Skip Navigation Links
Exit Print View
man pages section 3: Extended Library Functions     Oracle Solaris 10 8/11 Information Library
search filter icon
search icon
Document Information
Preface
Extended Library Functions - Part 1
Extended Library Functions - Part 2
Extended Library Functions - Part 3
Extended Library Functions - Part 4
Extended Library Functions - Part 5
Extended Library Functions - Part 6
sin(3M)
sincos(3M)
sincosf(3M)
sincosl(3M)
sinf(3M)
sinh(3M)
sinhf(3M)
sinhl(3M)
sinl(3M)
smf_degrade_instance(3SCF)
smf_disable_instance(3SCF)
smf_enable_instance(3SCF)
smf_get_state(3SCF)
smf_maintain_instance(3SCF)
smf_refresh_instance(3SCF)
smf_restart_instance(3SCF)
smf_restore_instance(3SCF)
sqrt(3M)
sqrtf(3M)
sqrtl(3M)
SSAAgentIsAlive(3SNMP)
SSAGetTrapPort(3SNMP)
SSAOidCmp(3SNMP)
SSAOidCpy(3SNMP)
SSAOidDup(3SNMP)
SSAOidFree(3SNMP)
SSAOidInit(3SNMP)
SSAOidNew(3SNMP)
SSAOidString(3SNMP)
SSAOidStrToOid(3SNMP)
SSAOidZero(3SNMP)
SSARegSubagent(3SNMP)
SSARegSubtable(3SNMP)
SSARegSubtree(3SNMP)
SSASendTrap(3SNMP)
SSAStringCpy(3SNMP)
SSAStringInit(3SNMP)
SSAStringToChar(3SNMP)
SSAStringZero(3SNMP)
SSASubagentOpen(3SNMP)
stdarg(3EXT)
step(3GEN)
stobclear(3TSOL)
stobl(3TSOL)
stobsl(3TSOL)
strcadd(3GEN)
strccpy(3GEN)
streadd(3GEN)
strecpy(3GEN)
strfind(3GEN)
strrspn(3GEN)
str_to_label(3TSOL)
strtrns(3GEN)
Sun_MP_SendScsiCmd(3MPAPI)
SUNW_C_GetMechSession(3EXT)
SUNW_C_KeyToObject(3EXT)
sysevent_bind_handle(3SYSEVENT)
sysevent_free(3SYSEVENT)
sysevent_get_attr_list(3SYSEVENT)
sysevent_get_class_name(3SYSEVENT)
sysevent_get_pid(3SYSEVENT)
sysevent_get_pub_name(3SYSEVENT)
sysevent_get_seq(3SYSEVENT)
sysevent_get_size(3SYSEVENT)
sysevent_get_subclass_name(3SYSEVENT)
sysevent_get_time(3SYSEVENT)
sysevent_get_vendor_name(3SYSEVENT)
sysevent_post_event(3SYSEVENT)
sysevent_subscribe_event(3SYSEVENT)
sysevent_unbind_handle(3SYSEVENT)
sysevent_unsubscribe_event(3SYSEVENT)
tan(3M)
tanf(3M)
tanh(3M)
tanhf(3M)
tanhl(3M)
tanl(3M)
Task(3PERL)
tgamma(3M)
tgammaf(3M)
tgammal(3M)
tnfctl_buffer_alloc(3TNF)
tnfctl_buffer_dealloc(3TNF)
tnfctl_check_libs(3TNF)
tnfctl_close(3TNF)
tnfctl_continue(3TNF)
tnfctl_exec_open(3TNF)
tnfctl_filter_list_add(3TNF)
tnfctl_filter_list_delete(3TNF)
tnfctl_filter_list_get(3TNF)
tnfctl_filter_state_set(3TNF)
tnfctl_indirect_open(3TNF)
tnfctl_internal_open(3TNF)
tnfctl_kernel_open(3TNF)
tnfctl_pid_open(3TNF)
tnfctl_probe_apply(3TNF)
tnfctl_probe_apply_ids(3TNF)
tnfctl_probe_connect(3TNF)
tnfctl_probe_disable(3TNF)
tnfctl_probe_disconnect_all(3TNF)
tnfctl_probe_enable(3TNF)
tnfctl_probe_state_get(3TNF)
tnfctl_probe_trace(3TNF)
tnfctl_probe_untrace(3TNF)
tnfctl_register_funcs(3TNF)
tnfctl_strerror(3TNF)
tnfctl_trace_attrs_get(3TNF)
tnfctl_trace_state_set(3TNF)
TNF_DEBUG(3TNF)
TNF_DECLARE_RECORD(3TNF)
TNF_DEFINE_RECORD_1(3TNF)
TNF_DEFINE_RECORD_2(3TNF)
TNF_DEFINE_RECORD_3(3TNF)
TNF_DEFINE_RECORD_4(3TNF)
TNF_DEFINE_RECORD_5(3TNF)
TNF_PROBE_0(3TNF)
TNF_PROBE_0_DEBUG(3TNF)
TNF_PROBE_1(3TNF)
TNF_PROBE_1_DEBUG(3TNF)
TNF_PROBE_2(3TNF)
TNF_PROBE_2_DEBUG(3TNF)
TNF_PROBE_3(3TNF)
TNF_PROBE_3_DEBUG(3TNF)
TNF_PROBE(3TNF)
TNF_PROBE_4(3TNF)
TNF_PROBE_4_DEBUG(3TNF)
TNF_PROBE_5(3TNF)
TNF_PROBE_5_DEBUG(3TNF)
tnf_process_disable(3TNF)
tnf_process_enable(3TNF)
tnf_thread_disable(3TNF)
tnf_thread_enable(3TNF)
touchlock(3MAIL)
tracing(3TNF)
trunc(3M)
truncf(3M)
truncl(3M)
tsalarm_get(3EXT)
tsalarm_set(3EXT)
tsol_getrhtype(3TSOL)
tsol_lbuild_create(3TSOL)
tsol_lbuild_destroy(3TSOL)
tsol_lbuild_get(3TSOL)
tsol_lbuild_set(3TSOL)
Ucred(3PERL)
uuid_clear(3UUID)
uuid_compare(3UUID)
uuid_copy(3UUID)
uuid_generate(3UUID)
uuid_generate_random(3UUID)
uuid_generate_time(3UUID)
uuid_is_null(3UUID)
uuid_parse(3UUID)
uuid_time(3UUID)
uuid_unparse(3UUID)
v12n(3EXT)
v12n_capabilities(3EXT)
v12n_chassis_serialno(3EXT)
v12n_ctrl_domain(3EXT)
v12n_domain_name(3EXT)
v12n_domain_roles(3EXT)
v12n_domain_uuid(3EXT)
varargs(3EXT)
vatan2_(3MVEC)
vatan2f_(3MVEC)
vatan_(3MVEC)
vatanf_(3MVEC)
vc_abs_(3MVEC)
vc_exp_(3MVEC)
vc_log_(3MVEC)
vcos_(3MVEC)
vcosf_(3MVEC)
vcospi_(3MVEC)
vcospif_(3MVEC)
vc_pow_(3MVEC)
vexp_(3MVEC)
vexpf_(3MVEC)
vhypot_(3MVEC)
vhypotf_(3MVEC)
vlog_(3MVEC)
vlogf_(3MVEC)
volmgt_acquire(3VOLMGT)
volmgt_check(3VOLMGT)
volmgt_feature_enabled(3VOLMGT)
volmgt_inuse(3VOLMGT)
volmgt_ownspath(3VOLMGT)
volmgt_release(3VOLMGT)
volmgt_root(3VOLMGT)
volmgt_running(3VOLMGT)
volmgt_symdev(3VOLMGT)
volmgt_symname(3VOLMGT)
vpow_(3MVEC)
vpowf_(3MVEC)
vrhypot_(3MVEC)
vrhypotf_(3MVEC)
vrsqrt_(3MVEC)
vrsqrtf_(3MVEC)
vsin_(3MVEC)
vsincos_(3MVEC)
vsincosf_(3MVEC)
vsincospi_(3MVEC)
vsincospif_(3MVEC)
vsinf_(3MVEC)
vsinpi_(3MVEC)
vsinpif_(3MVEC)
vsqrt_(3MVEC)
vsqrtf_(3MVEC)
vz_abs_(3MVEC)
vz_exp_(3MVEC)
vz_log_(3MVEC)
vz_pow_(3MVEC)
write_vtoc(3EXT)
wsreg_add_child_component(3WSREG)
wsreg_add_compatible_version(3WSREG)
wsreg_add_dependent_component(3WSREG)
wsreg_add_display_name(3WSREG)
wsreg_add_required_component(3WSREG)
wsreg_can_access_registry(3WSREG)
wsreg_clone_component(3WSREG)
wsreg_components_equal(3WSREG)
wsreg_create_component(3WSREG)
wsreg_free_component(3WSREG)
wsreg_free_component_array(3WSREG)
wsreg_get(3WSREG)
wsreg_get_all(3WSREG)
wsreg_get_child_components(3WSREG)
wsreg_get_compatible_versions(3WSREG)
wsreg_get_data(3WSREG)
wsreg_get_data_pairs(3WSREG)
wsreg_get_dependent_components(3WSREG)
wsreg_get_display_languages(3WSREG)
wsreg_get_display_name(3WSREG)
wsreg_get_id(3WSREG)
wsreg_get_instance(3WSREG)
wsreg_get_location(3WSREG)
wsreg_get_parent(3WSREG)
wsreg_get_required_components(3WSREG)
wsreg_get_type(3WSREG)
wsreg_get_uninstaller(3WSREG)
wsreg_get_unique_name(3WSREG)
wsreg_get_vendor(3WSREG)
wsreg_get_version(3WSREG)
wsreg_initialize(3WSREG)
wsreg_query_create(3WSREG)
wsreg_query_free(3WSREG)
wsreg_query_get_id(3WSREG)
wsreg_query_get_instance(3WSREG)
wsreg_query_get_location(3WSREG)
wsreg_query_get_unique_name(3WSREG)
wsreg_query_get_version(3WSREG)
wsreg_query_set_id(3WSREG)
wsreg_query_set_instance(3WSREG)
wsreg_query_set_location(3WSREG)
wsreg_query_set_unique_name(3WSREG)
wsreg_query_set_version(3WSREG)
wsreg_register(3WSREG)
wsreg_remove_child_component(3WSREG)
wsreg_remove_compatible_version(3WSREG)
wsreg_remove_dependent_component(3WSREG)
wsreg_remove_display_name(3WSREG)
wsreg_remove_required_component(3WSREG)
wsreg_set_data(3WSREG)
wsreg_set_id(3WSREG)
wsreg_set_instance(3WSREG)
wsreg_set_location(3WSREG)
wsreg_set_parent(3WSREG)
wsreg_set_type(3WSREG)
wsreg_set_uninstaller(3WSREG)
wsreg_set_unique_name(3WSREG)
wsreg_set_vendor(3WSREG)
wsreg_set_version(3WSREG)
wsreg_unregister(3WSREG)
Xbcleartos(3TSOL)
Xbsltos(3TSOL)
XTSOLgetClientAttributes(3XTSOL)
XTSOLgetPropAttributes(3XTSOL)
XTSOLgetPropLabel(3XTSOL)
XTSOLgetPropUID(3XTSOL)
XTSOLgetResAttributes(3XTSOL)
XTSOLgetResLabel(3XTSOL)
XTSOLgetResUID(3XTSOL)
XTSOLgetSSHeight(3XTSOL)
XTSOLgetWorkstationOwner(3XTSOL)
XTSOLIsWindowTrusted(3XTSOL)
XTSOLMakeTPWindow(3XTSOL)
XTSOLsetPolyInstInfo(3XTSOL)
XTSOLsetPropLabel(3XTSOL)
XTSOLsetPropUID(3XTSOL)
XTSOLsetResLabel(3XTSOL)
XTSOLsetResUID(3XTSOL)
XTSOLsetSessionHI(3XTSOL)
XTSOLsetSessionLO(3XTSOL)
XTSOLsetSSHeight(3XTSOL)
XTSOLsetWorkstationOwner(3XTSOL)
y0(3M)
y0f(3M)
y0l(3M)
y1(3M)
y1f(3M)
y1l(3M)
yn(3M)
ynf(3M)
ynl(3M)
volmgt_running
- return whether or not Volume Management is running
Synopsis
cc [ flag ... ] file ... -lvolmgt [ library ... ]
#include <volmgt.h>
int volmgt_running(void);
Description
volmgt_running() tells whether or not Volume Management is running.
Return Values
A non-zero value is returned if Volume Management is running, else 0 is returned.
Errors
volmgt_running() will fail, returning 0, if a stat(2) or open(2) of /dev/volctl fails, or if any of the following is true:
ENXIO
Volume Management is not running.
EINTR
An interrupt signal was detected while checking to see if Volume Management was running.
Examples
Example 1 Using volmgt_running()
To see if Volume Management is running:
if (volmgt_running() != 0) {
        (void) printf("Volume Management is running\n");
} else {
        (void) printf("Volume Management is NOT running\n");
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
MT-Safe
See Also
cc(1B), vold(1M), open(2), stat(2), volmgt_check(3VOLMGT), volmgt_inuse(3VOLMGT), attributes(5), volfs(7FS)
Notes
Volume Management must be running for many of the Volume Management library routines to work.
