Skip Navigation Links
Exit Print View
Sun ZFS Storage 7x20 Appliance Customer Service Manual
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Hardware Maintenance
Maintenance
Introduction
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Electrical Specifications
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
7320 Storage Disk Shelf
See Also
7420/7720
7420/7720 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Boards
Components
CPU and Memory
Fan Modules
7420 Standalone and Cluster Controller Configurations
Standalone Base Options
Cluster Base Options
NIC/HBA Options
PCIe Options
7720 Cluster Controller Configurations
NIC HBA Options
SDD Options
PCIe Options
Attached Storage
Disk Shelf
7700 Cabinet
7700
7700 Hardware Overview
Cabinet Specifications
Front and Rear Panels
Cabinet Dimensions
External Components
External Cables
Fan Trays
Drive Cages
Leaf Controller Cards
Power Supplies
Root Controller Cards
Solid State Drives
Internal Components
Cabling
Interface Boards
See Also
7x20
7x20 and 7700 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Controller Replacement Tasks
7x20 Controller Replacement Tasks
HDD or SSD
Fan Module
Power Supply
Memory
Battery
Cabinet Replacement Tasks
7x20 Cabinet Replacement Tasks
HDD or SSD
Fan Tray
LCC
Power Supply
System Indicator Boards
Storage Expansion Upgrade
SAS2
Sun Disk Shelf Overview
SAS2 Sun Disk Shelf Overview
Power Supply Exterior
Drive Locations
Drive Assembly Exterior
SIM Board Exterior
Disk Shelf Configurations
Sun Disk Shelf
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Tasks
Shelf Tasks
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
HBA Expansion pt.1
Expanding from 2 to 3 HBAs
Cabling Diagrams
HBA Expansion pt.2
Expanding from 3 to 4 HBAs
Cabling Diagrams
3.  System Maintenance
Glossary
Index
7700
This page contains information and instructions to help prepare you for servicing replaceable components in the Sun ZFS Storage 7700 appliance. For instructions on how to replace appliance components or for more information about the system controller, refer to the following pages:
The Sun ZFS Storage 7700 appliance cabinet houses all of the components that support a clustered storage system. The cabinet includes 12 cages that host 30 hard disk drives (HDDs), 2 leaf controller cards (LCCs), and 2 optional Logzilla solid state drives (SSDs). To control these resources, the appliance includes 2 system controllers and 2 rack controller cards (RCCs) on internal and external SAS and Ethernet networks. To power and cool the components, the cabinet includes 6 power supplies (PSUs) and 3 fan trays.
The lower cabinet is populated with 2 3U Sun ZFS 7720 storage controllers containing 4-socket CPU motherboards with large memory capacities, 4 optional read-optimized Readzilla SSDs and 10 PCIe slots with installed adapters that are clustered by default in a high availability configuration.
The following illustration shows the 7700 front panel (left) and rear panel (right) of the main cabinet. Image
Figure Legend
1 Fan trays
5 Power supplies
2 LCCs
6 RCCs
3 Disk cages
7 Storage controllers (main cabinet only)
4 HDDs and SSDs
Refer to http://www.sun.com/storage/disk_systems/unified_storage/7700/specs.xml for the most recent component specification.
Cabinet Dimensions
Description
U.S.
Metric
Width
23.5 in
60 cm
Depth (without doors)
43.0 in
109 cm
Depth (with front and rear doors)
46.0 in
117 cm
Height
79.5 in
202 cm
Maximum weight, storage system cabinet
1,740 lb
790 kg
Clearance, front or rear of system for service access
48 in
122 cm
Clearance, above system
18 in
46 cm
External Components
This section includes descriptions about the main components included in the 7700 main cabinet.
External Cables
The 7700 appliance is shipped with installed external cables located behind the cabinet doors. SAS cables connect the RCCs to the storage controllers, and Ethernet cables connect the internal Ethernet bus between the system controllers.
The external cables consist of power and data cables. The power cables (1) connect the power supplies and system controllers in the main cabinet to the power circuits (2 and 3) in the facility that connect to the power sources (4 and 5). Image
The following illustration shows the data cables that create the default cluster configuration between the system controllers and the RCCs. Image
Fan Trays
Each 7700 cabinet comes with three fan trays that each host three fan modules. Individual fan modules cannot be replaced; the entire fan tray must be replaced.
Caution: Operating a cabinet for an extended period of time with a fan tray removed reduces the effectiveness of the cooling system, and may initiate an emergency thermal shutdown. Unpack the replacement fan tray in advance, and insert it into the cabinet as soon as the faulted fan tray is removed. Cooling for the 7720 controllers is independent from that of the 7700 cabinet, but the same guidelines apply when replacing fans in a controller. Image
Drive Cages
The 7700 appliance cabinet hosts 12 drive cages (6 on each side). Each cage hosts 30 HDDs, 2 SSDs and 2 LCCs. Drives can be hot-swapped. Image
The leaf controller cards (LCCs) are the final SAS fan out to the HDDs that are the leaves in the SAS topology. Each drive cage has 2 LCCs that are load-balanced. In the event of a fault, one LCC provides connectivity to the HDDs. The LCCs can be hot-swapped without shutting down the appliance. If both an LCC and RCC (see below) are being replaced at the same time, replace the RCC first.
Power Supplies
Each 7700 cabinet comes with 6 power supplies near the bottom of the cabinet. The power supplies can be hot-swapped while the system is running. The system controllers also have power supplies. See the 7x20 Overview for more information. Image
The 7700 appliance contains two RCCs that are located between the storage controllers and the drive cages. In the event of an RCC failure, one RCC can provide connectivity to both system controllers and the drive cages. The RCCs are the primary interface to the storage controllers and the root of the SAS topology. The RCCs are hot-swappable, but they must be replaced by a Sun service technician. If both an RCC and one or more LCCs are being replaced at the same time, replace the RCC first. Image
Solid State Drives
All of the drive cages and both system controllers use SSDs as part of the hybrid storage pool, seamlessly adding flash into the storage hierarchy for performance. Slots 30 and 31, if populated, are dedicated to write-optimised SSDs. Zero to 2 SSDs may optionally be present in each cage. Populate all of the drive cages containing LCCs with one SSD in slot 30 before adding a second SSD to any of the cages.
The minimum SSD configuration is four SSDs per base cabinet. Refer to 7420/7720 CPU and Memory components for other storage controller component guidelines.
Internal Components
The following sections contain descriptions of the internal components in the Sun ZFS Storage 7700 appliance. Note: All internal components must be serviced by a Sun Service technician.
Cabling
The internal cables deliver power to the components and plumb the necessary SAS and Ethernet connections between the backplanes, storage controllers and RCCs. All cabling connections are shown in the cabling label on the inside of the cabinet. Failed internal cables must be replaced by a Sun Service technician.
Interface Boards
The 7700 cabinet includes several internal interface boards. There are no CRUs inside the 7700 cabinet, and access to the internal interface boards is limited to Oracle's Sun Service technicians.
See Also
