7 Understanding jdeinterop.ini for COM Connector
This chapter contains the following topic:
7.1 Settings for jdeinterop.ini File for the COM Connector
The jdeinterop.ini file includes settings the server might need. The default location for the file is c:\; however, you can configure this location. Information is organized by section, for example [JDENET].
These sections are configured for the COM connector:
  • OCM
  • JDENET
  • Server
  • Security
  • Debug
  • Interop
  • Events
7.1.1 [OCM]
Configure these [OCM] settings for the COM connector:
Setting and Typical Value Purpose
DSN=ODA ITTND17 The data source name from the system DSN of the ODBC setting.
OCM Datasource=COM OCM System data source for JD Edwards EnterpriseOne client.
DB User=jde User for the data source connection.
DB Pwd=jde Password for the data source connection.
Object Owner=sysb9 For UNIX platforms, this is the object owner in the [DB SYSTEM SETTINGS].
Seperator=. Separator used in SQL query.
For Oracle, SQL, and UDB databases, the separator is period (.); for IBM i, the separator is a slash (/).
7.1.2 [JDENET]
Configure these [JDENET] settings for the COM connector:
enterpriseServerTimeout=90000 Timeout value for a request to the JD Edwards EnterpriseOne enterprise server.
maxPoolSize=30 JDENET socket connection pool size.
7.1.3 [SERVER]
Configure these [SERVER] settings for the COM connector:
glossaryTextServer=JDED:6010 The JD Edwards EnterpriseOne enterprise server and port that provide glossary text information.
codePage=1252 The encoding scheme, such as:
1252 English and Western European.
932 Japanese.
950 Traditional Chinese.
936 Simplified Chinese.
949 Korean.
7.1.4 [SECURITY]
Configure this [SECURITY] setting for the COM connector.
NumServers=1 Number of security servers set.
7.1.5 [DEBUG]
Configure these [DEBUG] settings for the COM connector:
JobFile=c:\Interop.log Location of error file.
DebugFile=c:\InteropDebug.log Location of debug file.
log=c:\net.log Location of log file.
debugLevel=0 - 12 Defines the level of tracing provided by the COM connector and the CallObject component in the specified log file, in the COM server only.
0 None: Logging is turned off and only errors are written to the JobFile.
2 Errors (error messages).
4 System Errors (exception messages).
6 Warning Information.
8 Min Trace (Key operations; for example, Login, Logoff, Business Function calls).
10 Trouble Shooting Information (Help).
12 Complete Debug Information (Logs everything).
Note: The odd values are reserved for future levels to be added.
You typically do not need to use tracing. However, tracing is useful for debugging.
netTraceLevel=0 Defines the level of tracing provided by the ThinNet component in the specified log file, in the COM server only.
0 No trace.
1 Record process ID, thread ID, and the available socket status when a new connection is added and the socket pool is searched.
2 Includes the information in trace level 1 and also traces every call made in the Connection Manager class.
3 Includes all information in trace level 2, and also traces getPort calls and getHost calls.
Note: You typically do not need to use tracing. However, tracing is useful for debugging.
7.1.6 [INTEROP]
Configure these [INTEROP] settings for the COM connector:
SettingTime=60000 Enables the connector to access and retrieve event information from the F90703 and F90704 tables. Defines the time for the connector applications to start up before the connector starts recovering an event.
This value is milliseconds.
RecoveryInterval=10000 Enables the connector to access and retrieve event information from the F90703 and F90704 tables. Defines the time for the connector applications to start up before the connector starts recovering an event.
enterpriseServer=JDED The JD Edwards EnterpriseOne server.
port=6010 The port number of the JD Edwards EnterpriseOne server.
manual_timout=300000 The time-out value for a transaction in manual commit mode.
Repository=c:\JDEdwards\ Interop\repository Points to the location of the repository directory containing business object libraries (generated JAR files).
7.1.7 [EVENTS]
Configure these [EVENTS] settings for the COM connector:
UseGuaranteedEvents System= True Indicates guaranteed event delivery. Values are true and false. Must be set to True to use guaranteed event delivery.
Transport=HTTP Defines the event transport mechanism. Valid values are HTTP and JMS. The default value is HTTP.
eventServiceURL=http://<HOST>:<PORT>/
e1events/EventClientService
For a clustered transaction server:
eventServiceURL=http://<HOST1>:<PORT1>/
e1events/EventClientService|http://<HOST2>:
<PORT2>/e1events/ EventClientService
If there are more servers in a cluster, then the eventServiceURL can be appended with | as a delimiter; for example:
http://<HOST1>:<PORT1>/e1events/
EventClientService|http://<HOST2>:<PORT2>/
e1events/ EventClientService|http://<HOST3>:
<PORT3>/e1events/ EventClientService
Locates the event service. If the value for the Transport= setting is HTTP, then this setting must be configured.
For WebLogic, these ports are the Listen Port.
For WebSphere, these ports are the default http ports found under Server > Communication > Ports > WC_defaulthost.
jndiProviderURL=
For WebLogic:
jndiProviderURL=t3//<HOST>:<PORT>
t3://<HOST1>:<PORT1>;<HOST2>:<port3>
If there are more servers in a cluster, then the jndiProviderURL can be appended with ; as a delimiter; for example:
t3://<HOST1>:<PORT1>;<HOST2>:<PORT2>;
<HOST3>;<PORT3>
For WebSphere:
jndiProviderURL=corbaloc::<HOST>:<PORT>/
NameServiceServerRoot
corbaloc::<HOST1>:<PORT1>,:
<HOST2>:<PORT2>/NameServiceServerRoot
If there are more servers in a cluster, then the jndiProviderURL can be appended with ,; as a delimiter; for example:
corbaloc:://<HOST1>:<PORT1>;<HOST2>:<PORT2>;
<HOST3>;<PORT3>
Locates the event service. If the value for the Transport= setting is JMS, then this setting must be configured.
for WebSphere, these ports are the Bootstrap ports.
eventReceiveTimeout=60000 Maximum number of milliseconds that the event receiver waits before unsubscribing the event from the JD Edwards EnterpriseOne server.
initialContextFactory=
For WebLogic:
initialContextFactory=weblogic.jndi.WLInitialContextFactory
For WebSphere:
initialContextFactory=com.ibm.websphere.naming.WsnInitialContextFactory
Initial Context Factory
port=6002 The socket port number where the EventListener receives the events from the JD Edwards EnterpriseOne server. This port should not be used by any other resource. Also, the port should not be changed dynamically when the connector is running, as this causes subsequent subscriptions to be lost.
ListenerMaxConnection=10 The maximum number of connections allowed by the EventListener. The default number of connections is 10, but you can change this number. The maximum number of connections allowed is 64.
ListenerMaxQueueEntry=10 The maximum number of events that the EventListener can hold before processing by the EventManager. The default number of events for the queue is 10, but you can change this number. The maximum number of events that can be held in the queue is 100.
Outbound_timeout=1200000 Maximum number of milliseconds that the EventManager waits before unsubscribing the transient event from the JD Edwards EnterpriseOne server.
7.1.8 [JMSEVENTS]
This section has a single setting, CLASSPATH. Note that you must include the full directory path of each file, separating each file by a semicolon. For example, CLASSPATH=connector.jar;EventProcessor_JAR.jar;System_JAR.jar.
JD Edwards EnterpriseOne Tools Release 9.1 Update 4 and later releases require a different set of jar files.
For Tools Releases prior to JD Edwards EnterpriseOne Tools Release 9.1 Update 4, copy these files from the JD Edwards EnterpriseOne server to a directory on the machine that you want to use. Unless otherwise noted, the following files can be found in the <JD Edwards EnterpriseOne Windows client installation directory>\system\classes folder:
  • ApplicationAPIs_JAR.jar
  • ApplicationLogic_JAR.jar
  • Base_JAR.jar
  • BizLogicContainer_JAR.jar
  • BizLogicContainerClient_JAR.jar
  • BusinessLogicServices_JAR.jar
  • castor.jar
  • commons-httpclient-3.0.jar
  • commons-logging.jar
  • Connector.jar
  • EventProcessor_JAR.jar
  • Generator.jar
  • j2ee1_3.jar
  • JdbjBase_JAR.jar
  • JdbjInterfaces_JAR.jar
  • JdeNet_JAR.jar
  • jmxremote.jar
  • jmxremote_optional.jar
  • jmxri.jar
  • ManagementAgent_JAR.jar
  • Metadata.jar
  • MetadataInterface.jar
  • PMApi_JAR.jar
  • Spec_JAR.jar
  • System_JAR.jar
  • SystemInterfaces_JAR.jar
  • xalan.jar
  • xerces.jar
  • xmlparserv2.jar
The path to the directory where the jdeinterop.ini, jdbj.ini, and jdelog.properties files exist, which must all be in one directory.
The full path to the JDBC driver files, including the filenames.
The CLASSPATH entry must end with a slash (\), which indicates it is a directory name and not a file name.
If you are using JD Edwards EnterpriseOne Tools Release 9.1 Update 4 or a later release, copy the following files from the <JD Edwards EnterpriseOne Windows client installation directory>\system\class folder:
  • Base_JAR.jar
  • castor.jar
  • commons-codec.jar
  • commons-lang2.6.jar
  • Connector.jar
  • Generator_JAR.jar
  • httpclient.jar
  • httpcore.jar
  • httpmime.jar
  • j2ee1_3.jar
  • JdbjBase_JAR.jar
  • JdeNet_JAR.jar
  • jmxremote.jar
  • jmxri.jar
  • Metadata.jar
  • PMApi_JAR.jar
  • Spec_JAR.jar
  • System_JAR.jar
  • xerces.jar
  • xml-apis.jar
  • xmlparserv2.jar
For all releases, the files on the client side and Transaction server side must always match. This is important if the Transaction server is updated.
7.1.8.1 WebSphere
Normally IBM WebSphere MQ is included as part of other WebSphere applications, including the WebSphere Application Client. If you use WebSphere for the Java connection, you must include these additional files.
  • com.ibm.mqjms.jar
    Normally located in the <IBM WebSphere MQ installation directory>/Java/lib folder.
  • com.ibm.mq.jar
  • com.ibm.ws.ejb.thinclient_7.0.0.jar
    Normally located in the <WebSphere installation directory>\runtime fold.
  • com.ibm.ws.sib.client.thin.jms_7.0.0.jar
    Normally located in the <WebSphere installation directory>\runtime folder.
  • com.ibm.ws.orb_7.0.0.jar
The files on the client side and Transaction server side must always match. This is important if the Transaction server is updated.
7.1.8.2 Oracle WebLogic Application Server
If you use WebLogic Application Server for the Java connection, you must include additional files. These files are normally located in the Oracle installation directories in the weblogic.jar folder.
