Skip Navigation Links
Exit Print View
Oracle Solaris Administration: Network Services     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Part I Network Services Topics
1.  Network Service (Overview)
2.  Managing Web Cache Servers
3.  Time-Related Services
Part II Accessing Network File Systems Topics
4.  Managing Network File Systems (Overview)
5.  Network File System Administration (Tasks)
6.  Accessing Network File Systems (Reference)
Part III SLP Topics
7.  SLP (Overview)
8.  Planning and Enabling SLP (Tasks)
9.  Administering SLP (Tasks)
10.  Incorporating Legacy Services
11.  SLP (Reference)
Part IV Mail Services Topics
12.  Mail Services (Overview)
13.  Mail Services (Tasks)
14.  Mail Services (Reference)
Part V Serial Networking Topics
15.  Solaris PPP 4.0 (Overview)
16.  Planning for the PPP Link (Tasks)
17.  Setting Up a Dial-up PPP Link (Tasks)
18.  Setting Up a Leased-Line PPP Link (Tasks)
19.  Setting Up PPP Authentication (Tasks)
20.  Setting Up a PPPoE Tunnel (Tasks)
21.  Fixing Common PPP Problems (Tasks)
22.  Solaris PPP 4.0 (Reference)
Using PPP Options in Files and on the Command Line
Where to Define PPP Options
How PPP Options Are Processed
How PPP Configuration File Privileges Work
User Privileges
File Privileges
Effects of Option Privileges
/etc/ppp/options Configuration File
/etc/ppp/options.tmpl Template
Where to Find Examples of the /etc/ppp/options Files
/etc/ppp/options.ttyname Configuration File
Using /etc/ppp/options.ttyname on a Dial-in Server
Using /etc/ppp/options.ttyname on a Dial-out Machine
options.ttya.tmpl Template File
Where to Find Examples of the /etc/ppp/options.ttyname Files
Configuring User-Specific Options
Configuring $HOME/.ppprc on a Dial-in Server
Configuring $HOME/.ppprc on a Dial-out Machine
Specifying Information for Communicating With the Dial-in Server
/etc/ppp/peers/peer-name File
/etc/ppp/peers/myisp.tmpl Template File
Where to Find Examples of the /etc/ppp/peers/peer-name Files
Configuring Modem Speed for a Dial-up Link
Defining the Conversation on the Dial-up Link
Contents of the Chat Script
Chat Script Examples
Basic Modem Chat Script
/etc/ppp/myisp-chat.tmpl Chat Script Template
Modem Chat Script for Calling an ISP
Basic Chat Script Enhanced for a UNIX-Style Login
Chat Script for External ISDN TA
For More Chat Script Examples
Invoking the Chat Script
How to Invoke a Chat Script (Task)
Creating a Chat File That Is Executable
How to Create an Executable Chat Program
Authenticating Callers on a Link
Password Authentication Protocol (PAP)
/etc/ppp/pap-secrets File
Creating PAP Passwords
What Happens During PAP Authentication
Using the login Option With /etc/ppp/pap-secrets
Challenge-Handshake Authentication Protocol (CHAP)
/etc/ppp/chap-secrets File
What Happens During CHAP Authentication
Creating an IP Addressing Scheme for Callers
Assigning Dynamic IP Addresses to Callers
Assigning Static IP Addresses to Callers
Assigning IP Addresses by sppp Unit Number
Creating PPPoE Tunnels for DSL Support
Files for Configuring Interfaces for PPPoE
/etc/ppp/pppoe.if File
/usr/sbin/sppptun Command
Examples of sppptun Commands for Administering Interfaces
PPPoE Access Server Commands and Files
/usr/lib/inet/pppoed Daemon
/etc/ppp/pppoe File
/etc/ppp/pppoe.device File Plugin
Using PPPoE and PPP Files to Configure an Access Server
PPPoE Client Commands and Files
/usr/lib/inet/pppoec Utility Shared Object
/etc/ppp/peers/peer-name File for Defining an Access Server Peer
23.  Migrating From Asynchronous Solaris PPP to Solaris PPP 4.0 (Tasks)
24.  UUCP (Overview)
25.  Administering UUCP (Tasks)
26.  UUCP (Reference)
Part VI Working With Remote Systems Topics
27.  Working With Remote Systems (Overview)
28.  Administering the FTP Server (Tasks)
29.  Accessing Remote Systems (Tasks)
Part VII Monitoring Network Services Topics
30.  Monitoring Network Performance (Tasks)
To communicate with a dial-in server, you need to gather information about the server. Then edit a few files. Most significantly, you must configure the communications requirements of all dial-in servers that the dial-out machine needs to call. You can specify options about a dial-in server, such as an ISP phone number, in the /etc/ppp/options.ttyname file. However, the optimum place to configure peer information is in /etc/ppp/peers/peer-name files.
Note - The /etc/ppp/peers/peer-name file is not needed on the dial-out machine for Solaris PPP 4.0 to work correctly.
Use the /etc/ppp/peers/peer-name file to provide information for communicating with a particular peer. /etc/ppp/peers/peer-name allows ordinary users to invoke preselected privileged options that users are not allowed to set.
For example, a nonprivileged user cannot override the noauth option if noauth is specified in the /etc/ppp/peers/peer-name file. Suppose the user wants to set up a link to peerB, which does not provide authentication credentials. As superuser, you can create a /etc/ppp/peers/peerB file that includes the noauth option. noauth indicates that the local machine does not authenticate calls from peerB.
The pppd daemon reads /etc/ppp/peers/peer-name when pppd encounters the following option:
call  peer-name
You can create a /etc/ppp/peers/peer-name file for each target peer with which the dial-out machine needs to communicate. This practice is particularly convenient for permitting ordinary users to invoke special dial-out links without needing root privileges.
Typical options that you specify in /etc/ppp/peers/peer-name include the following:
See the pppd(1M) man page for more options that might apply to a specific target peer.
The /etc/ppp/peers/myisp.tmpl file contains helpful comments about the /etc/ppp/peers/peer-name file. The template concludes with common options that you might use for an /etc/ppp/peers/peer-name file:
connect "/usr/bin/chat -f /etc/ppp/myisp-chat"
user myname
remotename myisp
Call the peer by using the chat script /etc/ppp/myisp-chat.
user myname
Use this account name for the local machine. myname is the name for this machine in the peer's /etc/ppp/pap-secrets file.
remotename myisp
Recognize myisp as the name of the peer in the local machine's /etc/ppp/pap-secrets file.
Do not require calling peers to provide authentication credentials.
Do not use a default IP address for the local machine.
Use the default route that is assigned to the local machine.
Log errors in the PPP log files, rather than on the standard output.
Do not use CCP compression.
To use /etc/ppp/peers/myisp.tmpl at your site, rename /etc/ppp/peers/myisp.tmpl to /etc/ppp/peers/.peer-name. Replace peer-name with the name of the peer to be called. Then modify the file contents as needed by your site.
To find examples of the /etc/ppp/peers/peer-name files, refer to the following:
