Java methods to ”get” and ”set” the elements of a value object or other source file.
EnterpriseOne business logic written in Java. A business service is a collection of one or more artifacts. Unless specified otherwise, a business service implies both a published business service and business service.
Parts of the business service foundation that are specifically for supporting business service development.
Key value data pairs used to control the behavior or functionality of business services.
Business Service Property Admin Tool
An EnterpriseOne application for developers and administrators to manage business service property records.
business service property business service group
A classification for business service property at the business service level. This is generally a business service name. A business service level contains one or more business service property groups. Each business service property group may contain zero or more business service property records.
A unique name that identifies the business service property globally in the system.
business service property utilities
A utility API used in business service development to access EnterpriseOne business service property data.
The physical machine where the business services are located. Business services are run on an application server instance.
business services source file or business service class
One type of business service artifact. A text file with the .java file type written to be compiled by a Java compiler.
business service value object template
The structural representation of a business service value object used in a C-business function.
Business Service Value Object Template Utility
A utility used to create a business service value object template from a business service value object.
exposed method or value object
Published business service source files or parts of published business service source files that are part of the published interface. These are part of the contract with the customer.
internal method or value object
Business service source files or parts of business service source files that are not part of the published interface. These could be private or protected methods. These could be value objects not used in published methods.
An artifact that JDeveloper uses to organize project files. It contains one or more project files.
EnterpriseOne service level logic and interface. A classification of a published business service indicating the intention to be exposed to external (non-EnterpriseOne) systems.
