The network management connector (NET MGT) is an RJ-45 connector on the motherboard and provides an alternate terminal interface to the SP console.
There are four RJ-45 Gigabit Ethernet connectors (NET0, NET1, NET2, NET3) located on the motherboard that operate at 10/100/1000 Mbit/sec. These network interfaces must be configured before use.
The 7320 single and cluster controller configurations allow a single chain of 1 to 4 Sun Disk Shelves. Any combination of disk-only and Logzilla-capable shelves may be combined within the chain in any order. The cabling configurations are unchanged. Half-populated shelf configurations are not supported.
See Also
