Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Geographic Edition 3.3 5/11 Release Notes
search filter icon
search icon
Document Information
Preface
New Features and Functionality
HA for Oracle with Oracle Data Guard Replication
Three-Data-Center (3DC) Configuration
ZFS Storage Pools
Accessibility Information
Supported Products
Data Replication
Oracle Solaris Cluster Software
Volume Management Software
Restrictions
Support for EMC Symmetrix Remote Data Facility Configurations
Oracle 9i
Commands Modified in This Release
Known Issues and Bugs
Depending on the Order in Which Zone Cluster Setup and Geographic Edition Software Installation Is Done, Some Files Might Not Get Copied to the Zone (6968002)
geo-failovercontrol Resource Fails to Start on Second Node if Connection Lost to Primary Node (6932775)
Required Patches
Oracle Solaris Cluster Geographic Edition 3.3 5/11 Documentation
Documentation Addendum
Switchover Cannot Be Performed with Asynchronous SRDF (6389092)
Supported Products
This section lists the software products and versions that are supported by Geographic Edition software.
Data Replication
Oracle Solaris Cluster Geographic Edition 3.3 5/11 supports the same versions of the Oracle Solaris OS as the cluster software version you use. See the release notes for your version of cluster software for the supported versions of the Oracle Solaris OS.
The following table lists the volume managers that are supported in this release for each data replication software product.
Data Replication Software
Supported Volume Managers
Veritas Volume Manager
Hitachi TrueCopy
Hitachi Universal Replicator
Oracle Data Guard1
Oracle Automatic Storage Management
Solaris Volume Manager for Sun Cluster
Sun Availability Suite 4
1For information about additional supported storage management options, see Storage Management Requirements for Oracle Files in Oracle Solaris Cluster Data Service for Oracle Real Application Clusters Guide.
