Skip Navigation Links | |
Exit Print View | |
man pages section 3: Extended Library Functions, Volume 1 Oracle Solaris 11 Information Library |
CIRCLEQ_HEAD_INITIALIZER(3EXT)
cpc_walk_generic_events_all(3CPC)
cpc_walk_generic_events_pic(3CPC)
ct_dev_status_get_aset(3CONTRACT)
ct_dev_status_get_dev_state(3CONTRACT)
ct_dev_status_get_minor(3CONTRACT)
ct_dev_status_get_noneg(3CONTRACT)
ct_dev_tmpl_clear_noneg(3CONTRACT)
ct_dev_tmpl_get_aset(3CONTRACT)
ct_dev_tmpl_get_minor(3CONTRACT)
ct_dev_tmpl_get_noneg(3CONTRACT)
ct_dev_tmpl_set_aset(3CONTRACT)
ct_dev_tmpl_set_minor(3CONTRACT)
ct_dev_tmpl_set_noneg(3CONTRACT)
ct_event_read_critical(3CONTRACT)
ct_pr_event_get_exitstatus(3CONTRACT)
ct_pr_event_get_gcorefile(3CONTRACT)
ct_pr_event_get_pcorefile(3CONTRACT)
ct_pr_event_get_pid(3CONTRACT)
ct_pr_event_get_ppid(3CONTRACT)
ct_pr_event_get_sender(3CONTRACT)
ct_pr_event_get_senderct(3CONTRACT)
ct_pr_event_get_signal(3CONTRACT)
ct_pr_event_get_zcorefile(3CONTRACT)
ct_pr_status_get_contracts(3CONTRACT)
ct_pr_status_get_fatal(3CONTRACT)
ct_pr_status_get_members(3CONTRACT)
ct_pr_status_get_param(3CONTRACT)
ct_pr_status_get_svc_aux(3CONTRACT)
ct_pr_status_get_svc_creator(3CONTRACT)
ct_pr_status_get_svc_ctid(3CONTRACT)
ct_pr_status_get_svc_fmri(3CONTRACT)
ct_pr_tmpl_get_fatal(3CONTRACT)
ct_pr_tmpl_get_param(3CONTRACT)
ct_pr_tmpl_get_svc_aux(3CONTRACT)
ct_pr_tmpl_get_svc_fmri(3CONTRACT)
ct_pr_tmpl_get_transfer(3CONTRACT)
ct_pr_tmpl_set_fatal(3CONTRACT)
ct_pr_tmpl_set_param(3CONTRACT)
ct_pr_tmpl_set_svc_aux(3CONTRACT)
ct_pr_tmpl_set_svc_fmri(3CONTRACT)
ct_pr_tmpl_set_transfer(3CONTRACT)
ct_status_get_cookie(3CONTRACT)
ct_status_get_critical(3CONTRACT)
ct_status_get_holder(3CONTRACT)
ct_status_get_informative(3CONTRACT)
ct_status_get_nevents(3CONTRACT)
ct_status_get_nevid(3CONTRACT)
ct_status_get_ntime(3CONTRACT)
ct_status_get_qtime(3CONTRACT)
ct_status_get_state(3CONTRACT)
ct_status_get_zoneid(3CONTRACT)
ct_tmpl_get_critical(3CONTRACT)
ct_tmpl_get_informative(3CONTRACT)
ct_tmpl_set_critical(3CONTRACT)
ct_tmpl_set_informative(3CONTRACT)
dat_evd_clear_unwaitable(3DAT)
dat_get_consumer_context(3DAT)
dat_registry_add_provider(3DAT)
dat_registry_list_providers(3DAT)
dat_registry_remove_provider(3DAT)
dat_set_consumer_context(3DAT)
devid_deviceid_to_nmlist(3DEVID)
di_link_next_by_lnode(3DEVINFO)
di_link_next_by_node(3DEVINFO)
di_lnode_private_get(3DEVINFO)
di_lnode_private_set(3DEVINFO)
di_minor_private_get(3DEVINFO)
di_minor_private_set(3DEVINFO)
di_path_client_devfs_path(3DEVINFO)
di_path_client_next_path(3DEVINFO)
di_path_phci_next_path(3DEVINFO)
di_path_prop_lookup_bytes(3DEVINFO)
di_path_prop_lookup_int64s(3DEVINFO)
di_path_prop_lookup_ints(3DEVINFO)
di_path_prop_lookup_strings(3DEVINFO)
di_prom_prop_lookup_bytes(3DEVINFO)
di_prom_prop_lookup_ints(3DEVINFO)
di_prom_prop_lookup_strings(3DEVINFO)
di_prop_lookup_bytes(3DEVINFO)
di_prop_lookup_int64(3DEVINFO)
di_prop_lookup_strings(3DEVINFO)
ea_match_object_catalog(3EXACCT)
- access path property information
cc [ flag... ] file... -ldevinfo [ library... ] #include <libdevinfo.h> char *di_path_prop_bytes(di_path_prop_t prop);
int (di_path_prop_t prop);
int (di_path_prop_t prop, uchar_t **prop_data);
int (di_path_prop_t prop, int **prop_data);
int (di_path_prop_t prop, int64_t **prop_data);
int di_path_prop_type(di_path_prop_t prop, char **prop_data);
A handle to a property returned by di_path_prop_next(3DEVINFO).
For di_path_prop_bytes(), the address of a pointer to an unsigned character.
For di_path_prop_ints(), the address of a pointer to an integer.
For di_path_prop_int64(), the address of a pointer to a 64-bit integer.
For di_path_prop_strings(), the address of pointer to a character.
These functions access information associated with path property values and attributes such as the property name or data type.
The di_path_prop_name() function returns a pointer to a string containing the name of the property.
The di_path_prop_type() function returns the type of the path property. The type determines the appropriate interface to access property values. Possible property types are the same as for di_prop_type(3DEVINFO), excluding DI_PROP_TYPE_UNKNOWN and DI_PROP_UNDEFINED. Thus, di_path_prop_type() can return one of the following constants:
Use di_path_prop_ints() to access property data.
Use di_path_prop_int64s() to access property data.
Use di_path_prop_strings() to access property data.
Use di_path_prop_bytes() to access property data.
The di_path_prop_bytes() function returns the property data as a series of unsigned characters.
The di_path_prop_ints() function returns the property data as a series of integers.
The di_path_prop_int64s() function returns the property data as a series of integers.
The di_path_prop_strings() function returns the property data as a concatenation of null-terminated strings.
Upon successful completion, di_path_prop_bytes(), di_path_prop_ints(), di_path_prop_int64s(), and di_path_prop_strings() return a non-negative value, indicating the number of entries in the property value buffer. If the property is found, the number of entries in prop_data is returned. Otherwise, -1 is returned and errno is set to indicate the error.
For di_path_prop_bytes(), the number of entries is the number of unsigned characters contained in the buffer pointed to by prop_data.
For di_path_prop_ints(), the number of entries is the number of integers contained in the buffer pointed to by prop_data.
For di_path_prop_ints(), the number of entries is the number of 64-bit integers contained in the buffer pointed to by prop_data.
For di_path_prop_strings(), the number of entries is the number of null-terminated strings contained in the buffer. The strings are stored in a concatenated format in the buffer.
The di_path_prop_name() function returns the name of the property.
The di_path_prop_type() function can return one of types described in the Description.
These functions will fail if:
One of the arguments is invalid. For example, the property type does not match the interface.
The snapshot contains no property information.
The path property does not exist.
di_path_prop_next(3DEVINFO), di_prop_type(3DEVINFO), libdevinfo(3LIB), attributes(5)
