Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Concepts Guide     Oracle Solaris Cluster 4.0
search filter icon
search icon
Document Information
1.  Introduction and Overview
2.  Key Concepts for Hardware Service Providers
3.  Key Concepts for System Administrators and Application Developers
The Oracle Solaris Cluster Concepts Guide contains conceptual information about the Oracle Solaris Cluster product on both SPARC and x86 based systems.
Note - This Oracle Solaris Cluster release supports systems that use the SPARC and x86 families of processor architectures. In this document, “x86” refers to the larger family of x86 compatible products. Information in this document pertains to all platforms unless otherwise specified.
Bash is the default shell for Oracle Solaris 11. Machine names shown with the Bash shell prompt are displayed for clarity.
Using UNIX Commands
This document contains information about commands that are specific to installing and configuring Oracle Solaris Cluster data services. The document does not contain comprehensive information about basic UNIX commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
What you type, contrasted with onscreen computer output
machine_name% su
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows the default UNIX system prompt and superuser prompt for shells that are included in the Oracle Solaris OS. Note that the default system prompt that is displayed in command examples varies, depending on the Oracle Solaris release.
Table P-2 Shell Prompts
Bash shell, Korn shell, and Bourne shell
Bash shell, Korn shell, and Bourne shell for superuser
C shell
C shell for superuser
Related Documentation
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table. All Oracle Solaris Cluster documentation is available at
Hardware installation and administration
Oracle Solaris Cluster 4.0 Hardware Administration Manual
Individual hardware administration guides
Software installation
Data service installation and administration
Data service development
System administration
Software upgrade
Error messages
Command and function references
Access to Oracle Support
Oracle customers have access to electronic support through My Oracle Support. For information, visit or visit if you are hearing impaired.
Getting Help
If you have problems installing or using Oracle Solaris Cluster, contact your service provider and provide the following information.
Use the following commands to gather information about your system for your service provider.
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
pkg list
Reports which packages are installed
prtdiag -v
Displays system diagnostic information
/usr/cluster/bin/clnode show-rev
Displays Oracle Solaris Cluster release and package version information for each node
Also have available the contents of the /var/adm/messages file.
