Getting the Latest Software and Firmware
Preparing the Site for Installation
About the Installation Procedure
Installation Procedure Overview
About Server Features and Components
Front Panel Status Indicators, Connectors, and Drives
Back Panel Status Indicators, Connectors, Drives, and PCIe Slots
Preparing for Server Installation
Optional Component Installation
Tools and Equipment Needed for Installation
Installing the Server Into a Rack
Safety Precautions When Rackmounting the Server
Stabilize the Rack for Installation
Attach Tool-less Slide-Rail Assemblies
Install the Server Into the Slide-Rail Assemblies
Install the Second-Generation Cable Management Arm
Remove the Second-Generation Cable Management Arm
Install the First-Generation Cable Management Arm
Verify Operation of Slide-Rails and CMA
Rear Cable Connections and Ports
Attaching Data Cables and Power Cords to the Server
Oracle ILOM Hardware and Interfaces
Logging In to Oracle ILOM Using a Local Serial Connection
Logging In to Oracle ILOM Using a Remote Ethernet Connection
Accessing the Host Console Through Oracle ILOM
Troubleshooting the Service Processor Connection
Setting Up Software and Firmware Using Oracle System Assistant
Setting Up an Operating System and Drivers
RAID Configuration Requirements
Configuring Server Storage Drives Into RAID Volumes Using Oracle System Assistant
Configuring RAID Using the BIOS Setup Utility
Configuring the Preinstalled Oracle Solaris 11 Operating System
Preinstalled Operating System RAID Limitations
Configure the Preinstalled Oracle Solaris 11 Operating System
Oracle Solaris 11 Operating System Documentation
Configuring the Preinstalled Oracle Linux Operating System
Oracle Linux Configuration Worksheet
Configure the Preinstalled Oracle Linux Operating System
Register and Update Your Linux OS
Configuring the Preinstalled Oracle VM 3.x Software
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Configure the Preinstalled Oracle VM
Troubleshooting Installation Issues
Power Off the Server for Orderly Shutdown
Power Off the Server for Immediate Shutdown
Technical Support Information Worksheet
Locating the System Serial Number
Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
About Oracle Solaris Operating System Installs
Oracle Solaris OS Installation Task Map
Selecting the Console Display Option
Selecting the Boot Media Option
Selecting the Installation Target Option
Solaris OS Installation Options
Preparing to Install the Operating System
Installing the Oracle Solaris Operating System
Installing the Oracle Solaris 10 or 11 Operating System on a Single System Using Media
Oracle VM Installation Task Map
Oracle VM Installation Options
Preparing to Install Oracle VM
Verify the BIOS Factory Defaults
Installing Oracle VM on a Single System Using Oracle System Assistant
Installing Oracle VM on a Single System Using Media
Post Installation Tasks for Oracle VM
Configuring Network Interfaces
About Linux Operating System Installs
Supported Linux Operating Systems
Oracle Unbreakable Enterprise Kernel for Linux
Configuring the SLES 11 SP1 Operating System Software to Support Network Connections
Installing the Linux Operating System
Installing a Linux OS on a Single System Using Oracle System Assistant
Install a Linux OS Using Oracle System Assistant
Installing Oracle Linux on a Single System Using Media
Oracle Linux OS Installation Task Map
Install Oracle Linux 5.7 or 5.8 Using Local or Remote Media
Install Oracle Linux 6.1, 6.2, or 6.3 Using Local or Remote Media
Install Oracle Linux 5.7, 5.8, 6.1, 6.2, or 6.3 Using PXE Network Boot
Post Installation Tasks for Oracle Linux
Register Oracle Linux and Activate Automatic Updates
Install Oracle Unbreakable Enterprise Kernel Release 2 for Linux
Installing Red Hat Enterprise Linux on a Single System Using Media
Install RHEL 5.7 or 5.8 Using Local or Remote Media
Install RHEL 6.1, 6.2, or 6.3 Using Local or Remote Media
Install RHEL 5.7, 5.8, 6.1, 6.2, or 6.3 Using PXE Network Boot
Post Installation Tasks for RHEL
Register RHEL and Activate Automatic Updates
Installing SUSE Linux Enterprise Server on a Single System Using Media
SLES 11 SP1 and SP2 Installation Task Map
Installing SLES 11 SP1 or SP2 Using Local or Remote Media
Install SLES 11 SP1 or SP2 Using Local or Remote Media
Installing SLES 11 SP1 or SP2 Using a PXE Network Environment
Install SLES 11 SP1 or SP2 Using PXE Network Boot
Post Installation Tasks for SLES 11 SP1 or SP2
Update the SLES Operating System
About Windows Server 2008 Operating System Installs
Windows OS Installation Task Map
Supported Windows Operating Systems
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
Installing the Windows Server 2008
Installing Windows OS on a Single System Using Oracle System Assistant
Installing Windows Server 2008 on a Single System Using Media
Post Installation Tasks for Windows Server 2008
Supplemental Software Component Options
Installing Device Drivers and Supplemental Software
VMware ESXi Installation Task Map
Supported VMware ESXi Software
VMware ESXi Installation Options
Preparing to Install VMware ESXi
Configuring the VMware ESXi 5.0 Software or the Server Hardware to Support Network Connections
Installing VMware ESXi on a Single System Using Media
Post Installation Tasks for VMware ESXi
Configure Network Adapter Settings
Determine the MAC Address of a Connected Server Network Port
Update the VMware ESXi Software
About Server and Component LEDs
Service Troubleshooting Task List
Locate the Server Serial Number
Electrostatic Discharge Safety
Preparing the Server for Component Replacement
Servicing CRUs That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives (CRU)
Servicing Power Supplies (CRU)
Servicing CRUs That Require Server Power-Off
Servicing the SAS Expander Module (CRU)
Servicing the Air Baffle (CRU)
Servicing the Internal USB Flash Drives (CRU)
Servicing the Front and Rear Storage Drive Backplanes (FRU)
Servicing the Front LED/USB Indicator Modules (FRU)
Servicing the Motherboard Assembly (FRU)
Server Filler Panel Requirements
Remove and Install Filler Panels
Reinstall the Server Chassis in the Rack
Reconnect Power and Data Cables
Planning the System Management Environment
Choosing Tools for Single System Management
Choosing Tools for Multiple System Management
System Management Tools Overview
Common System Management Tasks
Common System Administrative Tasks
Evaluating the Server Environment
Installing System Management Tools
System Management Documentation
Accessing System Management Tools
Accessing Oracle System Assistant
Accessing Oracle Hardware Management Pack
Set Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware Using Oracle ILOM
Set Up Software and Firmware Using Oracle Hardware Management Pack
Setting Up the Server Using Oracle System Assistant
Organization of Oracle System Assistant
Configuring the Server Using Oracle System Assistant
Mounting the Oracle System Assistant USB Flash Drive
Troubleshooting Oracle System Assistant
Accessing the Oracle System Assistant Filesystem
Managing the Server Using Oracle ILOM
Oracle ILOM Features for Oracle x86 Servers
Supported HBA Disk Controllers
Creating a RAID Volume Before Installing an Operating System
Creating a RAID Volume After Installing an Operating System
Using Oracle ILOM to Monitor Storage Devices
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
Using BIOS for Resource Allocation
Common BIOS Setup Utility Tasks
BIOS Setup Utility Menu Options
UEFI Driver Control Menu Selections
BIOS Save & Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Identifying SNMP Trap Messages
Note - Additional drivers are required only if you installed SLES 11 SP1. If you installed SLES 11 SP2, you can ignore this section.
Updated LSI drivers for the Sun Storage PCIe host bus adapters (HBAs) are available on Novell's Partner Linux Driver Program (PLDP). If you are using either of the following HBAs in your server, you should download and install these drivers after you have installed SLES11 SP1:
Sun Storage 6 Gb SAS PCIe HBA, Internal (SG-SAS6-INT-Z)
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal (SG-SAS6-R-INT-Z)
These drivers are available on the Novell PLDP LSI web site:http://drivers.suse.com/driver-process/pub/update/LSI/sle11sp1/common/x86_64/
There are four drivers available, two for the SLES 11 SP1 regular kernel (non-XEN) and two for the SLES 11 SP1 XEN kernel. Install the two packages appropriate to your kernel.
For the SLES 11 SP1 regular kernel (non-XEN), install the following drivers:
lsi-megaraid_sas-kmp-default-00.00.06.12_2.6.32.12_0.7-1.x86_64.rpm, which is available at:http://drivers.suse.com/driver-process/pub/update/LSI/sle11sp1/common/x86_64/lsi-megaraid_sas-kmp-default-00.00.06.12_2.6.32.12_0.7-1.x86_64.rpm
lsi-mpt2sas-kmp-default-12.00.00.00_2.6.32.12_0.7-1.1.x86_64.rpm, which is available at: http://drivers.suse.com/driver-process/pub/update/LSI/sle11sp1/common/x86_64/lsi-mpt2sas-kmp-default-12.00.00.00_2.6.32.12_0.7-1.1.x86_64.rpm
For the SLES 11 SP1 XEN kernel, install the following drivers:
lsi-megaraid_sas-kmp-xen-00.00.06.12_2.6.32.12_0.7-1.x86_64.rpm, which is available at: http://drivers.suse.com/driver-process/pub/update/LSI/sle11sp1/common/x86_64/lsi-megaraid_sas-kmp-xen-00.00.06.12_2.6.32.12_0.7-1.x86_64.rpm
lsi-mpt2sas-kmp-xen-12.00.00.00_2.6.32.12_0.7-1.1.x86_64.rpm, which is available at: http://drivers.suse.com/driver-process/pub/update/LSI/sle11sp1/common/x86_64/lsi-mpt2sas-kmp-xen-12.00.00.00_2.6.32.12_0.7-1.1.x86_64.rpm
