Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster 4.0 Release Notes Oracle Solaris Cluster 4.0 |
Default Root File System of Oracle Solaris ZFS
Selected Support for Non-Global Zones
HA for Oracle with Oracle Data Guard Replication
What's Not Included in the Oracle Solaris Cluster 4.0 Software
Solaris Volume Manager Disk Sets in a Zone Cluster
Commands Modified in This Release
Oracle Clusterware Fails to Create All SIDs for ora.asm Resource (12680224)
IP Addresses on a Failed IP Interface Can No Longer Be Used Locally (7099852)
DID Disk Add to Solaris Zone Is Not Accepting Wild Card for *dsk (7081090)
x86: clzonecluster export Command Fails (7066586)
Using chmod to setuid Returns Error in Non-Global Zone on PxFS Secondary Server (7020380)
Cannot Create a Resource From a Configuration File With Non-Tunable Extension Properties (6971632)
Cluster.CCR: libpnm system error: Failed to resolve pnm proxy pnm_server.2.zonename (6942090)
Missing /dev/rmt Causes Incorrect Reservation Usage When Policy Is pathcount (6920996)
Disabling Device Fencing While Cluster Is Under Load Results in Reservation Conflict (6908466)
Removing Nodes From the Cluster Configuration Can Result in Node Panics (6735924)
'Unable to Determine Oracle CRS Version' Error After Applying Patch 145333-09 (7090390)
Scalable Applications Are Not Isolated Between Zone Clusters (6911363)
scinstall Tries to Create an IPMP Group on a Standby Interface (7095759)
Autodiscovery Should Find Only One Interconnect Path for Each Adapter (6299097)
Failure of Logical Hostname to Fail Over Caused by getnetmaskbyaddr() (7075347)
ssm_start Fails Due to Unrelated IPMP Down (6938555)
Oracle Solaris Cluster 4.0 Documentation Set
HA for Zones Procedure Moved to the Data Service Manual
Correction to Default Set of Packages That Are Installed by the Automated Installer
This section describes the software and memory requirements for Oracle Solaris Cluster 4.0 and Oracle Solaris Cluster Geographic Edition 4.0 software.
The following data replication products are supported in this release:
Availability Suite feature of Oracle Solaris – When used with Geographic Edition software, support requires a minimum of Oracle Solaris 11 software repository update (SRU) 1.
Oracle Data Guard – Support is limited to configurations that use Oracle Database 11.2.0.3 software.
Oracle Solaris Cluster Geographic Edition script-based plug-ins.
The following table describes the volume managers that are supported in this release for each data replication software product.
1For information about additional supported storage management options, see Storage Management Requirements in Oracle Solaris Cluster Data Service for Oracle Real Application Clusters Guide.
Data services for the following applications are supported with Oracle Solaris Cluster 4.0:
Apache
Apache Tomcat
DHCP
DNS
NFS
Oracle GlassFish Server Message Queue
Oracle Database single-instance on version 11.2.0.3 only
Oracle Real Application Clusters on version 11.2.0.3 only
Oracle Solaris Zones
Oracle VM Server for SPARC
Oracle WebTier
WebLogic Server
The Grid Engine and Sun Java System Application Server EE (formerly called HADB) Data Services are no longer supported.
The following table describes the file systems that work with the Oracle Solaris Cluster 4.0 software on SPARC and x86 platforms.
The Oracle Solaris Cluster Geographic Edition (Geographic Edition) 4.0 software runs on only Oracle Solaris Cluster 4.0 software.
A Geographic Edition configuration can consist of one cluster running Geographic Edition 4.0 software and the other cluster running Geographic Edition 3.3 5/11 software.
The Oracle Solaris Cluster 4.0 software requires the following memory requirements for every cluster node:
Minimum of 1.5 Gbytes of physical RAM (2 Gbytes typical)
Minimum of 6 Gbytes of available hard drive space
Actual physical memory and hard drive requirements are determined by the applications that are installed. Consult the application's documentation or contact the application vendor to calculate additional memory and hard drive requirements.
The Oracle Solaris Cluster 4.0, Oracle Solaris Cluster Geographic Edition 4.0, and Quorum Server software require the Oracle Solaris 11 OS.
This Oracle Solaris Cluster release works with Oracle VM Server for SPARC 2.1 This software was formerly called Sun Logical Domains (LDoms).
The following table describes the volume managers that work with Oracle Solaris 11 on the SPARC and x86 platforms. Veritas Volume Manager (VxVM) is not supported for the Oracle Solaris Cluster and Oracle Solaris Cluster Geographic Edition 4.0 software.
