Skip Navigation Links | |
Exit Print View | |
Developer's Guide to Oracle Solaris 11 Security Oracle Solaris 11 Information Library |
1. Oracle Solaris Security for Developers (Overview)
2. Developing Privileged Applications
3. Writing PAM Applications and Services
4. Writing Applications That Use GSS-API
7. Writing Applications That Use SASL
8. Introduction to the Oracle Solaris Cryptographic Framework
9. Writing User-Level Cryptographic Applications and Providers
10. Introduction to the Oracle Solaris Key Management Framework
A. Sample C-Based GSS-API Programs
Functions From Previous Versions of GSS-API
Functions for Manipulating OIDs
GSS-API Major Status Code Values
Address Types for Channel Bindings
Implementation-Specific Features in GSS-API
Oracle Solaris-Specific Functions
Implementations of Selected Data Types
Deletion of Contexts and Stored Data
Protection of Channel-Binding Information
Context Exportation and Interprocess Tokens
Types of Credentials Supported
Wrap Size Limits and QOP Values
Messages Returned in Kerberos v5 for Status Code 1
Messages Returned in Kerberos v5 for Status Code 2
Messages Returned in Kerberos v5 for Status Code 3
Messages Returned in Kerberos v5 for Status Code 4
Messages Returned in Kerberos v5 for Status Code 5
Messages Returned in Kerberos v5 for Status Code 6
Messages Returned in Kerberos v5 for Status Code 7
This appendix includes the following sections:
GSS-API Functions provides a table of GSS-API functions.
GSS-API Status Codes discusses status codes returned by GSS-API functions, and provides a list of those status codes.
GSS-API Data Types and Values discusses the various data types used by GSS-API.
Implementation-Specific Features in GSS-API covers features that are unique to the Oracle Solaris implementation of GSS-API.
Kerberos v5 Status Codes lists the status codes that can be returned by the Kerberos v5 mechanism.
Additional GSS-API definitions can be found in the file gssapi.h.
