Skip Navigation Links
Exit Print View
Sun ZFS Storage 7x20 Appliance Customer Service Manual
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Hardware Maintenance
Maintenance
Introduction
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Electrical Specifications
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
7320 Storage Disk Shelf
See Also
7420/7720
7420/7720 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Boards
Components
CPU and Memory
Fan Modules
7420 Standalone and Cluster Controller Configurations
Standalone Base Options
Cluster Base Options
NIC/HBA Options
PCIe Options
7720 Cluster Controller Configurations
NIC HBA Options
SDD Options
PCIe Options
Attached Storage
Disk Shelf
7700 Cabinet
7700
7700 Hardware Overview
Cabinet Specifications
Front and Rear Panels
Cabinet Dimensions
External Components
External Cables
Fan Trays
Drive Cages
Leaf Controller Cards
Power Supplies
Root Controller Cards
Solid State Drives
Internal Components
Cabling
Interface Boards
See Also
7x20
7x20 and 7700 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Controller Replacement Tasks
7x20 Controller Replacement Tasks
HDD or SSD
Fan Module
Power Supply
Memory
Battery
Cabinet Replacement Tasks
7x20 Cabinet Replacement Tasks
HDD or SSD
Fan Tray
LCC
Power Supply
System Indicator Boards
Storage Expansion Upgrade
SAS2
Sun Disk Shelf Overview
SAS2 Sun Disk Shelf Overview
Power Supply Exterior
Drive Locations
Drive Assembly Exterior
SIM Board Exterior
Disk Shelf Configurations
Sun Disk Shelf
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Tasks
Shelf Tasks
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
HBA Expansion pt.1
Expanding from 2 to 3 HBAs
Cabling Diagrams
HBA Expansion pt.2
Expanding from 3 to 4 HBAs
Cabling Diagrams
3.  System Maintenance
Glossary
Index
7420/7720
Use the information on this page as a preparation reference for servicing replaceable components of 7420 and 7720 controllers. Refer to the following for procedural instructions:
Chassis Overview
The Sun ZFS Storage 7420 Appliance consists of either a single storage controller, or two storage controllers in a high availability cluster configuration, and one to 24 Sun Disk shelves. Refer to the http://www.sun.com/storage/disk_systems/unified_storage/7420/specs.xml for the most recent component specification.
The Sun ZFS Storage 7720 Appliance is comprised of two storage controllers in a high availability cluster configuration installed in a Sun Storage 7700 cabinet, which houses twelve drive cages. Refer to the http://www.sun.com/storage/disk_systems/unified_storage/7720/specs.xml for the most recent component specification.
The 3U chassis form factor dimensions are as follows:
Dimension
Measurement
Dimension
Measurement
Height
13.3 cm/5.25 in
Depth
70.6 cm/27.8 in
Width
43.7 cm/17.19 in
Weight
16.36 kg/96 lbs
Front Panel
Figure Legend
1 Locator LED and button (white)
7 Power Supply (PS) Service Required LED
13 Boot drive 1 (required)
2 Service Required LED (amber)
8 Over Temperature Warning LED
14 Solid state drive 2 (optional)
3 Power/OK LED (green)
9 USB 2.0 Connectors
15 Solid state drive 3 (optional)
4 Power button
10 DB-15 video connector
16 Solid state drive 4 (optional)
5 Service Processor (SP) OK LED (green)
11 SATA DVD drive (optional)
6 Fan/CPU/Memory Service Required LED
12 Boot drive 0
17 Solid state drive 5 (optional)
The 500GB boot drives (HDDs) reside in slots 0 and 1 as a mirrored set, and Sun Storage Readzilla 512GB solid state drives (SSDs), may optionally fill, in order, slots 2 through 5. Each storage controller may have 0, 2, 3, or 4 Readzilla devices.
Figure Legend
1 Locate (white)
2 Service action required (amber)
3 OK/Activity (green)
Rear Panel
The following graphic shows the 7420/7720 rear panel.
Figure Legend
1 Power supply unit 0 status LEDs OK: green Power Supply Fail: amber AC OK: green
8 Network (NET) 10/100/1000 ports: NET0-NET3
2 Power supply unit 0 AC inlet
3 Power supply unit 1 status LEDs OK: green Power Supply Fail: amber AC OK: green
10 PCIe slots 5-9
4 Power supply unit 1 AC inlet
11 Network management (NET MGT) port
5 System status LEDs Power: green Attention: amber Locate: white
12 Serial management (SER MGT) port
6 PCIe slots 0-4
13 DB-15 video connector
7 Cluster card slot
Internal Boards
7420/7720 storage controller chassis have the following boards installed. Field-replaceable units (FRUs) should only be replaced by trained Sun service technicians.
Components
The components of the storage controller are shown in the following figure and identified in the table.
Figure Legend
1 Motherboard
8 System lithium battery
2 Low-profile PCIe cards
9 CPUs and heatsinks
3 Power supplies
10 Memory Risers
4 Power supply backplane
11 Fan board
5 Filler
12 Fan Modules
7 Drive backplane
14 Boot drives and SSDs
CPU and Memory
The 7420 appliance supports two or four CPUs, with two memory risers required by each CPU. Four or eight 4GB or 8GB DDR3 DIMMs are installed on each riser, accommodating up to 256GB of memory for two CPUs, or up to 512GB for four CPUs. Empty CPU sockets must have memory riser fillers installed for proper cooling. Note: The 7720 supports four CPU configurations only and the four CPU system requires high-line (200 to 240 Volt) AC sources to turn on main power.
Refer to the service label on the cover for DIMM placement information. On every memory riser, slots D0, D2, D4, and D6 must be populated; optionally, slots D1, D3, D5, and D7 may be populated as a group on all installed memory risers. All DIMMs in the system must be identical.
DIMM names in appliance logs and the Maintenance > Hardware view are displayed with the full name, such as /SYS/MB/P0/D7.
Fan Modules
The Fan Modules and Fan Module LEDs of the storage controller are shown in the following figure. The following LEDs are lit when a fan module fault is detected:Image
The system Overtemp LED might light if a fan fault causes an increase in system operating temperature.
The 7420/7720 PCIe expansion system is configured using two types of riser cards, as follows. Note that PCIe cards with x4, x8, or x16 mechanical finger pins will fit in any riser slot but will operate at the lane width of the slot. The Sun Fishworks Cluster Controller 200 belongs in the Cluster slot (C) only. SAS HBAs must all be of the same type, installed in slots 1 and 8, with an optional third SAS HBA in slot 2, and an optional fourth SAS HBA in slot 7. PCIe slots should be populated in the following order: 9 (if used), 0 (if used), 7, 2, 6, 3, 5, 4.
Riser/Slot Numbers
Electrical
Mechanical
Source
Riser 0 - Slot 0
x8
x8
MCP55
Riser 0 - Slot 3
x8
x8
MCP55
Riser 1 - Slot 1 (internal SAS HBA)
x8
x8
MCP55
Riser 1 - Slot 4 (internal SAS HBA)
x8
x8
IO55
Riser 2 - Slot 2 (optional 3rd internal SAS HBA)
x16
x16
IO55
Riser 2 - Slot 5
x4
x8
IO55
Riser 3 - Slot 6
x4
x8
IO55
Riser 3 - Slot 7(optional 4th internal SAS HBA)
x4
x8
IO55
Riser 4 - Slot 8
x4
x8
IO55
Riser 4 - Slot 9
x4
x8
IO55
The serial management connector (SER MGT) is an RJ-45 connector and provides a terminal connection to the SP console. Image
The network management connector (NET MGT) is an RJ-45 connector and provides a LAN interface to the SP console. Image
There are four RJ-45 Gigabit Ethernet connectors (NET0, NET1, NET2, NET3) located on the motherboard that operate at 10/100/1000 Mbit/sec. These network interfaces must be configured before use.
The following tables show the configuration options for a single standalone 7420 controller or two clustered 7420 controllers. All PCIe cards are low-profile, and must be fitted with low-profile mounting brackets.
This table describes 7420 standalone base configurations.
Mktg Part Number
Description
Mfg Part Number
TA7420-26AR00
S7420, no DIMMs, 2x1.86GHz-6C
597-0789-01
TA7420-28AR00
S7420, no DIMMs, 2x2.00GHz-8C
597-0790-01
This table describes 7420 cluster base configurations.
Mktg Part Number
Description
Mfg Part Number
TA7420-26AR00HA
S7420, no DIMMs, 2x1.86GHz-6C, Cluster
597-0795-01
TC7420-28AR00HA
S7420, no DIMMs, 2x2.00GHz-8C, Cluster
597-0792-01
NIC/HBA Options
This table describes NIC/HBA options for 7420 single and cluster configurations.
Mktg Part Number
Description
Mfg Part Number
SG-XPCIESAS-GEN2-Z
2-port External Sun Thebe SAS (x4) HBA, PCIe
F375-3609-03
SG-XPCIE2FC-QF8-Z
2-port FC HBA, 8Gb, PCIe
594-5684-01
X4446A-Z
4-port PCIe Quad GigE UTP
594-4024-01
X4237A
2-port 4X IB HCA PCIe
594-5862-02
X1109A-Z
2-port 10Gig SFP+ NIC, PCIe
594-6039-01
X2129A
XCVRm 850NM, 1/10GPS, Short Reach, SFP
594-6508-01
PCIe Options
This table describes the supported single and clustered PCIe configuration option summary for 7420.
Slot
Type
Sun Part Number
Description
Note
0
PCIe
371-4325-01
8Gb DP FC HBA
Optional FC Target or Initiator (Backup)
1
PCIe
375-3609-02
DP SAS-2 HBA
Base Configuration
2
PCIe
375-3609-02
DP SAS-2 HBA
Additional Optional Back-end
2
PCIe
375-3481-01
QP Copper NIC
Optional Recommended Front-end
2
PCIe
371-4325-01
8Gb DP FC HBA
2
PCIe
375-3606-01
Infiniband HCA
2
PCIe
375-3617-01
DP Optical 10GE NIC
3
PCIe
375-3481-01
QP Copper NIC
3
PCIe
371-4325-01
8Gb DP FC HBA
3
PCIe
375-3606-01
Infiniband HCA
3
PCIe
375-3617-01
DP Optical 10GE NIC
4
PCIe
375-3481-01
QP Copper NIC
4
PCIe
375-3606-01
InfiniBand HCA
4
PCIe
375-3617-01
DP Optical 10GE NIC
C
PCIe
511-1496-04
Cluster Base Configuration ONLY
5
PCIe
375-3481-01
QP Copper NIC
5
PCIe
375-3606-01
InfiniBand HCA
5
PCIe
375-3617-01
DP Optical 10GE NIC
6
PCIe
375-3481-01
QP Copper NIC
6
PCIe
371-4325-01
8Gb DP FC HBA
6
PCIe
375-3606-01
InfiniBand HCA
6
PCIe
375-3617-01
DP Optical 10GE NIC
7
PCIe
375-3609-02
DP SAS-2 HBA
7
PCIe
375-3481-01
QP Copper NIC
7
PCIe
371-4325-01
8Gb DP FC HBA
7
PCIe
375-3606-01
Infiniband HCA
7
PCIe
375-3617-01
DP Optical 10GE NIC
8
PCIe
375-3609-02
DP SAS-2 HBA
Base Configuration
9
PCIe
371-4325-01
8Gb DP FC HBA
The following table shows the configuration options for the clustered 7720 controllers. All PCIe cards are low-profile and are fitted with low-profile mounting brackets.
Mktg Part Number
Description
Mfg Part Number
N/A
ASSY, S7720 Cluster, 4x8C, 128GB
597-0865-01
N/A
ASSY, S7720 Cluster, 4x8C, 256GB
597-0880-01
N/A
ASSY, S7720 Cluster, 4x8C, 512GB
597-0881-01
NIC HBA Options
The following table describes NIC HBA options for the 7720.
Mktg Part Number
Description
Mfg Part Number
X4237A
594-5862-02
SG-XPCIE2FC-QF8-Z
594-5684-01
X4446A-Z
594-4024-01
X1109A-Z
594-6039-01
SDD Options
The following table describes the SSD options for 7720 cluster configurations.
Mktg Part Number
Description
Mfg Part Number
XTA7000-READZ512
S7000 Readzilla Cache 512GB
594-6713-01
PCIe Options
The following table describes the 7720 clustered PCIe configuration options.
Slot
Type
Sun Part Number
Description
Note
0
PCIe
371-4325-01
8Gb DP FC HBA
1
PCIe
375-3609-02
DP SAS-2 HBA
Base Configuration
2
PCIe
375-3609-02
DP SAS-2 HBA
3
PCIe
375-3481-01
QP Copper NIC
3
PCIe
371-4325-01
8Gb DP FC HBA
3
PCIe
375-3606-01
Infiniband HCA
3
PCIe
375-3617-01
DP Optical 10GE NIC
4
PCIe
375-3481-01
QP Copper NIC
4
PCIe
375-3606-01
Infiniband HCA
4
PCIe
375-3617-01
DP Optical 10GE NIC
C
PCIe
542-0298-01
5
PCIe
375-3481-01
QP Copper NIC
5
PCIe
375-3606-01
InfiniBand HCA
5
PCIe
375-3617-01
DP Optical 10GE NIC
6
PCIe
375-3481-01
QP Copper NIC
6
PCIe
371-4325-01
8Gb DP FC HBA
6
PCIe
375-3606-01
InfiniBand HCA
6
PCIe
375-3617-01
DP Optical 10GE NIC
7
PCIe
375-3609-02
DP SAS-2 HBA
Base Configuration
8
PCIe
375-3609-02
DP SAS-2 HBA
Base Configuration
9
PCIe
371-4325-01
8Gb DP FC HBA
Attached Storage
The 7420 and 7720 do not contain primary storage within their chassis, and therefore connect to external storage shelves and cages. The sections below outline the differences between these two controllers and their attached storage.
Disk Shelf
The 7420 single and cluster controller configurations allow one to four chains of 1 to 6 Sun Disk Shelves. Any combination of disk-only and Logzilla-capable shelves may be combined within the chain in any order. The cabling configurations are unchanged. Half-populated shelf configurations are not supported.
See Disk Shelf Overview for component specifications and diagrams.
7700 Cabinet
Two clustered 7720 controllers are installed in a 7700 main cabinet with 12 disk cages. See 7700 Hardware Overview for component specifications and diagrams.
