Skip Navigation Links
Exit Print View
SPARC and Netra SPARC T4 Series Servers
Security Guide
search filter icon
search icon
Document Information
SPARC and Netra SPARC T4 Series Servers Security
Understanding Security Principles
Planning a Secure Environment
Maintaining a Secure Environment
Index
Oracle hardware and software provide a number of security features controlling hardware and tracking assets.
Hardware Controls
Some Oracle systems can be set up to be turned on and off by software commands. In addition, the power distribution units (PDUs) for some system cabinets can be enabled and disabled remotely by software commands. Authorization for these commands is typically set up during system configuration and is usually limited to system administrators and service personnel. Refer to your system or cabinet documentation for further information.
Asset Tracking
Oracle serial numbers are embedded in firmware located on option cards and system mother boards. These serial numbers can be read through local area network connections for inventory tracking.
Wireless radio frequency identification (RFID) readers can further simplify asset tracking. An Oracle white paper, How to Track Your Oracle Sun System Assets by Using RFID is available at:
Software and Firmware
Local and Remote Access
Follow these guidelines to ensure the security of local and remote access to your systems:
Data Security
Follow these guidelines to maximize data security:
Network Security
Follow these guidelines to maximize your network security:
