The JD Edwards EnterpriseOne IBM WebSphere Portal Reference Guide covers the IBM WebSphere Portal technology.
The JD Edwards EnterpriseOne IBM WebSphere Portal Reference Guide is meant to be used to supplement the use of the IBM WebSphere Portal with Oracle JD Edwards portlets and WSRP technology. This guide is not meant to be read front to back. Instead, the user should skip to the necessary parts and use them with other guides that more fully detail the various install processes. The necessary supplementary guides include:
JD Edwards EnterpriseOne Server Manager Guide
JD Edwards EnterpriseOne Tools IBM WebSphere Portal for IBM i for Power Systems Guide
JD Edwards EnterpriseOne Tools IBM WebSphere Portal for Unix Guide
JD Edwards EnterpriseOne Tools IBM WebSphere Portal for Windows Guide
Customers must conform to the supported platforms for the release as detailed in the Certifications for JD Edwards EnterpriseOne. In addition, JD Edwards EnterpriseOne may integrate, interface, or work in conjunction with other Oracle products. Refer to the following link for cross-reference material in the Program Documentation for Program prerequisites and version cross-reference documents to assure compatibility of various Oracle products:
http://www.oracle.com/corporate/contracts/index.html
Access the Certifications from My Oracle Support (https://support.oracle.com) by searching for this product from the Certification tab:
JD Edwards EnterpriseOne Portal
EnterpriseOne Tools Release 9.1 supports these Portal Servers:
Oracle WebCenter
IBM WebSphere Portal 7.0
On each portal, EnterpriseOne tools release 9.1 supports the WSRP solution.
This guide has the following parts.
Part 1 covers the EnterpriseOne portal solutions for WebSphere Portal.
Part 2 covers installing the collaborative portal.
Depending on the combination of JD Edwards EnterpriseOne Applications and Tools Release levels, the availability of the different portal solutions can be referred to in the Product Certifications.
