Skip Navigation Links
Exit Print View
Sun Server X3-2L HTML Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Support and Accessibility
Site Planning
Preparing the Site for Installation
Server Specifications
Preparing the Facility
Installation
About the Installation Procedure
Installation Procedure Overview
About Server Features and Components
Server Components
UEFI BIOS
Front Panel Status Indicators, Connectors, and Drives
Back Panel Status Indicators, Connectors, Drives, and PCIe Slots
Server Management Software Overview
Preparing for Server Installation
Shipping Inventory
Optional Component Installation
Tools and Equipment Needed for Installation
ESD and Safety Precautions
Installing the Server Into a Rack
Installation Prerequisites
Rack Requirements
Safety Precautions When Rackmounting the Server
Rackmount Kit Contents
Stabilize the Rack for Installation
Install Mounting Brackets
Mark the Rackmount Location
Attach Tool-less Slide-Rail Assemblies
Install the Server Into the Slide-Rail Assemblies
Install the Second-Generation Cable Management Arm
Remove the Second-Generation Cable Management Arm
Install the First-Generation Cable Management Arm
Verify Operation of Slide-Rails and CMA
Cabling the Server
Rear Cable Connections and Ports
Ethernet Ports
Attaching Data Cables and Power Cords to the Server
Connecting to Oracle ILOM
Oracle ILOM Hardware and Interfaces
Network Defaults
Logging In to Oracle ILOM Using a Local Serial Connection
Logging In to Oracle ILOM Using a Remote Ethernet Connection
Accessing the Host Console Through Oracle ILOM
Troubleshooting the Service Processor Connection
Setting Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware
Setting Up an Operating System and Drivers
Configuring Server Drives for OS Installation
RAID Configuration Tools
RAID Configuration Requirements
Configuring Storage Drives Into RAID Volumes Using Oracle System Assistant
Configuring RAID Using the BIOS RAID Configuration Utilities
Configuring the Preinstalled Oracle Solaris 11 Operating System
Preinstalled Operating System RAID Limitations
Operating System Options
Oracle Solaris Configuration Worksheet
Configure the Preinstalled Oracle Solaris 11 Operating System
Oracle Solaris 11 Operating System Documentation
Configuring the Preinstalled Oracle Linux Operating System
Oracle Linux Configuration Worksheet
Configure the Preinstalled Oracle Linux Operating System
Register and Update Your Linux OS
Oracle Linux Operating System Documentation
Configuring the Preinstalled Oracle VM 3.x Software
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Oracle VM Server Configuration Worksheet
Configure the Preinstalled Oracle VM
Oracle VM Documentation
Controlling System Power and Troubleshooting Installation Issues
Power Off the Server for Orderly Shutdown
Power Off the Server for Immediate Shutdown
Reset the Server
Installation Troubleshooting
Technical Support Information Worksheet
Locating the System Serial Number
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Software Releases
Accessing Firmware and Software
Installing Updates Using Other Methods
Oracle Solaris Installation
About Oracle Solaris Operating System Installs
Oracle Solaris OS Installation Task Map
Supported Operating Systems
Selecting the Console Display Option
Selecting the Boot Media Option
Selecting the Installation Target Option
Solaris OS Installation Options
Preparing to Install the Operating System
Setting Up BIOS
Configuring RAID
Installing the Oracle Solaris Operating System
Before You Begin
Installing the Oracle Solaris 10 or 11 Operating System on a Single System Using Media
Software Releases
Oracle VM Installation
About Oracle VM Installs
Oracle VM Installation Task Map
Supported Oracle VM Software
Oracle VM Installation Options
Preparing to Install Oracle VM
Verify the BIOS Factory Defaults
Configuring RAID
Installing Oracle VM
Before You Begin
Installing Oracle VM on a Single System Using Oracle System Assistant
Installing Oracle VM on a Single System Using Media
Post Installation Tasks for Oracle VM
Configuring Network Interfaces
NIC Connectors
Software Releases
Linux Installation
About Linux Operating System Installs
Supported Linux Operating Systems
Oracle Unbreakable Enterprise Kernel for Linux
Linux OS Installation Options
Setting Up BIOS
Configuring the SLES 11 SP1 Operating System Software to Support Network Connections
Configuring RAID
Installing the Linux Operating System
Installing a Linux OS on a Single System Using Oracle System Assistant
Installing Oracle Linux on a Single System Using Media
Installing Red Hat Enterprise Linux on a Single System Using Media
Installing SUSE Linux Enterprise Server on a Single System Using Media
NIC Connectors
Software Releases
Windows Installation
About Windows Server 2008 Operating System Installs
Windows OS Installation Task Map
Supported Windows Operating Systems
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
Setting Up BIOS
Configuring RAID
Installing the Windows Server 2008
Before You Begin
Installing Windows OS on a Single System Using Oracle System Assistant
Installing Windows Server 2008 on a Single System Using Media
Post Installation Tasks for Windows Server 2008
Supplemental Software Component Options
Installing Device Drivers and Supplemental Software
Configuring Intel NIC Teaming
Software Releases
VMware ESXi Installation
About VMware ESXi Installs
VMware ESXi Installation Task Map
Supported VMware ESXi Software
VMware ESXi Installation Options
Preparing to Install VMware ESXi
Setting Up BIOS
Configuring the VMware ESXi 5.0 Software or the Server Hardware to Support Network Connections
Configuring RAID
Installing VMware ESXi
Before You Begin
Installing VMware ESXi on a Single System Using Media
Post Installation Tasks for VMware ESXi
Configure Network Adapter Settings
Determine the MAC Address of a Connected Server Network Port
Update the VMware ESXi Software
Manage VMware ESXi Resources
NIC Connectors
Software Releases
Service
About the Sun Server X3-2L
Product Description
About Controls and Connectors
About Server and Component LEDs
About System Components
Troubleshooting the Server
Service Troubleshooting Task List
Diagnostic Tools
Gather Service Information
Locate the Server Serial Number
Inspecting the System
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
Required Tools
Preparing the Server for Component Replacement
Servicing CRUs That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives (CRU)
Servicing Fan Modules (CRU)
Servicing Power Supplies (CRU)
Servicing CRUs That Require Server Power-Off
Servicing the DIMMs (CRU)
DIMM and Processor Physical Layout
DIMM Population Example for Optimal System Performance
DIMM Population Rules
DIMM Rank Classification Labels
Inconsistencies Between DIMM Fault LEDs and the BIOS Isolation of Faulty DIMMs
Using the Fault Remind Button
Remove Faulty DIMMs
Install DDR3 DIMMs
Servicing PCIe Cards (CRU)
PCIe Slot Locations
Remove a PCIe Card
Install a PCIe Card
Servicing the SAS Expander Module (CRU)
Remove the SAS Expander Module
Install the SAS Expander Module
Servicing the Air Baffle (CRU)
Remove the Air Baffle
Install the Air Baffle
Servicing the DVD Drive (CRU)
Remove the DVD Drive
Install the DVD Drive
Servicing the Internal USB Flash Drives (CRU)
Remove an Internal USB Flash Drive
Install an Internal USB Flash Drive
Servicing the Battery (CRU)
Remove the Battery
Install the Battery
Servicing FRUs
Servicing Processors (FRU)
Servicing the Front and Rear Storage Drive Backplanes (FRU)
Servicing the Front LED/USB Indicator Modules (FRU)
Servicing Cables (FRU)
Servicing the Motherboard Assembly (FRU)
Identifying the Server Ports
Gigabit-Ethernet Ports
Network Management Port
Serial Management Port
Video Connector
USB Ports
Server Filler Panel Requirements
Remove and Install Filler Panels
Install the Top Cover
Install the Fan Assembly Door
Remove Antistatic Measures
Reinstall the Server Chassis in the Rack
Reconnect Power and Data Cables
Power On the Server
Software Releases
Administration
Planning the System Management Environment
Choosing Tools for Single System Management
Choosing Tools for Multiple System Management
System Management Tools Overview
Common System Management Tasks
Common System Administrative Tasks
Evaluating the Server Environment
Installing System Management Tools
System Management Documentation
Accessing System Management Tools
Accessing Oracle System Assistant
Accessing Oracle ILOM
Accessing Oracle Hardware Management Pack
Set Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware Using Oracle ILOM
Set Up Software and Firmware Using Oracle Hardware Management Pack
Setting Up the Server Using Oracle System Assistant
Organization of Oracle System Assistant
Configuring the Server Using Oracle System Assistant
Mounting the Oracle System Assistant USB Flash Drive
Troubleshooting Oracle System Assistant
Accessing the Oracle System Assistant Filesystem
Managing the Server Using Oracle ILOM
Oracle ILOM Features
Oracle ILOM Features for Oracle x86 Servers
Configuring RAID
Supported HBA Disk Controllers
RAID Configuration Options
Creating a RAID Volume Before Installing an Operating System
Creating a RAID Volume After Installing an Operating System
Using Oracle ILOM to Monitor Storage Devices
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
Using Legacy or UEFI BIOS
Using BIOS for Resource Allocation
Common BIOS Setup Utility Tasks
BIOS Setup Utility Menu Options
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS IO Menu Selections
BIOS Boot Menu Selections
UEFI Driver Control Menu Selections
BIOS Save & Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Monitoring System Components
Identifying SNMP Trap Messages
Software Releases
Index
This section provides an example of how to populate the DIMMs to achieve optimal system performance.
Note - Not all possible configurations are shown here.
The following figure shows the order in which the DIMMs should be populated on a dual-processor system. On a single-processor system, you should follow the same order except that you should only install DIMMs in the DIMM sockets for processor 0 (P0). On a single-processor system, a DIMM filler panel must always be installed in processor 1 (P1) DIMM socket D7.
Figure 56 DIMM Population Example
image:Figure showing the DIMM population order.
For more information on populating the DIMMs, see the following topics:
DIMM Population Order for Single-processor Systems
For single-processor systems, DIMMs should only be installed into DIMM sockets associated processor 0 (P0) starting with P0 D0, first filling the blue sockets and then the white. This DIMM population order is illustrated in DIMM Population Example.
The following table describes the order in which the DIMMs should be populated on a single-processor system. The figure callouts in column two of the table refer to the callouts in DIMM Population Example.
Table 18 DIMM Population Order for Single-processor Systems
Population Order
Figure Callouts
DIMMs Sockets for Processor 0 (P0)
Fill the blue sockets first
First
1
D0
Second
3
D2
Third
5
D5
Fourth
7
D7
Then fill the white sockets
Fifth
9
D1
Sixth
11
D3
Seventh
13
D4
Eighth
15
D6
DIMM Population Order for Dual-processor Systems
For dual-processor systems, DIMMs should be installed into DIMM sockets starting with P0 D0 and alternating back and forth between P0 and the matching socket on P1, first filling the blue sockets and then the white. This DIMM population order is illustrated in DIMM Population Example.
The following table describes the order in which the DIMMs should be populated on a dual-processor system. The figure callouts in columns two and four of the table refer to callouts in DIMM Population Example.
Table 19 DIMM Population Order for Dual-processor Systems
Population Order
Figure Callouts
Figure Callouts
DIMMs Sockets for Processor 1 (P1)
First
1
Fill D0 first
2
Then D0
Second
3
Fill D2 first
4
Then D2
Third
5
Fill D5 first
6
Then D5
Fourth
7
Fill D7 first
8
Then D7
Fifth
9
Fill D1 first
10
Then D1
Sixth
11
Fill D3 first
12
Then D3
Seventh
13
Fill D4 first
14
Then D4
Eighth
15
Fill D6 first
16
Then D6
