Skip Navigation Links
Exit Print View
SPARC T4-1 Server
Product Notes
search filter icon
search icon
Document Information
Using This Documentation
1.  Late Breaking Information
Preinstalled Software
Supported Versions of Oracle Solaris OS, Firmware, and Software
OS Package and Patch Updates
Determining Oracle Solaris 11 OS Package Update Version
Determining Oracle Solaris 10 Patch Revision
Minimum Required Patchset for Oracle Solaris 10 8/11 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 9/10 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 10/09 OS
Installing and Booting Oracle Solaris 11 From Devices Connected to a USB Port
Support for new 16 Gbyte and 32 Gbyte DIMMs
Rules for I/O Slot Use by Certain Cards
2.  Known Product Issues
Hardware Issues
Maximizing Memory Bandwidth
Direct I/O Support
Use Links Labeled SPARC T3 to Download sas2ircu Firmware and Documentation for SPARC T4 Servers
Sun Type 6 Keyboards Are Not Supported By SPARC T4 Series Servers
Caution Needed When Removing a SATA Data Cable From a Backplane Connector
Caution Needed When Handling the Connector Board
Server Panics When Booting From a USB Thumbdrive Attached to the Front USB Ports (Bug ID 15667682)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (Bug ID 15705327, Bug ID 15713018)
PCIe Correctable Errors Might Be Reported (Bug ID 15720000, Bug ID 15722832)
SPARC T3 and T4 Platforms Might See Dropped or Doubled Character Input From USB Keyboards (Bug ID 15700526, Bug ID 15728507)
L2 Cache UEs Are Sometimes Reported as Core Faults Without Any Cache Line Retirements (Bug ID 15731176)
Upon a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (Bug ID 15733431)
reset /SYS Operations Can Cause the SAS Controller to Disappear (Bug ID 15737475)
SAS Command Might Fail to Complete When Certain SAS Devices Are Put Under Heavy Load (Bug ID 15802084)
Rebooting an SDIO-SAS HBA Guest Domain Might Generate ereport.io.pciex.pl.re (Bug ID 15718101)
Characters Are Occasionally Dropped at the Oracle OpenBoot Prompt (Bug ID15813690)
Oracle Solaris OS Issues
When a Start Address Is Not Aligned With the Largest Page Size, the OS Should Use the Next Available Page Size (Bug ID 15718159)
Cannot Boot Oracle Solaris 10 10/09 OS (U8) From the Internal DVD
Spurious Interrupt Message in System Console (Bug ID 15651697, Bug ID 15771956, Bug ID 15771958)
Spurious Error Message During Initial Oracle Solaris 10 OS Installation (Bug ID 15658412)
When diag-switch? is Set to true, Oracle Solaris OS Fails to Update EEPROM for Automatic Rebooting (Bug ID 15666767)
Memory Allocation Issues With Emulex 8Gb HBAs In a Magma IO Expansion Box (Bug ID 15666779)
Fault Management Sometimes Sends Resolved Cases to the SP (Bug ID 15667874, Bug ID 15741999)
Gigabit Ethernet (nxge) Driver Not Loading on Systems With Oracle Solaris 10 10/09 OS and a Solaris 10 9/10 Patchset or Solaris 10 8/11 Patchset (Bug ID 15677751)
The trapstat -T Command Causes Bad Watchdog Resets at TL2 (Bug ID 15720390)
Watchdog Timeouts Seen With Heavy Workloads and Maximum Memory Configurations (Bug ID 15737671, Bug ID 15744469, Bug ID 15771943)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (Bug ID 15738845, Bug ID 15742069)
Benign Error Message: mptsas request inquiry page 0x83 for target:a, lun:0 failed! (Bug ID 15809005)
Oracle VTS dtlbtest hangs when the CPU Threading Mode is Set to max-ipc (Bug ID 15743740, Bug ID 15744945)
Some pciex8086,105f Devices Fail to Attach (Bug ID 15774699)
L2 Cache Uncorrectable Errors Causing a Reboot Abort (Bug ID 15826320)
Firmware Issues
Performing First-Time Boot On Servers Equipped With the Sun Storage 6 Gb SAS PCIe 8-Port Internal RAID HBA
Cold Reset Adds One Day to System Time (CR 15764743, Bug ID 15765255, Bug ID 15765770)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be Off by One Hour (Bug ID 15802097)
Missing Interrupt Causes USB Hub Hotplug Thread to Hang, Resulting In Process Hangs (Bug ID 15655752)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (Bug ID 15675720)
Message From cpustat Refers to Processor Documentation Incorrectly (Bug ID 15717099, Bug ID 15717100, Bug ID 15749141)
reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (Bug ID 15816272)
Explicit Processor Binding Might Block Strand Retirement (Bug ID 15733312)
Blue OK-to-Remove LED On Drive Does Not Light When The Drive Is Ready To Remove (Bug ID 15737491)
In Some Instances, a PCIe Card Might Disappear From the Device Tree Upon Reboot or During Power-On (Bug ID 15849720)
System Firmware 8.2.0 Contains a New Version of the scvar Database (Bug ID 16184046)
System Firmware 8.3.0.b Incompatible with the Sun Flash Accelerator F40 PCIe Card (Bug ID 16813726)
Documentation Issues
Note - You should install the latest patches or package updates available for the version of the Oracle Solaris OS installed on your system.
Updates to Oracle Solaris 11 are provisioned using package updates called Support Repository Updates (SRUs) instead of patches. SRUs are part of a new OS provisioning scheme called the Image Packaging System (IPS).
To determine the package version of the Oracle Solaris 11 OS installed on your system, run the pkg info kernel command and then interpret the FMRI value displayed in the output. This is an example:
# pkg info kernel
       Summary: Core Kernel
   Description: Core operating system kernel, device drivers and other modules.
      Category: System/Core
         State: Installed
     Publisher: solaris
       Version: 0.5.11
 Build Release: 5.11
        Branch: 0.175.0.2.0.2.1
Packaging Date: Wed Oct 19 07:57:11 2011
          FMRI: pkg://solaris/system/kernel@0.5.11,5.11-0.175.0.2.0.2.1:
                  20111128T20503
Then evaluate the following three fields in the FMRI value:
You can ignore the other fields in the FMRI package description.
When you know which version of the OS is installed, you can access a list of all the packages contained in that release from the following web page:
http://pkg.oracle.com/solaris/release/en/index.shtml
To list the packages contained in a particular Oracle Solaris 11 release, select that release in the Release and Branch pull-down menu and press the Browse button. Or you can search for individual packages in the Search for: window.
If your system is currently running Oracle Solaris 10, you can find its patch level with the commands showrev(1M) and uname(1). This is shown in the following example:
# showrev
Hostname: *********
Host id: *********
Release: 5.10
Kernel architecture: sun4v
Application architecture: sparc
Hardware provider: Sun_Microsystems
Domain: Ecd.East.Sun.COM
Kernel version SunOS 5.10 Generic_142909-17
# uname -a
SunOS ********* Generic_142909-17 sun4v sparc sun4v
# showrev -p | tail -3
Patch: 143525-01 Obsoletes: Requires: 118833-36, 127127-11 Incompatibles:
    Packages:SUNWcsu
Patch: 143125-01 Obsoletes: 138079-01 138089-01 Requires: 120011-14
    Incompatibles: Packages: SUNWcsu
Patch: 121557-01 Obsoletes: Requires: Incompatibles: Packages: SUNWpiclu
Install the patches listed in Minimum Required Patchset for Oracle Solaris 10 8/11 before using the server with the Oracle Solaris 10 8/11 OS.
Table 1-3 Minimum Required Patchset for Oracle Solaris 10 8/11
147440-03
147149-01
147153-01
147707-01
147159-03
In addition, you should download and install “Recommended OS Patchset Solaris 10 SPARC”. This patchset contains Oracle Solaris 10 OS patches that address current Sun Alerts.
Note - The download of the Solaris 10 8/11 SPARC Bundle is identified by the number 14158708 at http://support.oracle.com.
To use the server with the Oracle Solaris 10 9/10 OS, install the patches listed in Minimum Required Patchset for Oracle Solaris 10 8/11, as well as the Oracle Solaris 10 8/11 SPARC Bundle. In addition, you should download and install “Recommended OS Patchset Solaris 10 SPARC”. This patchset contains Oracle Solaris 10 OS patches that address current Sun Alerts.
Note - The download of the Solaris 10 9/10 SPARC Bundle is identified by the number 13153809 at http://support.oracle.com.
To use the server with the Oracle Solaris 10 10/09 OS, install the patches listed in Minimum Required Patchset for Oracle Solaris 10 8/11, as well as the Oracle Solaris 10 8/11 SPARC Bundle. In addition, you should download and install “Recommended OS Patchset Solaris 10 SPARC”. This patchset contains Oracle Solaris 10 OS patches that address current Sun Alerts.
Note - The download of the Solaris 10 9/10 SPARC Bundle is available at http://support.oracle.com.
