Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster Geographic Edition Overview Oracle Solaris Cluster 4.0 |
1. Introduction to Geographic Edition Software
2. Key Concepts for Geographic Edition
Oracle Solaris Cluster Geographic Edition Overview introduces the Oracle Solaris Cluster Geographic Edition (Geographic Edition) software by explaining the purpose of the product and the means by which Geographic Edition achieves this purpose. This book also explains key concepts for Geographic Edition. This document contains information about Geographic Edition features and functionality.
Bash is the default prompt for Oracle Solaris 11. Machine names shown with the Bash shell prompt are displayed for clarity.
This document contains information about commands that are used to install, configure, or administer a Geographic Edition configuration. This document might not contain complete information on basic UNIX commands and procedures such as shutting down the system, booting the system, and configuring devices.
See one or more of the following sources for this information:
Online documentation for the Solaris software system
Other software documentation that you received with your system
Solaris Operating System (OS) man pages
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
The following table shows the default UNIX system prompt and superuser prompt for shells that are included in the Oracle Solaris OS. Note that the default system prompt that is displayed in command examples varies, depending on the Oracle Solaris release.
Table P-2 Shell Prompts
Information about related Geographic Edition topics is available in the documentation that is listed in the following table.
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table.
Oracle customers have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
If you have problems installing or using the Geographic Edition system, contact your service provider and provide the following information:
Your name and email address (if available)
Your company name, address, and phone number
The model and serial numbers of your systems
The release number of the operating system (for example, Oracle Solaris 11)
The release number of the Geographic Edition software (for example, 4.0)
Use the following commands to gather information about each node on your system for your service provider.
Also have available the contents of the /var/adm/messages file and the log files in /var/opt/SUNWcacao/logs.
