Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Geographic Edition System Administration Guide
search filter icon
search icon
Document Information
Preface
1.  Introduction to Administering the Geographic Edition Software
2.  Before You Begin
3.  Administering the Geographic Edition Infrastructure
4.  Administering Access and Security
5.  Administering Cluster Partnerships
6.  Administering Heartbeats
7.  Administering Protection Groups
8.  Monitoring and Validating the Geographic Edition Software
9.  Customizing Switchover and Takeover Actions
10.  Script-Based Plug-Ins
A.  Standard Geographic Edition Properties
B.  Legal Names and Values of Geographic Edition Entities
C.  Disaster Recovery Administration Example
D.  Takeover Postconditions
E.  Troubleshooting Geographic Edition Software
F.  Deployment Example: Replicating Data With MySQL
G.  Error Return Codes for Script-Based Plug-Ins
Index
Preface
Oracle Solaris Cluster Geographic Edition System Administration Guide provides procedures for administering Oracle Solaris Cluster Geographic Edition (Geographic Edition) software. This document is intended for experienced system administrators with extensive knowledge of Oracle software and hardware. This document is not to be used as a planning or presales guide.
The instructions in this book assume knowledge of the Oracle Solaris Operating System, of Oracle Solaris Cluster, and expertise with the volume manager software that is used with Oracle Solaris Cluster software.
Related Documentation
Information about related Geographic Edition topics is available in the documentation that is listed in the following table. All Geographic Edition documentation is available at http://www.oracle.com/technetwork/indexes/documentation/index.html.
Topic
Documentation
Overview
Installation
Data Replication
System administration
For a complete list of Geographic Edition documentation, see Oracle Solaris Cluster Geographic Edition 3.3 5/11 Release Notes.
Topic
Documentation
Concepts
Hardware installation and administration
Oracle Solaris Cluster 3.3 Hardware Administration Manual
Individual hardware administration guides
Software installation
Data service installation and administration
Data service development
Software upgrade
Error messages
Command and function references
Related Third-Party Web Site References
Sun is not responsible for the availability of third-party web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Sun will not be responsible or liable for any actual or alleged damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
Using UNIX Commands
This document contains information about commands that are used to install, configure, or administer an Geographic Edition configuration. This document might not contain complete information on basic UNIX commands and procedures such as shutting down the system, booting the system, and configuring devices.
See one or more of the following sources for this information:
Documentation and Support
See the following web sites for additional resources:
Oracle Software Resources
Oracle Technology Network offers a range of resources related to Oracle software:
Obtaining Help
If you have problems installing or using Geographic Edition software, contact your service provider and provide the following information:
Use the following commands to gather information about each node on your system for your service provider.
Command
Function
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
showrev –p
Reports which patches are installed
prtdiag -v
Displays system diagnostic information
geoadm -V
Displays the Geographic Edition software release information
cluster status
Provides a snapshot of the cluster status
cluster show
Lists cluster configuration information
geoadm status
Displays the Geographic Edition runtime status of the local cluster
Also have available the contents of the /var/adm/messages file.
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
Typeface
Meaning
Example
AaBbCc123
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
What you type, contrasted with onscreen computer output
machine_name% su
Password:
aabbcc123
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
AaBbCc123
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows the default UNIX system prompt and superuser prompt for shells that are included in the Oracle Solaris OS. Note that the default system prompt that is displayed in command examples varies, depending on the Oracle Solaris release.
Table P-2 Shell Prompts
Shell
Prompt
Bash shell, Korn shell, and Bourne shell
Bash shell, Korn shell, and Bourne shell for superuser
C shell
machine_name%
C shell for superuser
machine_name#
