Skip Navigation Links
Exit Print View
man pages section 3: Realtime Library Functions     Oracle Solaris 10 8/11 Information Library
search filter icon
search icon
Document Information
Preface
aiocancel(3AIO)
aio_cancel(3RT)
aio_error(3RT)
aio_fsync(3RT)
aioread(3AIO)
aio_read(3RT)
aio_return(3RT)
aio_suspend(3RT)
aiowait(3AIO)
aio_waitn(3RT)
aiowrite(3AIO)
aio_write(3RT)
clock_getres(3RT)
clock_gettime(3RT)
clock_nanosleep(3RT)
clock_settime(3RT)
door_bind(3DOOR)
door_call(3DOOR)
door_create(3DOOR)
door_cred(3DOOR)
door_info(3DOOR)
door_return(3DOOR)
door_revoke(3DOOR)
door_server_create(3DOOR)
door_ucred(3DOOR)
door_unbind(3DOOR)
door_xcreate(3DOOR)
fdatasync(3RT)
lio_listio(3RT)
mq_close(3RT)
mq_getattr(3RT)
mq_notify(3RT)
mq_open(3RT)
mq_receive(3RT)
mq_reltimedreceive_np(3RT)
mq_reltimedsend_np(3RT)
mq_send(3RT)
mq_setattr(3RT)
mq_timedreceive(3RT)
mq_timedsend(3RT)
mq_unlink(3RT)
nanosleep(3RT)
proc_service(3PROC)
ps_kill(3PROC)
ps_lcontinue(3PROC)
ps_lgetfpregs(3PROC)
ps_lgetregs(3PROC)
ps_lgetxregs(3PROC)
ps_lgetxregsize(3PROC)
ps_lrolltoaddr(3PROC)
ps_lsetfpregs(3PROC)
ps_lsetregs(3PROC)
ps_lsetxregs(3PROC)
ps_lstop(3PROC)
ps_pcontinue(3PROC)
ps_pdread(3PROC)
ps_pdwrite(3PROC)
ps_pglobal_lookup(3PROC)
ps_pglobal_sym(3PROC)
ps_pread(3PROC)
ps_pstop(3PROC)
ps_ptread(3PROC)
ps_ptwrite(3PROC)
ps_pwrite(3PROC)
sched_getparam(3RT)
sched_get_priority_max(3RT)
sched_get_priority_min(3RT)
sched_getscheduler(3RT)
sched_rr_get_interval(3RT)
sched_setparam(3RT)
sched_setscheduler(3RT)
sched_yield(3RT)
sem_close(3RT)
sem_destroy(3RT)
sem_getvalue(3RT)
sem_init(3RT)
sem_open(3RT)
sem_post(3RT)
sem_reltimedwait_np(3RT)
sem_timedwait(3RT)
sem_trywait(3RT)
sem_unlink(3RT)
sem_wait(3RT)
shm_open(3RT)
shm_unlink(3RT)
sigqueue(3RT)
sigtimedwait(3RT)
sigwaitinfo(3RT)
timer_create(3RT)
timer_delete(3RT)
timer_getoverrun(3RT)
timer_gettime(3RT)
timer_settime(3RT)
door_xcreate
- create a door descriptor for a private door with per-door control over thread creation
Synopsis
#include <door.h>
typedef void door_server_procedure_t(void *, char *, size_t,
     door_desc_t *, uint_t);
typedef int door_xcreate_server_func_t(door_info_t *,
     void *(*)(void *), void *, void *);
typedef void door_xcreate_thrsetup_func_t(void *);
int door_xcreate(door_server_procedure_t *server_proceduere,
     void *cookie, uint_t attributes,
     door_xcreate_server_func_t *thr_create_func,
     door_xcreate_thrsetup_func_t *thr_setup_func, void *crcookie,
     int nthread);
Description
The door_xcreate() function creates a private door to the given server_procedure, with per-door control over the creation of threads that will service invocations of that door. A private door is a door that has a private pool of threads that service calls to that door alone; non-private doors share a pool of service threads (see door_create(3DOOR)).
Creating private doors using door_create()
Prior to the introduction of door_xcreate(), a private door was created using door_create() specifying attributes including DOOR_PRIVATE after installing a suitable door server thread creation function using door_server_create(). During such a call to door_create(), the first server thread for that door is created by calling the door server function; you must therefore already have installed a custom door server creation function using door_server_create(). The custom server creation function is called at initial creation of a private door, and again whenever a new invocation uses the last available thread for that door. The function must decide whether it wants to increase the level of concurrency by creating an additional thread - if it decides not to then further invocations may have to wait for an existing active invocation to complete before they can proceed. Additional threads may be created using whatever thread attributes are desired in the application, and the application must specify a thread start function (to thr_create(3C) or pthread_create(3C)) which will perform a door_bind() to the newly-created door before calling door_return(NULL, 0, NULL, 0) to enter service. See door_server_create(3DOOR) and door_bind(3DOOR) for more information and for an example.
This “legacy” private door API is adequate for many uses, but has some limitations:
Creating private doors with door_xcreate()
The door_xcreate() function is purpose-designed for the creation of private doors and simplifies their use by moving responsibility for binding the new server thread and synchronizing with it into a library-provided thread startup function:
The descriptor returned from door_xcreate() will be marked as close on exec (FD_CLOEXEC). Information about a door is available for all clients of a door using door_info(3DOOR). Applications concerned with security should not place secure information in door data that is accessible by door_info(). In particular, secure data should not be stored in the data item cookie.
A process can advertise a door in the file system name space using fattach(3C).
A door created with door_xcreate() may be revoked using door_revoke(3DOOR). This closes the associated file descriptor, and acts as a barrier to further door invocations, but existing active invocations are not guaranteed to have completed before door_revoke() returns. Server threads bound to a revoked door do not wakeup or exit automatically when the door is revoked.
Return Values
Upon successful completion, door_xcreate() returns a non-negative value. Otherwise, door_xcreate() returns -1 and sets errno to indicate the error.
Errors
The door_xcreate() function will fail if:
E2BIG
The requested nthread is too large. A small amount of stack space is required for each thread we must start and synchronize with. If extending the door_xcreate() stack by the required amount will exceed the stack bounds then E2BIG is returned.
EBADF
The attempt to door_bind() within the library-provided thread start function failed.
EINVAL
Invalid attributes are passed, nthread is less than 1, or thr_create_func() is NULL. This is also returned if thr_create_func() returns 0 (no thread creation attempted) during door_xcreate().
EMFILE
The process has too many open descriptors.
ENOMEM
Insufficient memory condition while creating the door.
ENOTSUP
A door_xcreate() call was attempted from a fork handler.
EPIPE
A call to the nominated thr_create_func() returned -1 indicating that pthread_create() or thr_create() failed.
Examples
Example 1 Create a private door with an initial pool of 10 server threads
Create a private door with an initial pool of 10 server threads. Threads are created with the minimum required attributes and there is no thread setup function. Use fattach() to advertise the door in the filesystem namespace.
static pthread_attr_t tattr;
 * Simplest possible door_xcreate_server_func_t.  Always attempt to
 * create a thread, using the previously initialized attributes for
 * all threads. We must use the start function and argument provided,
 * and make no use of our private mycookie argument.
int
thrcreatefunc(door_info_t *dip, void *(*startf)(void *),
    void *startfarg, void *mycookie)
        if (pthread_create(NULL, &tattr, startf, startfarg) != 0) {
                perror("thrcreatefunc: pthread_create");
                return (-1);
        return (1);
 * Dummy door server procedure - does no processing.
void
door_proc(void *cookie, char *argp, size_t argsz, door_desc_t *descp,
    uint_t n)
    door_return (NULL, 0, NULL, 0);
int
main(int argc, char *argv[])
    struct stat buf;
    int did;
     * Setup thread attributes - minimum required.
    (void) pthread_attr_init(&tattr);
    (void) pthread_attr_setdetachstate(&tattr, PTHREAD_CREATE_DETACHED);
    (void) pthread_attr_setscope(&tattr, PTHREAD_SCOPE_SYSTEM);
     * Create a private door with an initial pool of 10 server threads.
    did = door_xcreate(door_proc, NULL, 0, thrcreatefunc, NULL, NULL,
                       10);
    if (did == -1) {
        perror("door_xcreate");
        exit(1);
    if (stat(DOORPATH, &buf) < 0) {
        int newfd;
        if ((newfd = creat(DOORPATH, 0644)) < 0) {
            perror("creat");
            exit(1);
        (void) close(newfd);
    (void) fdetach(DOORPATH);
    if (fattach(did, DOORPATH) < 0) {
        perror("fattach");
        exit(1);
    (void) fprintf(stderr, "Pausing in main\n");
    (void) pause();
Example 2 Create a private door with exactly one server thread and no callbacks for additional threads
Create a private door with exactly one server thread and no callbacks for additional threads. Use a server thread stacksize of 32K, and specify a thread setup function.
#define DOORPATH        "/tmp/grmdoor"
 * Thread setup function - configuration that must be performed from
 * the conext of the new thread.  The mycookie argument is the
 * second-to-last argument from door_xcreate.
void
thrsetupfunc(void *mycookie)
     * If a thread setup function is specified it must do the
     * following at minimum.
    (void) pthread_setcanceltype(PTHREAD_CANCEL_DEFERRED, NULL);
     * The default thread setup functions also performs the following
     * to disable thread cancellation notifications, so that server
     * threads are not cancelled when a client aborts a door call.
     * This is not a requirement.
    (void) pthread_setcancelstate(PTHREAD_CANCEL_DISABLE, NULL);
     * Now we can go on to perform other thread initialization,
     * for example to allocate and initialize some thread-specific data
     * for this thread;  for thread-specific data you can use a
       destructor function in pthread_key_create if you want to perform
       any actions if/when a door server thread exits.
 * The door_xcreate_server_func_t we will use for server thread
 * creation. The mycookie argument is the second-to-last argument
 * from door_xcreate.
int
            return (-1);
    return (1);
 * Door procedure.  The cookie received here is the second arg to
 * door_xcreate.
void
    uint_t n)
    (void) door_return(NULL, 0, NULL, 0);
int
    struct stat buf;
    int did;
     * Configure thread attributes we will use in thrcreatefunc.
     * The PTHREAD_CREATE_DETACHED and PTHREAD_SCOPE_SYSTEM are
     * required.
    (void) pthread_attr_setstacksize(&tattr, 16 * 1024);
     * Create a private door with just one server thread and asking for
         * no further callbacks on thread pool depletion during an
         * invocation.
    did = door_xcreate(door_proc, NULL, DOOR_NO_DEPLETION_CB,
        thrcreatefunc, thrsetupfunc, NULL, 1);
    if (did == -1) {
            exit(1);
            int newfd;
                    perror("creat");
                    exit(1);
            perror("fattach");
            exit(1);
    (void) pause();
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
all
Availability
SUNWcsu
Interface Stability
Committed
MT-Level
Safe
See Also
door_bind(3DOOR), door_call(3DOOR), door_create(3DOOR), door_info(3DOOR), door_revoke(3DOOR), door_server_create(3DOOR), fattach(3C), libdoor(3LIB), pthread_create(3C), pthread_cleanup_pop(3C), pthread_cleanup_push(3C), thr_create(3C), attributes(5), cancellation(5)
