Before using the universal HBA, check for the latest drivers at the Oracle support area of the QLogic web site. The drivers and utilities, as well as ReadMe guides, are located at: http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
For diagnostic support, you might need to rebuild the Linux driver. Before rebuilding the drivers for Linux, you must have the required Linux OS installed on the hard disk. The driver and utilities are available for download at the Oracle support area of the QLogic web site.
If the universal HBA is running in CNA/FCoE mode, you might need to update both the FC/FCoE driver and the network driver that are available in this section.
