In an Oracle Solaris OS environment, diagnostic support for the HBA is included in the Oracle VTS software. Oracle VTS software is available for download at: https://support.oracle.com/
For information about the Oracle VTS software, see the Oracle VTS documentation at: http://docs.oracle.com/cd/E19719-01/index.html
For information about diagnostic options using the OneCommand Manager utilities, see Diagnostic Support for All Other Supported Operating Systems.
The emlxtest utility, which is part of the Oracle VTS software, supports the following functions:
Connectivity verification
Firmware version and checksum test
Self-test
Loopback tests
External (all HBAs (in FC mode only) present in the system)
Internal, single-bit
Internal, 10-bit
Mailbox
