Skip Navigation Links | |
Exit Print View | |
man pages section 3: Extended Library Functions Oracle Solaris 10 8/11 Information Library |
Extended Library Functions - Part 1
ct_event_read_critical(3CONTRACT)
ct_pr_event_get_exitstatus(3CONTRACT)
ct_pr_event_get_gcorefile(3CONTRACT)
ct_pr_event_get_pcorefile(3CONTRACT)
ct_pr_event_get_pid(3CONTRACT)
ct_pr_event_get_ppid(3CONTRACT)
ct_pr_event_get_sender(3CONTRACT)
ct_pr_event_get_senderct(3CONTRACT)
ct_pr_event_get_signal(3CONTRACT)
ct_pr_event_get_zcorefile(3CONTRACT)
ct_pr_status_get_contracts(3CONTRACT)
ct_pr_status_get_fatal(3CONTRACT)
ct_pr_status_get_members(3CONTRACT)
ct_pr_status_get_param(3CONTRACT)
ct_pr_tmpl_get_fatal(3CONTRACT)
ct_pr_tmpl_get_param(3CONTRACT)
ct_pr_tmpl_get_transfer(3CONTRACT)
ct_pr_tmpl_set_fatal(3CONTRACT)
ct_pr_tmpl_set_param(3CONTRACT)
ct_pr_tmpl_set_transfer(3CONTRACT)
ct_status_get_cookie(3CONTRACT)
ct_status_get_critical(3CONTRACT)
ct_status_get_holder(3CONTRACT)
ct_status_get_informative(3CONTRACT)
ct_status_get_nevents(3CONTRACT)
ct_status_get_nevid(3CONTRACT)
ct_status_get_ntime(3CONTRACT)
ct_status_get_qtime(3CONTRACT)
ct_status_get_state(3CONTRACT)
ct_status_get_zoneid(3CONTRACT)
ct_tmpl_get_critical(3CONTRACT)
ct_tmpl_get_informative(3CONTRACT)
ct_tmpl_set_critical(3CONTRACT)
ct_tmpl_set_informative(3CONTRACT)
dat_evd_clear_unwaitable(3DAT)
dat_get_consumer_context(3DAT)
Extended Library Functions - Part 2
Extended Library Functions - Part 3
Extended Library Functions - Part 4
- transfer data to the remote side
cc [ flag… ] file… -ldat [ library… ] #include <dat/udat.h> DAT_RETURN dat_ep_post_send ( IN DAT_EP_HANDLE ep_handle, IN DAT_COUNT num_segments, IN DAT_LMR_TRIPLET *local_iov, IN DAT_DTO_COOKIE user_cookie, IN DAT_COMPLETION_FLAGS completion_flags )
Handle for an instance of the Endpoint.
Number of lmr_triplets in local_iov. Can be 0 for 0 size message.
I/O Vector that specifies the local buffer that contains data to be transferred. Can be NULL for 0 size message.
User-provided cookie that is returned to the Consumer at the completion of the send. Can be NULL.
Flags for posted Send. The default DAT_COMPLETION_DEFAULT_FLAG is 0x00. Other values are as follows:
DAT_COMPLETION_SUPPRESS_FLAG
Suppress successful Completion.
DAT_COMPLETION_SOLICITED_WAIT_FLAG
Request for notification completion for matching receive on the other side of the connection.
DAT_COMPLETION_UNSIGNALLED_FLAG
Non-notification completion. Local Endpoint must be configured for Notification Suppression.
DAT_COMPLETION_BARRIER_FENCE_FLAG
Request for Barrier Fence.
The dat_ep_post_send() function requests a transfer of all the data from the local_iov over the connection of the ep_handle Endpoint to the remote side.
The num_segments parameter specifies the number of segments in the local_iov. The local_iov segments are traversed in the I/O Vector order until all the data is transferred.
A Consumer cannot modify the local_iov or its content until the DTO is completed. When a Consumer does not adhere to this rule, the behavior of the Provider and the underlying Transport is not defined. Providers that allow Consumers to get ownership of the local_iov back after the dat_ep_post_send() returns should document this behavior and also specify its support in Provider attributes. This behavior allows Consumers full control of the local_iov, but not the memory it specifies after dat_ep_post_send() returns. Because this behavior is not guaranteed by all Providers, portable Consumers should not rely on this behavior. Consumers should not rely on the Provider copying local_iov information.
The DAT_SUCCESS return of the dat_ep_post_send() is at least the equivalent of posting a Send operation directly by native Transport. Providers should avoid resource allocation as part of dat_ep_post_send() to ensure that this operation is nonblocking and thread safe for an UpCall.
The completion of the posted Send is reported to the Consumer asynchronously through a DTO Completion event based on the specified completion_flags value. The value of DAT_COMPLETION _UNSIGNALLED_FLAG is only valid if the Endpoint Request Completion Flags DAT_COMPLETION_UNSIGNALLED_FLAG. Otherwise, DAT_INVALID_PARAMETER is returned.
The user_cookie allows Consumers to have unique identifiers for each DTO. These identifiers are completely under user control and are opaque to the Provider. There is no requirement on the Consumer that the value user_cookie should be unique for each DTO. The user_cookie is returned to the Consumer in the Completion event for the posted Send.
The operation is valid for the Endpoint in the DAT_EP_STATE_CONNECTED and DAT_EP_STATE_DISCONNECTED states. If the operation returns successfully for the Endpoint in the DAT_EP_STATE_DISCONNECTED state, the posted Send is immediately flushed to request_evd_handle.
The operation was successful.
The operation failed due to resource limitations.
Invalid parameter. For example, one of the IOV segments pointed to a memory outside its LMR.
The ep_handle parameter is invalid.
A parameter is in an invalid state. Endpoint was not in the DAT_EP_STATE_CONNECTED or DAT_EP_STATE_DISCONNECTED state.
Protection violation for local or remote memory access. Protection Zone mismatch between an LMR of one of the local_iov segments and the local Endpoint.
Privileges violation for local or remote memory access. One of the LMRs used in local_iov was either invalid or did not have the local read privileges.
For best Send operation performance, the Consumer should align each buffer segment of local_iov to the Optimal Buffer Alignment attribute of the Provider. For portable applications, the Consumer should align each buffer segment of local_iov to the DAT_OPTIMAL_ALIGNMENT.
