Skip Navigation Links | |
Exit Print View | |
man pages section 3: Extended Library Functions Oracle Solaris 10 8/11 Information Library |
Extended Library Functions - Part 1
Extended Library Functions - Part 2
Extended Library Functions - Part 3
Extended Library Functions - Part 4
MP_GetAssociatedPathOidList(3MPAPI)
MP_GetAssociatedPluginOid(3MPAPI)
MP_GetAssociatedTPGOidList(3MPAPI)
MP_GetDeviceProductOidList(3MPAPI)
MP_GetDeviceProductProperties(3MPAPI)
MP_GetInitiatorPortOidList(3MPAPI)
MP_GetInitiatorPortProperties(3MPAPI)
MP_GetLibraryProperties(3MPAPI)
MP_GetMPLogicalUnitProperties(3MPAPI)
MP_GetMPLuOidListFromTPG(3MPAPI)
MP_GetPathLogicalUnitProperties(3MPAPI)
MP_GetPluginProperties(3MPAPI)
MP_GetProprietaryLoadBalanceOidList(3MPAPI)
MP_GetProprietaryLoadBalanceProperties(3MPAPI)
MP_GetTargetPortGroupProperties(3MPAPI)
MP_GetTargetPortOidList(3MPAPI)
MP_GetTargetPortProperties(3MPAPI)
MP_RegisterForObjectPropertyChanges(3MPAPI)
MP_RegisterForObjectVisibilityChanges(3MPAPI)
MP_SetFailbackPollingRate(3MPAPI)
MP_SetLogicalUnitLoadBalanceType(3MPAPI)
MP_SetPluginLoadBalanceType(3MPAPI)
MP_SetProbingPollingRate(3MPAPI)
MP_SetProprietaryProperties(3MPAPI)
nvlist_add_boolean_array(3NVPAIR)
nvlist_add_boolean_value(3NVPAIR)
nvlist_add_byte_array(3NVPAIR)
nvlist_add_int16_array(3NVPAIR)
nvlist_add_int32_array(3NVPAIR)
nvlist_add_int64_array(3NVPAIR)
nvlist_add_int8_array(3NVPAIR)
nvlist_add_nvlist_array(3NVPAIR)
nvlist_add_string_array(3NVPAIR)
nvlist_add_uint16_array(3NVPAIR)
nvlist_add_uint32_array(3NVPAIR)
nvlist_add_uint64_array(3NVPAIR)
nvlist_add_uint8_array(3NVPAIR)
nvlist_lookup_boolean(3NVPAIR)
nvlist_lookup_boolean_array(3NVPAIR)
nvlist_lookup_boolean_value(3NVPAIR)
nvlist_lookup_byte_array(3NVPAIR)
nvlist_lookup_int16_array(3NVPAIR)
nvlist_lookup_int32_array(3NVPAIR)
nvlist_lookup_int64_array(3NVPAIR)
nvlist_lookup_int8_array(3NVPAIR)
nvlist_lookup_nv_alloc(3NVPAIR)
nvlist_lookup_nvlist_array(3NVPAIR)
nvlist_lookup_string_array(3NVPAIR)
nvlist_lookup_uint16_array(3NVPAIR)
nvlist_lookup_uint32_array(3NVPAIR)
nvlist_lookup_uint64_array(3NVPAIR)
nvlist_lookup_uint8_array(3NVPAIR)
nvpair_value_boolean_array(3NVPAIR)
nvpair_value_boolean_value(3NVPAIR)
nvpair_value_byte_array(3NVPAIR)
nvpair_value_int16_array(3NVPAIR)
nvpair_value_int32_array(3NVPAIR)
nvpair_value_int64_array(3NVPAIR)
nvpair_value_int8_array(3NVPAIR)
nvpair_value_nvlist_array(3NVPAIR)
nvpair_value_string_array(3NVPAIR)
nvpair_value_uint16_array(3NVPAIR)
nvpair_value_uint32_array(3NVPAIR)
nvpair_value_uint64_array(3NVPAIR)
nvpair_value_uint8_array(3NVPAIR)
papiAttributeListAddBoolean(3PAPI)
papiAttributeListAddCollection(3PAPI)
papiAttributeListAddDatetime(3PAPI)
papiAttributeListAddInteger(3PAPI)
papiAttributeListAddMetadata(3PAPI)
papiAttributeListAddRange(3PAPI)
papiAttributeListAddResolution(3PAPI)
papiAttributeListAddString(3PAPI)
papiAttributeListAddValue(3PAPI)
papiAttributeListDelete(3PAPI)
papiAttributeListFromString(3PAPI)
papiAttributeListGetBoolean(3PAPI)
papiAttributeListGetCollection(3PAPI)
papiAttributeListGetDatetime(3PAPI)
papiAttributeListGetInteger(3PAPI)
papiAttributeListGetMetadata(3PAPI)
papiAttributeListGetNext(3PAPI)
papiAttributeListGetRange(3PAPI)
papiAttributeListGetResolution(3PAPI)
papiAttributeListGetString(3PAPI)
papiAttributeListGetValue(3PAPI)
papiAttributeListToString(3PAPI)
papiJobGetAttributeList(3PAPI)
papiJobSubmitByReference(3PAPI)
papiLibrarySupportedCall(3PAPI)
papiLibrarySupportedCalls(3PAPI)
papiPrinterGetAttributeList(3PAPI)
papiServiceGetAttributeList(3PAPI)
papiServiceGetEncryption(3PAPI)
papiServiceGetServiceName(3PAPI)
papiServiceGetStatusMessage(3PAPI)
papiServiceSetEncryption(3PAPI)
picld_plugin_register(3PICLTREE)
picl_get_frutree_parent(3PICL)
picl_get_propinfo_by_name(3PICL)
picl_get_propval_by_name(3PICL)
picl_set_propval_by_name(3PICL)
picl_walk_tree_by_class(3PICL)
pool_get_owning_resource(3POOL)
pool_get_resource_binding(3POOL)
pool_query_pool_resources(3POOL)
pool_query_resource_components(3POOL)
pool_resource_type_list(3POOL)
pool_resource_xtransfer(3POOL)
- resource pool component functions
cc [ flag… ] file… -lpool [ library… ] #include <pool.h> const char *pool_component_info(pool_conf_t *conf, pool_component_t *component, int flags);
pool_resource_t *pool_get_owning_resource(pool_conf_t *conf, pool_component_t *component);
Certain resources, such as processor sets, are composed of resource components. Informational and ownership attributes of resource components are made available with the pool_component_info() and pool_get_owning_resource() functions. The conf argument for each function refers to the target configuration to which the operation applies.
The pool_component_info() function returns a string describing component. The string is allocated with malloc(3C). The caller is reponsible for freeing the returned string. The flags argument is ignored.
The pool_get_owning_resource() function returns the resource currently containing component. Every component is contained by a resource.
Upon successful completion, pool_component_info() returns a string. Otherwise it returns NULL and pool_error(3POOL) returns the pool-specific error value.
Upon successful completion, pool_get_owning_resource() returns the owning resource. Otherwise it returns NULL and pool_error() returns the pool-specific error value.
The pool_component_info() function will fail if:
The supplied configuration's status is not POF_VALID or the flags paramter is neither 0 or 1.
The configuration is invalid.
A system error has occurred. Check the system error code for more details.
The pool_get_owning_resource() function will fail if:
The supplied configuration's status is not POF_VALID.
