Skip Navigation Links
Exit Print View
Sun Storage Common Array Manager
Software Release Notes, Release 6.9.0 Update
search filter icon
search icon
Document Information
1.  Sun Storage Common Array Manager Software Release Notes
What's New in This Update
How to Get the Software
For Product Information...
What You Get with the Software
Security Advisory
Licensing Optional Premium Features
90-day Evaluation Licenses
System Requirements
Supported Arrays
Supported Web Browsers
Best Practices for Browser Performance
Supported Languages
Supported Operating Systems
2500 Arrays Upgrade
2500 Array Support for VMware ESX 4.1 with Firmware and later
6540, 6140, and FLX380 Arrays Upgrade
J4000 Arrays
Sun Blade 6000 Disk Module
Sun Storage F5100 Flash Array Notes
Supported Expansion Modules
Notable Fixes
Known Issues
Array Issues
Create Snapshot fails using CLI
Controller Smart battery replacement procedure
Array loses communication during registration when IPV6 is enabled
Ancient I/O rebooting due to cache block size
AIX host type for 6140 arrays
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Communication Loss reported from Windows and Linux when registering JBODs on Oracle Enterprise Linux 6 proxy
Reboots occur due to ancient I/O being aborted in large configurations
Volume errorevShowVol output: Initialization: Not Completed
Configuration Issues
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
No email notification for critical and above events
Access Configuration: Cascaded J4400 issues
Access Configuration: Sun Storage 6Gb SAS HBA—OS hangs
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Documentation Issues
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware Update Issues
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade error: No such expander - 50800200006deabf SIGSEGV in Linux
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Premium Feature Issues
Performance Enhancer for 2500-M2
Enabling Try and Buy license using the CLI
Linux Issues
“Require-Stop” not working in SUSE11.1 innserv jexec init.d script
Logging in to CAM on SUSE11 using invalid password
Adding or removing SATA drives requires host boot
Sun Storage J4000 and F5100 Flash arrays—Linux hot plug issues
Solaris Issues
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
Windows Issues
Add License error using the CLI
Support Data does not save using Windows 2008 R2 SP1 Servers
Contacting Support
System Requirements
System requirements for Sun Storage Common Array Manager software are described in the following sections:
Supported Arrays
Sun Storage Common Array Manager software supports the following Sun storage systems:
Table 1-3 Supported Web Browsers
Supported Version
3.0 and higher
Microsoft Internet Explorer
9.0, 8.0
For best web browser performance:
Supported Languages
Because locales are part of the installation, there is no need to download additional software other than appropriate patches.
For Solaris, Linux, and Windows, the Browser User Interface (BUI) is available in:
Command-line interface (CLI) is available in:
Online help is available in:
Man pages are available in:
See How to Get the Software for instructions on downloading patches.
To obtain patches using Solaris, install Solaris 10 Update 9.
The mpt_sas driver requires these patches:
The mpt_sas driver also requires this Solaris 10 update:
See for information about LSI HBA packages.
Table 1-4 Management Host Operating System Support
Operating System
OS Version
Solaris OS
Solaris 10 OS U10 and U9
Solaris 11 Express 2010.11
Sun Storage F5100 array support only
Oracle Linux 6.0, 5.6, and 5.5
Supports UEK as a kernel option.
Before installing CAM on Oracle Linux 6.0 hosts, you must install the packages listed in the “Linux OS Requirements” section of the Sun Storage Common Array Manager Installation and Setup Guide.
Red Hat Enterprise Linux 6.0, 5.6, and 5.5
Before installing CAM on Red Hat Enterprise Linux 6.0 hosts, you must install the packages listed in the “Linux OS Requirements” section of the Sun Storage Common Array Manager Installation and Setup Guide.
SUSE Linux Enterprise Server 11.1 SP1 and 10.4 SP3
Oracle VM
Oracle VM 2.2.2
Management host (out-of-band) support only
Windows Server 2008 R2 SP2
Windows 2003 R2 SP2
Supports both 32-bit and 64-bit
Windows XP Pro SP3
Windows 7
