| Skip Navigation Links | |
| Exit Print View | |
Sun Server X3-2L (formerly Sun Fire X4270 M3) Product Notes, Version 1.2 |
Getting the Latest Software and Firmware
Sun Server X3-2L Product Notes
Single-Processor to Dual-Processor Upgrade Is Not Supported
Update Your System to the Latest Software Release
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Supported Operating System Limitations
Update HBA Firmware to Support UEFI BIOS
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Failure of a Single Server Fan Module Might Impact Performance
MAC Address Mapping to Ethernet Ports
Rear-Mounted HDD Naming When Using Oracle Solaris
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing HDDs
Oracle System Assistant Known Issues
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
If you use the Oracle VM Server software that is preinstalled on your system, you must ensure that it is compatible with the version of Oracle VM Manager that you use to manage your Oracle VM infrastructure. If necessary to achieve compatibility, upgrade your Oracle VM Server or Oracle VM Manager so that they are the same version.
For information about upgrading the Oracle VM software, see the Oracle VM Installation and Upgrade Guide. The Oracle VM documentation is available at the following web site: http://www.oracle.com/technetwork/documentation/vm-096300.html
