This chapter contains the following topics:
Source and header file names can be a maximum of 8 characters and should be formatted as bxxyyyy, where:
b = BSFN object
xx (second two digits) = The system code, such as:
01 = Address Book
04 = Accounts Payable
yyyyy (the last five digits) = A sequential number for the system code, such as:
00001 = The first source or header file for the system code
00002 = The second source or header file for the system code
Both the C source and the accompanying header file should have the same name.
This table shows examples of this naming convention:
System | System Code | Source Number | Source File | Header File |
Address Book | 01 | 10 | b0100010.c | b0100010.h |
Accounts Receivable | 04 | 58 | b0400058.c | b0400058.h |
General Ledger | 09 | 2457 | b0902457.c | b0902457.h |
An internal function can be a maximum of 42 characters and should be formatted as Ixxxxxx_a, where:
I = An internal function
xxxxxx = The source file name
a = The function description
Function descriptions can be up to 32 characters in length, and must not contain spaces. Be as descriptive as possible and capitalize the first letter of each word, such as ValidateTransactionCurrencyCode. When possible use the major table name or purpose of the function.
An example of a Function Name is I4100040_CompareDate
Do not use an underscore after I.Variables are storage places in a program and can contain numbers and strings. Variables are stored in the computer's memory. Variables are used with keywords and functions, such as char and MATH_NUMERIC, and must be declared at the beginning of the program.
A variable name can be up to 32 characters in length. Be as descriptive as possible and capitalize the first letter of each word.
You must use Hungarian prefix notation for all variable names, as shown in this table:
Prefix | Description |
c | JCHAR |
sz | NULL-terminated JCHAR string |
z | ZCHAR |
zz | NULL-terminated ZCHAR string |
n | short |
l | long |
b | Boolean |
mn | MATH_NUMERIC |
jd | JDEDATE |
lp | long pointer |
i | integer |
by | byte |
ul | unsigned long (identifier) |
us | unsigned Short |
ds | data structures |
h | handle |
e | enumerated types |
id | id long integer, JDE data type for returns |
ut | JDEUTIME |
sz | VARCHAR |
These variable names use Hungarian notation:
Variable | Description |
JCHAR | cPaymentRecieved; |
JCHAR [ ] | szCompanyNumber = _J(00000); |
short | nLoopCounter; |
long int | lTaxConstant; |
BOOL | bIsDateValid; |
MATH_NUMERIC | mnAddressNumber; |
JDEDATE | jdGLDate; |
LPMATH_NUMERIC | lpAddressNumber; |
int | iCounter; |
byte | byOffsetValue; |
unsigned long | ulFunctionStatus; |
D0500575A | dsInputParameters; |
JDEDB_RESULT | idJDEDBResult; |
The data structure for business function event rules and business functions should be formatted as DxxyyyyA, where:
D = Data structure
01 = Address Book
02 = Accounts Payable
yyyy = A next number (the numbering assignments follow current procedures in the respective application groups)
A = An alphabetical character (such as A, B, C and so on) placed at the end of the data structure name to indicate that a function has multiple data structures
Even if a function has only one data structure, you should include the A in the name.
An example of a Business Function Data Structure Name is D050575A.
