Skip Navigation Links
Exit Print View
Sun ZFS Storage 7x20 Appliance Customer Service Manual
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Hardware Maintenance
3.  System Maintenance
System
Introduction
System Disks
Support Bundles
Managing Support Bundles Using the BUI
Managing Support Bundles Using the CLI
Initial Setup
Factory Reset
Updates
System Updates
Procedure
Preconditions
Deferred Updates
Hardware Firmware Updates
Reboot After an Update
Rollback
Fail-safe Rollback
Cluster Upgrade
Updating via the BUI
Unpacking and verifying media
Beginning an upgrade
Rolling back
Removing update media
Applying deferred updates
Updating via the CLI
Rolling back
Applying Deferred updates
ConfigurationBackup
Configuration Backup
Backup Contents
Restore Impact
Security Considerations
Managing Configuration Backups Using the BUI
Create a Configuration Backup
Restore from a Saved Configuration
Delete a Saved Configuration
Export a Saved Configuration
Import a Saved Configuration
Managing Configuration Backups Using the CLI
Listing Configurations
Problems
Problems
Active problems display
Repairing problems
Related features
Logs
Introduction
Alerts
Faults
System
Audit
Phone Home
BUI
CLI
Listing logs
Viewing a log
Entry details
Glossary
Index
Problems
Problems
To aid serviceability, the appliance detects persistent hardware failures (faults) and software failures (defects, often included under faults) and reports them as active problems on this screen. If the phone home service is enabled, active problems are automatically reported to Sun Support, where a support case may be opened depending on the service contract and the nature of the fault.
For each problem, the appliance reports what happened, when the problem was detected, the severity and type of the problem, and whether it has been phoned home. Below are some example faults as they would be displayed in the BUI:
Date
Description
Type
Phoned Home
2009-09-16 13:56:36
SMART health-monitoring firmware reported that a disk failure is imminent.
Major Fault
Never
2009-09-05 17:42:55
A disk of a different type (cache, log, or data) was inserted into a slot. The newly inserted device must be of the same type.
Minor Fault
Never
2009-08-21 16:40:37
The ZFS pool has experienced currently unrecoverable I/O failures.
Major Error
Never
2009-07-16 22:03:22
A memory module is experiencing excessive correctable errors affecting large numbers of pages.
Major Fault
Never
This information can also be viewed in the CLI:
gefilte:> maintenance problems show
Problems:
COMPONENT    DIAGNOSED            TYPE            DESCRIPTION
problem-000  2010-7-27 00:02:49   Major Fault     SMART health-monitoring
                                                  failure is imminent on disk
                                                  'HDD 17'.
Selecting any fault shows more information about the fault including the impact to the system, affected components, the system's automated response (if any), and the recommended action for the administrator (if any). In the CLI, only the "uuid", "diagnosed", "severity", "type", and "status" fields are considered stable. Other property values may change from release to release.
For hardware faults, you may be able to select the affected hardware component to locate it on the Hardware screen.
Repairing problems
Problems can be repaired by performing the steps described in the suggested action section. This typically involves replacing the physical component (for hardware faults) or reconfiguring and restarting the affected service (for software defects). Repaired problems no longer appear on this screen.
While the system typically detects repairs automatically, in some cases manual intervention may be required. If a problem persists after the affected components have been repaired, contact support. You may be instructed to mark the problem repaired. This should only be done under the direction of service personnel or as part of a documented Sun repair procedure.
Related features
