Confirming Server and Site Specifications
Install Mounting Brackets on Server
Attach Slide Rail Assemblies to Rack
Connecting Data and Management Cables
Secure Cables to CMA (Optional)
Powering On the Server for the First Time
Connect a Terminal or Emulator to the SER MGT Port
Power On the System for the First Time
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Understanding System Administration Resources
Platform-Specific Oracle ILOM Features
Oracle VM Server for SPARC Overview
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Display the Oracle ILOM -> Prompt
Power On the Server (Oracle ILOM)
Power Off the Server (Oracle ILOM)
Reset the Server (Oracle Solaris OS)
Reset the Server (Oracle ILOM)
Reset the SP to Default Values
Important Hardware RAID Guidelines
Prepare to Use the FCode Utility
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
RAID Drive Replacement Strategies
Changing Server Identification Information
Change Customer Data on FRU PROMs
Change System Identifier Information
Restore the Host Power State at Restart
Specify the Host Power State at Restart
Disable or Re-Enable the Host Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior (Keyswitch State)
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the IP Address of the SP
Using an In-band Connection to the SP
Configure the Host Boot Mode (Oracle VM Server for SPARC)
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OBP Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Enabling Automatic System Recovery
Identifying WWN-Designated SAS2 Devices
Mapping WWN Values to Hard Drives (OBP probe-scsi-all Command)
Identify a Disk Slot Using prtconf (Oracle Solaris OS)
WWN Syntax in an OS Installation on an Individual Drive
WWN Syntax in an OS Installation on a RAID Volume
Infrastructure Boards in the Server
Front and Rear Panel System Controls and LEDs
Ethernet and Network Management Port LEDs
Oracle ILOM Troubleshooting Overview
Display FRU Information (show Command)
Check for Faults (show faulty Command)
Check for Faults (fmadm faulty Command)
Clear Faults (clear_fault_action Property)
Service-Related Oracle ILOM Commands
Interpreting Log Files and System Messages
Checking if Oracle VTS Is Installed
Check if Oracle VTS Software Is Installed
Oracle ILOM Properties that Affect POST Behavior
Understanding Component Replacement Categories
Removing Power From the Server
Positioning the System for Servicing
Attaching Devices to the Server
Verify Fan Module Functionality
Verify Power Supply Functionality
Servicing Memory Risers and DIMMs
Locate a Faulty DIMM (DIMM Fault Remind Button)
Locate a Faulty DIMM (show faulty Command)
Increase Server Memory With Additional DIMMs
Increase Server Memory with Additional DIMMs (16 Gbyte Configurations)
Remove a Memory Riser Filler Panel
Install a Memory Riser Filler Panel
DIMM Configuration Error Messages
Remove a DVD Drive or Filler Panel
Install a DVD Drive or Filler Panel
Servicing the System Lithium Battery
Servicing Expansion (PCIe) Cards
Remove a PCIe Card Filler Panel
Cable an Internal SAS HBA PCIe Card
Install a PCIe Card Filler Panel
Verify Fan Board Functionality
Verify Motherboard Functionality
Verify Drive Backplane Functionality
Servicing the Power Supply Backplane
Remove the Power Supply Backplane
Install the Power Supply Backplane
Verify Power Supply Backplane Functionality
Return the Server to the Normal Rack Position
When no faults have been detected, the show fault output looks like this:
-> show faulty Target | Property | Value --------------------+------------------------+------------------- -----------------------------------------------------------------
Other examples are shown in the following sections.
The following is an example of the show faulty command reporting a power supply fault.
Note - The characters “SPT” at the beginning of the message ID indicate that the fault was detected by Oracle ILOM.
-> show faulty Target | Property | Value --------------------+------------------------+------------------------------- /SP/faultmgmt/0 | fru | /SYS/PS0 /SP/faultmgmt/0/ | class | fault.chassis.power.volt-fail faults/0 | | /SP/faultmgmt/0/ | sunw-msg-id | SPT-8000-LC faults/0 | | /SP/faultmgmt/0/ | uuid | ********-****-****-****-************ faults/0 | | /SP/faultmgmt/0/ | timestamp | 2010-08-11/14:54:23 faults/0 | | /SP/faultmgmt/0/ | fru_part_number | ******* faults/0 | | /SP/faultmgmt/0/ | fru_serial_number | ****** faults/0 | | /SP/faultmgmt/0/ | product_serial_number | ********** faults/0 | | /SP/faultmgmt/0/ | chassis_serial_number | ********** faults/0 | | /SP/faultmgmt/0/ | detector | /SYS/PS0/VOLT_FAULT faults/0 | |
The following is an example of the fmadm faulty command reporting on the same power supply fault as shown in the show faulty example. Note that the two examples show the same UUID value.
The fmadm faulty command was invoked from within the ILOM faultmgmt shell.
-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y faultmgmtsp> fmadm faulty ------------------- ------------------------------------ -------------- ------- Time UUID msgid Severity ------------------- ------------------------------------ -------------- ------- 2010-08-11/14:54:23 ********-****-****-****-************ SPT-8000-LC Critical Fault class : fault.chassis.power.volt-fail Description : A Power Supply voltage level has exceeded acceptible limits. Response : The service required LED on the chassis and on the affected Power Supply may be illuminated. Impact : Server will be powered down when there are insufficient operational power supplies Action : The administrator should review the ILOM event log for additional information pertaining to this diagnosis. Please refer to the Details section of the Knowledge Article for additional information. faultmgmtsp> exit
The following is an example of the show faulty command displaying a fault that was detected by POST. These kinds of faults are identified by the message Forced fail reason, where reason is the name of the power-on routine that detected the fault.
-> show faulty Target | Property | Value -------------------+------------------------+-------------------------------- /SP/faultmgmt/0 | fru | /SYS/MB /SP/faultmgmt/0 | class | fault.component.disabled faults/0 | | /SP/faultmgmt/0/ | sunw-msg-id | SPT-8000-HR faults/0 | | /SP/faultmgmt/0/ | uuid | ******************************** faults/0 | | a262 /SP/faultmgmt/0/ | timestamp | 2010-09-03/11:21:17 faults/0 | | /SP/faultmgmt/0/ | detector | /SYS/MB/CMP0/NIU1 faults/0 | | /SP/faultmgmt/0/ | fru_part_number | 541-3857-04 faults/0 | | /SP/faultmgmt/0/ | fru_serial_number | ****************** faults/0 | | /SP/faultmgmt/0/ | product_serial_number | ********** faults/0 | | /SP/faultmgmt/0/ | chassis_serial_number | ********** faults/0 | |
The following is an example of the show faulty command displaying a fault that was detected by the PSH technology. These kinds of faults are identified by the absence of the characters “SPT” at the beginning of the message ID.
-> show faulty Target | Property | Value --------------------+------------------------+-------------------------------- /SP/faultmgmt/0 | fru | /SYS/MB /SP/faultmgmt/0/ | class | fault.cpu.generic-sparc.strand faults/0 | | /SP/faultmgmt/0/ | sunw-msg-id | SUN4V-8002-6E faults/0 | | /SP/faultmgmt/0/ | uuid | ********-****-****-****-************ faults/0 | | 7a8a /SP/faultmgmt/0/ | timestamp | 2010-08-13/15:48:33 faults/0 | | /SP/faultmgmt/0/ | chassis_serial_number | ********** faults/0 | | /SP/faultmgmt/0/ | product_serial_number | ********** faults/0 | | /SP/faultmgmt/0/ | fru_serial_number | *******-********** faults/0 | | /SP/faultmgmt/0/ | fru_part_number | 541-3857-07 faults/0 | | /SP/faultmgmt/0/ | mod-version | 1.16 faults/0 | | /SP/faultmgmt/0/ | mod-name | eft faults/0 | | /SP/faultmgmt/0/ | fault_diagnosis | /HOST faults/0 | | /SP/faultmgmt/0/ | severity | Major faults/0 | |
