This chapter discusses understanding RSS portlets. This section of the guide should be used in conjunction with the JD Edwards EnterpriseOne Requisition Self-Service Implementation Guide
If your organization has an employee portal, you can create links to programs that your employees might frequently use, such as Shopping Cart (P43E25) and Desktop Receiving (P43E20) on the portal.
See "Entering a Requisition Using the Shopping Cart Program" in the JD Edwards EnterpriseOne Applications Requisition Self-Service Implementation Guide.
See "Understanding the Desktop Receiving Program" in the JD Edwards EnterpriseOne Applications Requisition Self-Service Implementation Guide.
You can also set up the JD Edwards EnterpriseOne Requisition Self Service portlet (P43E83) for buyers within your organization and attach it to the portal. The Requisition Self Service portlet contains alerts, such as:
Open approvals.
See Understanding the Requisition Entry Program in the JD Edwards EnterpriseOne Applications Requisition Self-Service Implementation Guide.
Requisition lines marked as high priority.
See "Understanding the Requisition Entry Program" in the JD Edwards EnterpriseOne Applications Requisition Self-Service Implementation Guide.
Requisition lines marked as special requests.
See "Requisition lines marked as special request" in the JD Edwards EnterpriseOne Applications Requisition Self-Service Implementation Guide.
Requisition lines that have been open for more than 10 days.
See "Requisition lines that have been open for more than 10 days" in the JD Edwards EnterpriseOne Applications Requisition Self-Service Implementation Guide.
Below is an example of the Requisition Self Service portlet:
If you want to modify the JD Edwards EnterpriseOne Requisition Self Service portlet, you must use Form Design Aid to make any modifications. The JD Edwards EnterpriseOne Requisition Self Service portlet conforms to the JSR 168 specification.
