Sun Server X3-2L (formerly Sun Fire X4270 M3) Product Notes Version 1.4.4
Exit Print View
Updated: April 2016
Update Your System to the Latest Software Release
It is highly recommended that you update your system to the latest software release before you use the system. Software releases often include bug fixes, and updating ensures that your server software is compatible with the latest server firmware and other component firmware and software.
You can get the latest available system BIOS, Oracle ILOM, firmware, and drivers from Oracle by performing the Get Updates task in Oracle System Assistant. An Internet connection is required. For instructions on how to use the Get Updates task, see “Get Updates for a New Platform Software Release” in the Sun Server X3-2L Administration Guide.
You also can download the latest firmware and software updates from My Oracle Support at http://support.oracle.com. For information about downloading firmware and software from My Oracle Support, see Getting Server Firmware and Software.
