Skip Navigation Links
Exit Print View
SPARC T4-4 Server HTML Document Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Support and Accessibility
Installation and Setup
Confirming Server and Site Specifications
Server Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Preparing for Installation
Shipping Kit
Handling Precautions
ESD Precautions
Tools Needed for Installation
Installing the Server
Install Optional Components
Rack Compatibility
Rackmount Kit
Determine Correct Rackmount Hardware
Mark the Rackmounting Location
Install the Rackmount Hardware
Install the Server
Installing the Shipping Bracket Assembly (Optional)
Installing the CMA (Optional)
Connecting the Server Cables
Cabling Requirements
Identifying Ports
Connecting Data and Management Cables
Secure Cables Using the CMA
Powering On the Server for the First Time
Connect a Terminal or Emulator to the SER MGT Port
Prepare Power Cords
Power On the System for the First Time
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Booting the Oracle Solaris Operating System
Understanding System Administration Resources
Oracle ILOM Overview
Platform-Specific Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle VM Server for SPARC Overview
Multipathing Software
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Accessing the Server
Log In to Oracle ILOM
Log In to the System Console
Display the ok Prompt
Display the Oracle ILOM -> Prompt
Use a Local Graphics Monitor
Oracle ILOM Remote Console
Controlling the Server
Power On the Server (Oracle ILOM)
Power Off the Server (Oracle ILOM)
Reset the Server (Oracle Solaris OS)
Reset the Server (Oracle ILOM)
Reset the SP to Default Values
Configuring Hardware RAID
Hardware RAID Support
Important Hardware RAID Guidelines
Prepare to Use the FCode Utility
FCode Utility Commands
Create a Hardware RAID Volume
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
RAID Drive Replacement Strategies
Locate Device Paths
Changing Server Identification Information
Change Customer Data on FRU PROMs
Change System Identifier Information
Configuring Policy Settings
Specify Cooldown Mode
Restore the Host Power State at Restart
Specify the Host Power State at Restart
Disable or Re-Enable the Host Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior (Keyswitch State)
Configuring Network Addresses
SP Network Address Options
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the IP Address of the SP
Display the Host MAC Address
Using an In-band Connection to the SP
Configuring Boot Mode
Boot Mode Overview
Configure the Host Boot Mode (Oracle VM Server for SPARC)
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OBP Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Set the Boot Timeout Interval
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Configuring Devices
Unconfigure a Device Manually
Reconfigure a Device Manually
Monitoring the Server
Monitoring Faults
Enabling Automatic System Recovery
Display Server Components
Locate the Server
Updating the Firmware
Display the Firmware Version
Update the Firmware
Display OpenBoot Version
Display POST Version
Identifying WWN-Designated SAS2 Devices
World Wide Name Syntax
Mapping WWN Values to Hard Drives (OBP probe-scsi-all Command)
probe-scsi-all WWN Mapping Overview
probe-scsi-all WWN Mapping Example (SPARC T4-1)
probe-scsi-all WWN Mapping Example (Netra SPARC T4-1)
probe-scsi-all WWN Mapping Example (SPARC T4-2)
probe-scsi-all WWN Mapping Example (Netra SPARC T4-2)
probe-scsi-all WWN Mapping Example (SPARC T4-4 With Four CPUs)
probe-scsi-all WWN Mapping Example (SPARC T4-4 With Two CPUs)
probe-scsi-all WWN Mapping Example (SPARC T4-1B and Netra SPARC T4-1B)
Identify a Disk Slot Using prtconf (Oracle Solaris OS)
WWN Syntax in an OS Installation on an Individual Drive
WWN Syntax in an OS Installation on a RAID Volume
Identifying Components
Main Module Components
Processor Module Components
Illustrated Parts Breakdown
Detecting and Managing Faults
Diagnostics Overview
Diagnostics Process
Interpreting Diagnostic LEDs
Memory Fault Handling
Managing Faults (Oracle ILOM)
Fault Management Command Examples
Interpreting Log Files and System Messages
Managing Faults (POST)
Managing Faults (PSH)
Managing Components (ASR)
Verifying Oracle VTS Installation
Preparing for Service
Safety Information
Tools Needed for Service
Find the Server Serial Number
Locate the Server
Understanding Component Replacement Categories
Removing Power From the Server
Accessing Internal Components
Accessing the Main Module
Remove the Main Module
Install the Main Module
Filler Panels
Servicing Processor Modules
Processor Module Overview
Processor Module LEDs
Replacing a Faulty Processor Module
Install a New Processor Module
Verify Processor Module Functionality
Servicing DIMMs
Understanding DIMM Configurations
Locate a Faulty DIMM (DIMM Fault Remind Button)
Locate a Faulty DIMM (show faulty Command)
Remove a DIMM
Install a DIMM
Increase Memory With Additional DIMMs
Increase Memory With Additional DIMMs (16-Gbyte Configurations)
Verify DIMM Functionality
Understanding DIMM Configuration Error Messages
Servicing Hard Drives
Hard Drive Hot-Pluggable Capabilities
Hard Drive Configuration Reference
Hard Drive LEDs
Locate a Faulty Hard Drive
Remove a Hard Drive
Install a Hard Drive
Verify Hard Drive Functionality
Servicing Power Supplies
Power Supply Overview
Power Supply and AC Power Connector Configuration Reference
Power Supply and AC Power Connector LEDs
Locate a Faulty Power Supply
Remove a Power Supply
Install a Power Supply
Verify Power Supply Functionality
Servicing RAID Expansion Modules
Remove the RAID Expansion Module
Install the RAID Expansion Module
Servicing the Service Processor Card
Service Processor Card Overview
Locate a Faulty Service Processor Card
Remove the Service Processor Card
Install the Service Processor Card
Verify Service Processor Card Functionality
Servicing the System Battery
Remove the System Battery
Install the System Battery
Verify the System Battery
Servicing Fan Modules
Fan Module Overview
Fan Module Configuration Reference
Fan Module LED
Locate a Faulty Fan Module
Remove a Fan Module
Install a Fan Module
Verify Fan Module Functionality
Servicing Express Modules
Express Module Configuration Reference
Express Module FRU Paths
Locate a Faulty Express Module
Remove an Express Module
Install an Express Module
Verify Express Module Functionality
Servicing the Rear I/O Module
Locate a Faulty Rear I/O Module
Remove the Rear I/O Module
Install the Rear I/O Module
Verify Rear I/O Module Functionality
Servicing the System Configuration PROM
System Configuration PROM Overview
Remove the System Configuration PROM
Install the System Configuration PROM
Servicing the Front I/O Assembly
Front I/O Assembly Overview
Remove the Front I/O Assembly
Install the Front I/O Assembly
Servicing the Storage Backplane
Remove a Storage Backplane
Install a Storage Backplane
Servicing the Main Module Motherboard
Main Module Motherboard Overview
Main Module Motherboard LEDs
Locate a Faulty Main Module Motherboard
Remove the Main Module Motherboard
Install the Main Module Motherboard
Verify Main Module Motherboard Functionality
Servicing the Rear Chassis Subassembly
Rear Chassis Subassembly Overview
Remove the Rear Chassis Subassembly
Install the Rear Chassis Subassembly
Connect Power Cords
Power On the Server (start /SYS Command)
Power On the Server (Power Button)
The SPARC T4-4 server has two REM cards plugged into the motherboard. These modules are referred to as controllers 0 and 1. Each SAS controller is connected to a separate four-slot disk backplane. The following table shows the PhyNum-to-disk slot mapping for the two four-slot SPARC T4-4 backplanes.
Table 8 SAS2 Controller Port Mapping for the SPARC T4-4 Disk Backplane
Disk Backplane 0
Disk Backplane 1
SAS2 Controller
Controller Port ID
Disk Slot ID
SAS2 Controller
Controller Port ID
Disk Slot ID
1Default boot drive
This table shows that ports 0-3 of controller 0 are connected to backplane slots 0-3 and ports 0-3 of controller 1 are connected to slots 4-7.
The following example is based on a SPARC T4-4 server with two CPUs and eight hard drives. These hard drives are deployed as six individual storage devices and a virtual drive that consists of two hard drives configured as a RAID volume. Controllers 0 and 1 are attached to these storage devices in the following manner:
Note - OBP uses a different device path for SAS controller 1 in SPARC T4-4 servers, depending on whether the server has four processors or two processors.The path for SAS controller 0 is the same for both processor configurations.
ok probe-scsi-all
/pci@500/pci@1/pci@0/pci@0/LSI,sas@0                    <---- SAS controller 1
FCode Version 1.00.54, MPT Version 2.00, Firmware Version
Target 9
  Unit 0   Disk   HITACHI  H103030SCSUN300G A2A8    585937500 Blocks, 300 GB
  SASDeviceName 5000cca00abc5cc8  SASAddress 5000cca00abc5cc9  PhyNum 0
Target a
  SASDeviceName 5000cca00abaf620  SASAddress 5000cca00abaf621  PhyNum 1
Target b
  SASDeviceName 5000cca00abcec4c  SASAddress 5000cca00abcec4d  PhyNum 2
Target c
  SASDeviceName 5000cca00abc5218  SASAddress 5000cca00abc5219  PhyNum 3
Unit 0   Removable Read Only device    AMI     Virtual CDROM   1.00
/pci@400/pci@1/pci@0/pci@0/LSI,sas@0                    <---- SAS controller 0
Target 9
  SASDeviceName 5000cca00abcede0  SASAddress 5000cca00abcede1  PhyNum 0
Target a
  SASDeviceName 5000cca00abc51a8  SASAddress 5000cca00abc51a9  PhyNum 1
Target 457 Volume 0
  Unit 0   Disk   LSI     Logical Volume   3000   583983104 Blocks,   298 GB
  VolumeDeviceName 3ce534e42c02a3c0   VolumeWWID 0ce534e42c02a3c0
In this example, the controller ports are attached to the hard drives in the following manner:
Disk Backplane 0
Disk Backplane 1
Controller Port (PhyNum)
Disk Slot ID
Disk Slot ID
RAID Target 457
RAID Target 457
1Default boot drive
Note - Target values are not static. The same storage device can appear in two consecutive probe-scsi-all listings with different Target values.
The default boot device has the following values:
If you want to specify another drive to be the boot device, find its PhyNum value in the output and use the SASDeviceName assigned to that device. For example, if you want to use the hard drive in disk slot 1, it has the following values:
Related Information
