Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster Security Guide Oracle Solaris Cluster 4.0 |
The Oracle Solaris Cluster Security Guide contains conceptual information about the Oracle Solaris Cluster software product.
The Oracle Solaris Cluster Security Guide contains the following chapter:
Chapter 1, Introduction to Oracle Solaris Cluster Security provides an overview of the overall concepts that you need to know about Oracle Solaris Cluster security.
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table. All Oracle Solaris Cluster documentation is available at http://www.oracle.com/technetwork/indexes/documentation/index.html.
Oracle customers have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
If you have problems installing or using Oracle Solaris Cluster software, contact your service provider and provide the following information:
Your name and email address (if available)
Your company name, address, and phone number
The model and serial numbers of your systems
The release number of the operating system (for example, Oracle Solaris 11)
The release number of the Oracle Solaris Cluster software (for example, 4.0)
The contents of the /var/cacao/instances/default/logs/cacao.0/1/2 file
Also have available the contents of the /var/adm/messages file.
