This chapter contains the following topics:
Section 8.2, "Inserting Parameters for Error Messages in lpDS"
Section 8.4, "Using Text Substitution to Display Specific Error Messages"
Section 8.5, "Mapping Data Structure Errors with jdeCallObject"
Messages provide an effective and usable method of communicating information to end-users. You can use simple messages or text substitution messages.
Text substitution messages provide specific information to the user. At runtime, the system replaces variables in the message with substitution values. Two types of text substitution messages exist:
Error messages (glossary group E)
Workflow messages (glossary group Y)
The return code from all JDB and JDE Cache APIs must be checked and an appropriate error message set, returned, or both to the calling function. The standard error messages for JDB and JDE Cache errors are shown in these tables.
The JDB errors are:
Error ID | Description |
078D | Open Table Failed |
078E | Close Table Failed |
078F | Insert to Table Failed |
078G | Delete from Table Failed |
078H | Update to Table Failed |
078I | Fetch from Table Failed |
078J | Select from Table Failed |
078K | Set Sequence of Table Failed |
078S * | Initialization of Behavior Failed |
* 078S does not use text substitution
The JDE Cache errors are:
078L | Initialization of Cache Failed |
078M | Open Cursor Failed |
078N | Fetch from Cache Failed |
078O | Add to Cache Failed |
078P | Update to Cache Failed |
078Q | Delete from Cache Failed |
078R | Terminate of Cache Failed |
Include the parameters cSuppressErrorMessage and szErrorMessageID in lpDS for error message processing. The functionality for each is as follows:
cSuppressErrorMessage (SUPPS)
Valid data is either 1 or 0. This parameter is required if jdeErrorSet(...) is used in the business function. When cSuppressErrorMessage is set to 1, do not set an error because jdeErrorSet will automatically display an error message.
szErrorMessageID (DTAI)
This 4–character string contains the error message ID value that is passed back by the business function. If an error occurs in the business function, szErrorMessageID contains that error number ID.
This example includes the lpDS parameters, cSuppressErrorMessage, and szErrorMessageID:
if ((!IsStringBlank(lpDS->szErrorMessageID)) && (lpDS->cSuppressErrorMessage != _J('1'))) { jdeStrcpy ((JCHAR*) (lpDS->szErrorMessageID), (const JCHAR*) (_J("0653"))); jdeErrorSet (lpBhvrCom, lpVoid, (ID) IDERRcMethodofComputation_1, lpDS->szErrorMessageID, (LPVOID) NULL); idReturnValue = ER_ERROR; } /*********************************************************** * Function Clean Up ***********************************************************/ return idReturnValue;
Business functions that use the JD Edwards EnterpriseOne database API are required to call the Initialize Behavior function before calling any of the database functions. Set error 078S if the Initialize Behavior function does not complete successfully.
This example illustrates an initialize behavior error:
/*********************************************************************** * Initialize Behavior ***********************************************************************/ idJDBReturn = JDB_InitBhvr(lpBhvrCom, &hUser, (JCHAR *) NULL, JDEDB_COMMIT_AUTO); if (idJDBReturn != JDEDB_PASSED) { jdeStrcpy (lpDS->szErrorMessageID, _J("078S")); if (lpDS->cSuppressErrorMessage != _J('1')) { jdeErrorSet(lpBhvrCom, lpVoid, (ID)0, _J(078S), (LPVOID) NULL); } return ER_ERROR; }
You can use the JD Edwards EnterpriseOne text substitution APIs for returning error messages within a business function. Text substitution is a flexible method for displaying a specific error message.
Text substitution is accomplished through the data dictionary. To use text substitution, you first must set up a data dictionary item that defines text substitution for the specific error message. A selection of error messages for JDB and JDE Cache have already been created and are listed in this chapter.
Error messages for cache and tables are critical in a configurable network computing (CNC) architecture. C programmers must set the appropriate error message when working with tables or cache APIs.
JDB API errors should substitute the name of the file against which the API failed. JDE cache API errors should substitute the name of the cache for which the API failed.
When calling errors that use text substitution, you must:
Load a data structure with the information you want to substitute in the error message.
Call jdeErrorSet to set the error.
This example uses text substitution in JDB_OpenTable:
/************************************************************** * Open the General Ledger Table F0911 *************************************************************/ eJDBReturn = JDB_OpenTable( hUser, ID_F0911, ID_F0911_DOC_TYPE__NUMBER___B, idColF0911, nNumColsF0911, (JCHAR *)NULL, &hRequestF0911); if (eJDBReturn != JDEDB_PASSED) { memset((void *)(&dsDE0022), 0x00, sizeof(dsDE0022)); jdeStrncpy((JCHAR *)dsDE0022.szDescription, (const JCHAR *)(_J("F0911")), DIM(dsDE0022.szDescription)-1); jdeErrorSet (lpBhvrCom, lpVoid,(ID)0, _J("078D"), &dsDE0022); }
Any Business Function calling an external Business Function must use jdeCallObject. When using jdeCallObject, be sure to match the Error IDs correctly.
You need to match the Ids from the original Business Function with the Error Ids of the Business Function in jdeCallObject. A data structure is used in the jdeCallObject to accomplish this task.
/************************************************************* * Variable declarations *************************************************************/ CALLMAP cm_D0000026[2] = {{IDERRmnDisplayExchgRate_62, IDERRmnExchangeRate_2}}; ID idReturnCode = ER_SUCCESS; /* Return Code */ /************************************************************ * Business Function structures *********************************************************/ DSD0000026 dsD0000026 = {0}; /* Edit Tolerance */ idReturnCode = jdeCallObject(_J("EditExchanbeRateTolerance"), NULL, lpBhvrCom, lpVoid, (void *)&dsD0000026, (CALLMAP *)&cm_D0000026, ND0000026, (JCHAR *)NULL, (JCHAR *)NULL, (int)0);
