Go to main content
Sun Storage 16 Gb Fibre Channel ExpressModule Host Bus Adapter, Emulex Installation Guide For HBA Model 7101690
Exit Print View
Updated: August 2018
Link Aggregation Control Protocol (LACP) Cannot Be Used In Certain Conditions
Bug 18707752
Conditions:
  • System Platform: All supported systems using the Oracle Solaris driver
  • Operating Protocol Mode of HBA: FC, CNA
  • Environment: HBA connected directly to supported storage
Issue:
LACP cannot be used on the same port as FCoE or iSCSI.
Workaround:
None.
