Skip Navigation Links
Exit Print View
man pages section 3: Extended Library Functions, Volume 4     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Preface
acl_check(3SEC)
aclcheck(3SEC)
acl_free(3SEC)
aclfrommode(3SEC)
acl_fromtext(3SEC)
aclfromtext(3SEC)
acl_get(3SEC)
acl_set(3SEC)
aclsort(3SEC)
acl_strip(3SEC)
acltomode(3SEC)
acl_totext(3SEC)
acltotext(3SEC)
acl_trivial(3SEC)
bcleartoh(3TSOL)
bcleartoh_r(3TSOL)
bcleartos(3TSOL)
blcompare(3TSOL)
bldominates(3TSOL)
blequal(3TSOL)
blinrange(3TSOL)
blmaximum(3TSOL)
blminimum(3TSOL)
blminmax(3TSOL)
blstrictdom(3TSOL)
bltocolor(3TSOL)
bltocolor_r(3TSOL)
bltos(3TSOL)
bsltoh(3TSOL)
bsltoh_r(3TSOL)
bsltos(3TSOL)
btohex(3TSOL)
cfc_file_start(3TECLA)
cfc_literal_escapes(3TECLA)
cfc_set_check_fn(3TECLA)
cpl_add_completion(3TECLA)
cpl_check_exe(3TECLA)
cpl_complete_word(3TECLA)
cpl_file_completions(3TECLA)
cpl_last_error(3TECLA)
cpl_list_completions(3TECLA)
cpl_recall_matches(3TECLA)
cpl_record_error(3TECLA)
del_CplFileConf(3TECLA)
del_ExpandFile(3TECLA)
del_GetLine(3TECLA)
del_PathCache(3TECLA)
del_PcaPathConf(3TECLA)
del_WordCompletion(3TECLA)
ef_expand_file(3TECLA)
ef_last_error(3TECLA)
ef_list_expansions(3TECLA)
facl_get(3SEC)
facl_set(3SEC)
getpathbylabel(3TSOL)
getplabel(3TSOL)
getuserrange(3TSOL)
getzoneidbylabel(3TSOL)
getzonelabelbyid(3TSOL)
getzonelabelbyname(3TSOL)
getzonerootbyid(3TSOL)
getzonerootbylabel(3TSOL)
getzonerootbyname(3TSOL)
gl_abandon_line(3TECLA)
gl_append_history(3TECLA)
gl_automatic_history(3TECLA)
gl_bind_keyseq(3TECLA)
gl_catch_blocked(3TECLA)
gl_change_terminal(3TECLA)
gl_clear_history(3TECLA)
gl_completion_action(3TECLA)
gl_configure_getline(3TECLA)
gl_customize_completion(3TECLA)
gl_display_text(3TECLA)
gl_echo_mode(3TECLA)
gl_erase_terminal(3TECLA)
gl_error_message(3TECLA)
gl_get_line(3TECLA)
gl_group_history(3TECLA)
gl_handle_signal(3TECLA)
gl_ignore_signal(3TECLA)
gl_inactivity_timeout(3TECLA)
gl_io_mode(3TECLA)
gl_last_signal(3TECLA)
gl_limit_history(3TECLA)
gl_list_signals(3TECLA)
gl_load_history(3TECLA)
gl_lookup_history(3TECLA)
gl_normal_io(3TECLA)
gl_pending_io(3TECLA)
gl_prompt_style(3TECLA)
gl_query_char(3TECLA)
gl_range_of_history(3TECLA)
gl_raw_io(3TECLA)
gl_read_char(3TECLA)
gl_register_action(3TECLA)
gl_replace_prompt(3TECLA)
gl_resize_history(3TECLA)
gl_return_status(3TECLA)
gl_save_history(3TECLA)
gl_set_term_size(3TECLA)
gl_show_history(3TECLA)
gl_size_of_history(3TECLA)
gl_state_of_history(3TECLA)
gl_terminal_size(3TECLA)
gl_toggle_history(3TECLA)
gl_trap_signal(3TECLA)
gl_tty_signals(3TECLA)
gl_watch_fd(3TECLA)
h_alloc(3TSOL)
hextob(3TSOL)
h_free(3TSOL)
htobclear(3TSOL)
htobsl(3TSOL)
labelclipping(3TSOL)
label_to_str(3TSOL)
libtecla_version(3TECLA)
media_findname(3VOLMGT)
media_getattr(3VOLMGT)
media_getid(3VOLMGT)
media_setattr(3VOLMGT)
m_label(3TSOL)
m_label_alloc(3TSOL)
m_label_dup(3TSOL)
m_label_free(3TSOL)
new_CplFileConf(3TECLA)
new_ExpandFile(3TECLA)
new_GetLine(3TECLA)
new_PathCache(3TECLA)
new_PcaPathConf(3TECLA)
new_WordCompletion(3TECLA)
pca_last_error(3TECLA)
pca_lookup_file(3TECLA)
pca_path_completions(3TECLA)
pca_scan_path(3TECLA)
pca_set_check_fn(3TECLA)
ppc_file_start(3TECLA)
ppc_literal_escapes(3TECLA)
sbcleartos(3TSOL)
sbltos(3TSOL)
sbsltos(3TSOL)
scf_count_ranges_destroy(3SCF)
scf_decoration_create(3SCF)
scf_decoration_destroy(3SCF)
scf_decoration_get_bundle(3SCF)
scf_decoration_get_layer(3SCF)
scf_decoration_get_value(3SCF)
scf_decoration_handle(3SCF)
scf_decoration_is_type(3SCF)
scf_decoration_layer_from_string(3SCF)
scf_decoration_layer_to_string(3SCF)
scf_decoration_type(3SCF)
scf_entry_add_value(3SCF)
scf_entry_create(3SCF)
scf_entry_destroy(3SCF)
scf_entry_destroy_children(3SCF)
scf_entry_handle(3SCF)
scf_entry_reset(3SCF)
scf_error(3SCF)
scf_handle_bind(3SCF)
scf_handle_create(3SCF)
scf_handle_decode_fmri(3SCF)
scf_handle_decorate(3SCF)
scf_handle_destroy(3SCF)
scf_handle_get_scope(3SCF)
scf_handle_unbind(3SCF)
scf_instance_add_pg(3SCF)
scf_instance_create(3SCF)
scf_instance_delcust(3SCF)
scf_instance_delete(3SCF)
scf_instance_destroy(3SCF)
scf_instance_get_decoration(3SCF)
scf_instance_get_name(3SCF)
scf_instance_get_parent(3SCF)
scf_instance_get_pg(3SCF)
scf_instance_get_pg_composed(3SCF)
scf_instance_get_snapshot(3SCF)
scf_instance_handle(3SCF)
scf_instance_is_complete(3SCF)
scf_instance_is_masked(3SCF)
scf_instance_to_fmri(3SCF)
scf_int_ranges_destroy(3SCF)
scf_iter_create(3SCF)
scf_iter_decoration_values(3SCF)
scf_iter_destroy(3SCF)
scf_iter_handle(3SCF)
scf_iter_handle_scopes(3SCF)
scf_iter_instance_decorations(3SCF)
scf_iter_instance_pgs(3SCF)
scf_iter_instance_pgs_composed(3SCF)
scf_iter_instance_pgs_typed(3SCF)
scf_iter_instance_pgs_typed_composed(3SCF)
scf_iter_instance_snapshots(3SCF)
scf_iter_next_decoration(3SCF)
scf_iter_next_instance(3SCF)
scf_iter_next_pg(3SCF)
scf_iter_next_property(3SCF)
scf_iter_next_scope(3SCF)
scf_iter_next_service(3SCF)
scf_iter_next_snapshot(3SCF)
scf_iter_next_value(3SCF)
scf_iter_pg_decorations(3SCF)
scf_iter_pg_properties(3SCF)
scf_iter_property_decorations(3SCF)
scf_iter_property_values(3SCF)
scf_iter_reset(3SCF)
scf_iter_scope_services(3SCF)
scf_iter_service_decorations(3SCF)
scf_iter_service_instances(3SCF)
scf_iter_service_pgs(3SCF)
scf_iter_service_pgs_typed(3SCF)
scf_iter_snaplevel_pgs(3SCF)
scf_iter_snaplevel_pgs_typed(3SCF)
scf_limit(3SCF)
scf_myname(3SCF)
scf_pg_create(3SCF)
scf_pg_delcust(3SCF)
scf_pg_delete(3SCF)
scf_pg_destroy(3SCF)
scf_pg_get_decoration(3SCF)
scf_pg_get_flags(3SCF)
scf_pg_get_name(3SCF)
scf_pg_get_parent_instance(3SCF)
scf_pg_get_parent_service(3SCF)
scf_pg_get_parent_snaplevel(3SCF)
scf_pg_get_property(3SCF)
scf_pg_get_type(3SCF)
scf_pg_get_underlying_pg(3SCF)
scf_pg_handle(3SCF)
scf_pg_is_masked(3SCF)
scf_pg_to_fmri(3SCF)
scf_pg_update(3SCF)
scf_property_create(3SCF)
scf_property_delcust(3SCF)
scf_property_destroy(3SCF)
scf_property_get_decoration(3SCF)
scf_property_get_name(3SCF)
scf_property_get_value(3SCF)
scf_property_get_value_at_layer(3SCF)
scf_property_handle(3SCF)
scf_property_is_masked(3SCF)
scf_property_is_type(3SCF)
scf_property_to_fmri(3SCF)
scf_property_type(3SCF)
scf_scope_add_service(3SCF)
scf_scope_create(3SCF)
scf_scope_destroy(3SCF)
scf_scope_get_name(3SCF)
scf_scope_get_service(3SCF)
scf_scope_handle(3SCF)
scf_scope_to_fmri(3SCF)
scf_service_add_instance(3SCF)
scf_service_add_pg(3SCF)
scf_service_create(3SCF)
scf_service_delcust(3SCF)
scf_service_delete(3SCF)
scf_service_destroy(3SCF)
scf_service_get_decoration(3SCF)
scf_service_get_instance(3SCF)
scf_service_get_name(3SCF)
scf_service_get_parent(3SCF)
scf_service_get_pg(3SCF)
scf_service_handle(3SCF)
scf_service_is_masked(3SCF)
scf_service_to_fmri(3SCF)
scf_simple_app_props_free(3SCF)
scf_simple_app_props_get(3SCF)
scf_simple_app_props_next(3SCF)
scf_simple_app_props_search(3SCF)
scf_simple_prop_free(3SCF)
scf_simple_prop_get(3SCF)
scf_simple_prop_name(3SCF)
scf_simple_prop_next_astring(3SCF)
scf_simple_prop_next_boolean(3SCF)
scf_simple_prop_next_count(3SCF)
scf_simple_prop_next_integer(3SCF)
scf_simple_prop_next_opaque(3SCF)
scf_simple_prop_next_reset(3SCF)
scf_simple_prop_next_time(3SCF)
scf_simple_prop_next_ustring(3SCF)
scf_simple_prop_numvalues(3SCF)
scf_simple_prop_pgname(3SCF)
scf_simple_prop_type(3SCF)
scf_simple_walk_instances(3SCF)
scf_snaplevel_create(3SCF)
scf_snaplevel_destroy(3SCF)
scf_snaplevel_get_instance_name(3SCF)
scf_snaplevel_get_next_snaplevel(3SCF)
scf_snaplevel_get_parent(3SCF)
scf_snaplevel_get_pg(3SCF)
scf_snaplevel_get_scope_name(3SCF)
scf_snaplevel_get_service_name(3SCF)
scf_snaplevel_handle(3SCF)
scf_snapshot_create(3SCF)
scf_snapshot_destroy(3SCF)
scf_snapshot_get_base_snaplevel(3SCF)
scf_snapshot_get_name(3SCF)
scf_snapshot_get_parent(3SCF)
scf_snapshot_handle(3SCF)
scf_snapshot_update(3SCF)
scf_strerror(3SCF)
scf_string_to_type(3SCF)
scf_tmpl_error_pg(3SCF)
scf_tmpl_error_pg_tmpl(3SCF)
scf_tmpl_error_prop(3SCF)
scf_tmpl_error_prop_tmpl(3SCF)
scf_tmpl_errors_destroy(3SCF)
scf_tmpl_error_source_fmri(3SCF)
scf_tmpl_error_type(3SCF)
scf_tmpl_error_value(3SCF)
scf_tmpl_get_by_pg(3SCF)
scf_tmpl_get_by_pg_name(3SCF)
scf_tmpl_get_by_prop(3SCF)
scf_tmpl_iter_pgs(3SCF)
scf_tmpl_iter_props(3SCF)
scf_tmpl_next_error(3SCF)
scf_tmpl_pg_common_name(3SCF)
scf_tmpl_pg_create(3SCF)
scf_tmpl_pg_description(3SCF)
scf_tmpl_pg_destroy(3SCF)
scf_tmpl_pg_name(3SCF)
scf_tmpl_pg_required(3SCF)
scf_tmpl_pg_reset(3SCF)
scf_tmpl_pg_target(3SCF)
scf_tmpl_pg_type(3SCF)
scf_tmpl_prop_cardinality(3SCF)
scf_tmpl_prop_common_name(3SCF)
scf_tmpl_prop_create(3SCF)
scf_tmpl_prop_description(3SCF)
scf_tmpl_prop_destroy(3SCF)
scf_tmpl_prop_internal_seps(3SCF)
scf_tmpl_prop_name(3SCF)
scf_tmpl_prop_required(3SCF)
scf_tmpl_prop_reset(3SCF)
scf_tmpl_prop_type(3SCF)
scf_tmpl_prop_units(3SCF)
scf_tmpl_prop_visibility(3SCF)
scf_tmpl_reset_errors(3SCF)
scf_tmpl_strerror(3SCF)
scf_tmpl_validate_fmri(3SCF)
scf_tmpl_value_common_name(3SCF)
scf_tmpl_value_count_range_choices(3SCF)
scf_tmpl_value_count_range_constraints(3SCF)
scf_tmpl_value_description(3SCF)
scf_tmpl_value_in_constraint(3SCF)
scf_tmpl_value_int_range_choices(3SCF)
scf_tmpl_value_int_range_constraints(3SCF)
scf_tmpl_value_name_choices(3SCF)
scf_tmpl_value_name_constraints(3SCF)
scf_tmpl_visibility_to_string(3SCF)
scf_transaction_commit(3SCF)
scf_transaction_create(3SCF)
scf_transaction_destroy(3SCF)
scf_transaction_destroy_children(3SCF)
scf_transaction_handle(3SCF)
scf_transaction_property_change(3SCF)
scf_transaction_property_change_type(3SCF)
scf_transaction_property_delete(3SCF)
scf_transaction_property_new(3SCF)
scf_transaction_reset(3SCF)
scf_transaction_reset_all(3SCF)
scf_transaction_start(3SCF)
scf_type_base_type(3SCF)
scf_type_to_string(3SCF)
scf_value_base_type(3SCF)
scf_value_create(3SCF)
scf_value_destroy(3SCF)
scf_value_get_as_string(3SCF)
scf_value_get_as_string_typed(3SCF)
scf_value_get_astring(3SCF)
scf_value_get_boolean(3SCF)
scf_value_get_count(3SCF)
scf_value_get_integer(3SCF)
scf_value_get_opaque(3SCF)
scf_value_get_time(3SCF)
scf_value_get_ustring(3SCF)
scf_value_handle(3SCF)
scf_value_is_type(3SCF)
scf_value_reset(3SCF)
scf_values_destroy(3SCF)
scf_value_set_astring(3SCF)
scf_value_set_boolean(3SCF)
scf_value_set_count(3SCF)
scf_value_set_from_string(3SCF)
scf_value_set_integer(3SCF)
scf_value_set_opaque(3SCF)
scf_value_set_time(3SCF)
scf_value_set_ustring(3SCF)
scf_value_type(3SCF)
setflabel(3TSOL)
smf_degrade_instance(3SCF)
smf_disable_instance(3SCF)
smf_enable_instance(3SCF)
smf_get_state(3SCF)
smf_maintain_instance(3SCF)
smf_notify_del_params(3SCF)
smf_notify_get_params(3SCF)
smf_notify_set_params(3SCF)
smf_refresh_instance(3SCF)
smf_restart_instance(3SCF)
smf_restore_instance(3SCF)
smf_state_from_string(3SCF)
smf_state_to_string(3SCF)
srpt_GetDefaultState(3SRPT)
srpt_GetTargetState(3SRPT)
srpt_ResetTarget(3SRPT)
srpt_SetDefaultState(3SRPT)
srpt_SetTargetState(3SRPT)
SSAAgentIsAlive(3SNMP)
SSAGetTrapPort(3SNMP)
SSAOidCmp(3SNMP)
SSAOidCpy(3SNMP)
SSAOidDup(3SNMP)
SSAOidFree(3SNMP)
SSAOidInit(3SNMP)
SSAOidNew(3SNMP)
SSAOidString(3SNMP)
SSAOidStrToOid(3SNMP)
SSAOidZero(3SNMP)
SSARegSubagent(3SNMP)
SSARegSubtable(3SNMP)
SSARegSubtree(3SNMP)
SSASendTrap(3SNMP)
SSAStringCpy(3SNMP)
SSAStringInit(3SNMP)
SSAStringToChar(3SNMP)
SSAStringZero(3SNMP)
SSASubagentOpen(3SNMP)
stmfAddToHostGroup(3STMF)
stmfAddToTargetGroup(3STMF)
stmfAddViewEntry(3STMF)
stmfCheckHostGroupInUse(3STMF)
stmfCheckTargetGroupInUse(3STMF)
stmfClearProviderData(3STMF)
stmfCreateHostGroup(3STMF)
stmfCreateLu(3STMF)
stmfCreateLuResource(3STMF)
stmfCreateTargetGroup(3STMF)
stmfDeleteHostGroup(3STMF)
stmfDeleteLu(3STMF)
stmfDeleteTargetGroup(3STMF)
stmfDestroyProxyDoor(3STMF)
stmfDevidFromIscsiName(3STMF)
stmfDevidFromWwn(3STMF)
stmfFreeLuResource(3STMF)
stmfFreeMemory(3STMF)
stmfGetAluaState(3STMF)
stmfGetHostGroupList(3STMF)
stmfGetHostGroupMembers(3STMF)
stmfGetLogicalUnitList(3STMF)
stmfGetLogicalUnitProperties(3STMF)
stmfGetLuProp(3STMF)
stmfGetLuResource(3STMF)
stmfGetPersistMethod(3STMF)
stmfGetProviderData(3STMF)
stmfGetProviderDataProt(3STMF)
stmfGetState(3STMF)
stmfGetStmfProp(3STMF)
stmfGetTargetGroupList(3STMF)
stmfGetTargetGroupMembers(3STMF)
stmfGetTargetList(3STMF)
stmfGetTargetProperties(3STMF)
stmfGetViewEntryList(3STMF)
stmfImportLu(3STMF)
stmfInitProxyDoor(3STMF)
stmfLuStandby(3STMF)
stmfModifyLu(3STMF)
stmfModifyLuByFname(3STMF)
stmfOfflineLogicalUnit(3STMF)
stmfOfflineTarget(3STMF)
stmfOnlineLogicalUnit(3STMF)
stmfOnlineTarget(3STMF)
stmfPostProxyMsg(3STMF)
stmfRemoveFromHostGroup(3STMF)
stmfRemoveFromTargetGroup(3STMF)
stmfRemoveViewEntry(3STMF)
stmfSetAluaState(3STMF)
stmfSetLuProp(3STMF)
stmfSetPersistMethod(3STMF)
stmfSetProviderData(3STMF)
stmfSetProviderDataProt(3STMF)
stmfSetStmfProp(3STMF)
stmfValidateView(3STMF)
stobclear(3TSOL)
stobl(3TSOL)
stobsl(3TSOL)
str_to_label(3TSOL)
sysevent_bind_handle(3SYSEVENT)
sysevent_free(3SYSEVENT)
sysevent_get_attr_list(3SYSEVENT)
sysevent_get_class_name(3SYSEVENT)
sysevent_get_pid(3SYSEVENT)
sysevent_get_pub_name(3SYSEVENT)
sysevent_get_seq(3SYSEVENT)
sysevent_get_size(3SYSEVENT)
sysevent_get_subclass_name(3SYSEVENT)
sysevent_get_time(3SYSEVENT)
sysevent_get_vendor_name(3SYSEVENT)
sysevent_post_event(3SYSEVENT)
sysevent_subscribe_event(3SYSEVENT)
sysevent_unbind_handle(3SYSEVENT)
sysevent_unsubscribe_event(3SYSEVENT)
tsol_getrhtype(3TSOL)
uuid_clear(3UUID)
uuid_compare(3UUID)
uuid_copy(3UUID)
uuid_generate(3UUID)
uuid_generate_random(3UUID)
uuid_generate_time(3UUID)
uuid_is_null(3UUID)
uuid_parse(3UUID)
uuid_time(3UUID)
uuid_unparse(3UUID)
volmgt_acquire(3VOLMGT)
volmgt_check(3VOLMGT)
volmgt_feature_enabled(3VOLMGT)
volmgt_inuse(3VOLMGT)
volmgt_ownspath(3VOLMGT)
volmgt_release(3VOLMGT)
volmgt_root(3VOLMGT)
volmgt_running(3VOLMGT)
volmgt_symdev(3VOLMGT)
volmgt_symname(3VOLMGT)
wsreg_add_child_component(3WSREG)
wsreg_add_compatible_version(3WSREG)
wsreg_add_dependent_component(3WSREG)
wsreg_add_display_name(3WSREG)
wsreg_add_required_component(3WSREG)
wsreg_can_access_registry(3WSREG)
wsreg_clone_component(3WSREG)
wsreg_components_equal(3WSREG)
wsreg_create_component(3WSREG)
wsreg_free_component(3WSREG)
wsreg_free_component_array(3WSREG)
wsreg_get(3WSREG)
wsreg_get_all(3WSREG)
wsreg_get_child_components(3WSREG)
wsreg_get_compatible_versions(3WSREG)
wsreg_get_data(3WSREG)
wsreg_get_data_pairs(3WSREG)
wsreg_get_dependent_components(3WSREG)
wsreg_get_display_languages(3WSREG)
wsreg_get_display_name(3WSREG)
wsreg_get_id(3WSREG)
wsreg_get_instance(3WSREG)
wsreg_get_location(3WSREG)
wsreg_get_parent(3WSREG)
wsreg_get_required_components(3WSREG)
wsreg_get_type(3WSREG)
wsreg_get_uninstaller(3WSREG)
wsreg_get_unique_name(3WSREG)
wsreg_get_vendor(3WSREG)
wsreg_get_version(3WSREG)
wsreg_initialize(3WSREG)
wsreg_query_create(3WSREG)
wsreg_query_free(3WSREG)
wsreg_query_get_id(3WSREG)
wsreg_query_get_instance(3WSREG)
wsreg_query_get_location(3WSREG)
wsreg_query_get_unique_name(3WSREG)
wsreg_query_get_version(3WSREG)
wsreg_query_set_id(3WSREG)
wsreg_query_set_instance(3WSREG)
wsreg_query_set_location(3WSREG)
wsreg_query_set_unique_name(3WSREG)
wsreg_query_set_version(3WSREG)
wsreg_register(3WSREG)
wsreg_remove_child_component(3WSREG)
wsreg_remove_compatible_version(3WSREG)
wsreg_remove_dependent_component(3WSREG)
wsreg_remove_display_name(3WSREG)
wsreg_remove_required_component(3WSREG)
wsreg_set_data(3WSREG)
wsreg_set_id(3WSREG)
wsreg_set_instance(3WSREG)
wsreg_set_location(3WSREG)
wsreg_set_parent(3WSREG)
wsreg_set_type(3WSREG)
wsreg_set_uninstaller(3WSREG)
wsreg_set_unique_name(3WSREG)
wsreg_set_vendor(3WSREG)
wsreg_set_version(3WSREG)
wsreg_unregister(3WSREG)
Xbcleartos(3TSOL)
Xbsltos(3TSOL)
XTSOLgetClientAttributes(3XTSOL)
XTSOLgetPropAttributes(3XTSOL)
XTSOLgetPropLabel(3XTSOL)
XTSOLgetPropUID(3XTSOL)
XTSOLgetResAttributes(3XTSOL)
XTSOLgetResLabel(3XTSOL)
XTSOLgetResUID(3XTSOL)
XTSOLgetSSHeight(3XTSOL)
XTSOLgetWorkstationOwner(3XTSOL)
XTSOLIsWindowTrusted(3XTSOL)
XTSOLMakeTPWindow(3XTSOL)
XTSOLsetPolyInstInfo(3XTSOL)
XTSOLsetPropLabel(3XTSOL)
XTSOLsetPropUID(3XTSOL)
XTSOLsetResLabel(3XTSOL)
XTSOLsetResUID(3XTSOL)
XTSOLsetSessionHI(3XTSOL)
XTSOLsetSessionLO(3XTSOL)
XTSOLsetSSHeight(3XTSOL)
XTSOLsetWorkstationOwner(3XTSOL)
zs_close(3ZONESTAT)
zs_open(3ZONESTAT)
zs_property(3ZONESTAT)
zs_property_double(3ZONESTAT)
zs_property_int(3ZONESTAT)
zs_property_int64(3ZONESTAT)
zs_property_string(3ZONESTAT)
zs_property_type(3ZONESTAT)
zs_property_uint(3ZONESTAT)
zs_property_uint64(3ZONESTAT)
zs_pset(3ZONESTAT)
zs_pset_list(3ZONESTAT)
zs_pset_property(3ZONESTAT)
zs_pset_total_cpus(3ZONESTAT)
zs_pset_total_time(3ZONESTAT)
zs_pset_used_cpus(3ZONESTAT)
zs_pset_used_pct(3ZONESTAT)
zs_pset_used_time(3ZONESTAT)
zs_pset_walk(3ZONESTAT)
zs_pset_zone(3ZONESTAT)
zs_pset_zone_get_pset(3ZONESTAT)
zs_pset_zone_get_zone(3ZONESTAT)
zs_pset_zone_list(3ZONESTAT)
zs_pset_zone_property(3ZONESTAT)
zs_pset_zone_used_cpus(3ZONESTAT)
zs_pset_zone_used_pct(3ZONESTAT)
zs_pset_zone_used_time(3ZONESTAT)
zs_pset_zone_walk(3ZONESTAT)
zs_resource(3ZONESTAT)
zs_resource_property(3ZONESTAT)
zs_resource_total_time(3ZONESTAT)
zs_resource_total_uint64(3ZONESTAT)
zs_resource_type(3ZONESTAT)
zs_resource_used_pct(3ZONESTAT)
zs_resource_used_time(3ZONESTAT)
zs_resource_used_uint64(3ZONESTAT)
zs_resource_used_zone_pct(3ZONESTAT)
zs_resource_used_zone_time(3ZONESTAT)
zs_resource_used_zone_uint64(3ZONESTAT)
zs_usage(3ZONESTAT)
zs_usage_diff(3ZONESTAT)
zs_usage_free(3ZONESTAT)
zs_usage_read(3ZONESTAT)
zs_zone(3ZONESTAT)
zs_zone_limit_time(3ZONESTAT)
zs_zone_limit_type(3ZONESTAT)
zs_zone_limit_uint64(3ZONESTAT)
zs_zone_limit_used_pct(3ZONESTAT)
zs_zone_limit_used_time(3ZONESTAT)
zs_zone_limit_used_uint64(3ZONESTAT)
zs_zone_list(3ZONESTAT)
zs_zone_property(3ZONESTAT)
zs_zone_walk(3ZONESTAT)
zs_usage
, zs_usage_read
, zs_usage_diff
, zs_usage_free
- read system configuration and utilization
Synopsis
cc [ flag ... ] file... -lzonestat [ libary ... ]
#include <zonestat.h>
zs_usage_t zs_usage_read(zs_ctl_t zsctl);
zs_usage_t zs_usage_diff(zs_usage_t u1, zs_usage_t u2);
void zs_usage_free(zs_usage_t zsctl);
Description
The zs_usage_read() function reads the system configuration and utilization with respect to zones, memory, and CPU.
Each zs_usage_read() will return a zs_usage_t object, which includes the following information:
Increasing utilization values are described libzonestat(3LIB). Increasing values continually increase, starting at zero from the point at which zs_open(3ZONESTAT) was first called.
For all other utilization values, utilization information will be the usage at the point in time at which zs_usage_read() is called.
For zones and processors sets that were booted or created after zs_open() was called, the increasing usage values will be usage since the most recent boot or creation before the call to zs_usage_read().
The zs_usage_diff() function computes and returns the utilization differences between two zs_usage_t objects returned by zs_usage_read(). Both u1 and u2 must be read from the same zsctl object. u2 must be read after u1.
The purpose of zs_usage_diff() is to simplify the comparison of zs_usage_read() calls made at a interval.
The returned zs_usage_t object will contain:
The zs_usage_free() function frees the memory associated with a zs_usage_t object returned by zs_usage_read() or zs_usage_diff().
Return Values
On success, zs_usage_free() and zs_usage_diff() return a pointer to a zonestat usage object. On failure, zs_open() returns NULL.
Errors
The zs_usage_diff() function will fail if:
EAGAIN
Insufficient resources are available.
ENOMEM
Insufficient memory is available.
The zs_usage_read() function will fail if:
EAGAIN
EINTR
A signal was caught.
ENOMEM
ESRCH
Unable to connect to the zones monitoring service. See Notes.
Examples
Example 1 Read zone CPU utilization.
The following example uses zs_usage_read() to read each zones CPU utilization at a regular interval.
extern int time_to_quit; /* hypothetical quit notification */
zs_ctl_t ctl;
zs_usage_t last;
zs_usage_t next;
zs_usage_t diff;
zs_zone_t zone;
timestruct_t time;
uint64_t cpus;
ctl = zs_usage_open();  /* Open zone statistics */
last = zs_usage_read(); /* Read initial usage */
for (;;) {
        sleep(10);
        next = zs_usage_read();
        diff = zs_usage_diff(last, next);
        /* Walk zones in usage data */
        for (zone = zs_zone_first(diff); zone != NULL ;
            zone = zs_zone_next(diff, zone)) {
                 * fetch cpu time used by zone over interval in terms of
                 * seconds and nanoseconds
                zs_resource_used_zone_time(zone, ZS_RESOURCE_CPU,
                    &time);
                 * cpu used.  100 equals one cpu.  For example, a
                 * value of 250 means the zone used 2.5 cpus worth of
                 * time between last and next.
                zs_resource_used_zone_uint64(zone, ZS_RESOURCE_CPU,
                    &cpus;
        zs_usage_free(diff);
        zs_usage_free(last);
        last = next;
        if (time_to_quit)
                break;
zs_usage_free(last)
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
See below.
The zs_usage_*() functions are MT-safe, with the exception that only one thread may actively use a zs_ctl_t * object at any time. Synchronization is left to the application.
See Also
zonestat(1), pooladm(1M), psrset(1M), rcapadm(1M), swap(1M), zoneadm(1M), zonestatd(1M), libpool(3LIB), libzonestat(3LIB), zs_open(3ZONESTAT), zs_pset(3ZONESTAT), zs_property(3ZONESTAT), zs_pset_zone(3ZONESTAT), zs_resource(3ZONESTAT), zs_zone(3ZONESTAT), attributes(5), resource_controls(5)
Notes
The service svc:/system/zones-monitoring:default must be enabled in the global zone in order for zs_usage_read() to succeed. This requirement exists for use of libzonestat(3LIB) in both the global zone and non-global zones.
If the zones-monitoring service goes off line, ESRCH will be returned. At this point the zsctl object is no longer usable. Use zs_close(zsctl) and use zs_open(3ZONESTAT) to reconnect.
