An actor that determines if and why an EnterpriseOne business service needs to be developed.
An application that, during the Installation Workbench processing, runs the batch applications for the planned merges that update the data dictionary, user-defined codes, menus, and user override tables.
A transaction method in which a client application communicates interactively and directly with a server application.
See also batch-of-one and store-and-forward.
The JDBC class that manages multiple registered JDBC drivers and dispatches connection initialization requests to them. The Java driver manager class is java.sql.DriverManager.
A JD Edwards EnterpriseOne proprietary database middleware package that provides platform-independent APIs, along with client-to-server access.
An application that, during the Installation Workbench process, copies all locations that are defined in the installation plan from the Location Master table in the Planner data source to the system data source.
A message triggered from EnterpriseOne application logic that is intended for external systems to consume.
