This chapter contains the following topics:
Oracle JD Edwards EnterpriseOne provides reports across many systems to meet your business needs, including:
JD Edwards EnterpriseOne Financial Management
JD Edwards EnterpriseOne Human Capital Management
JD Edwards EnterpriseOne Logistic
JD Edwards EnterpriseOne Manufacturing
JD Edwards EnterpriseOne reports can be processed and viewed in these formats:
Online in PDF
In hardcopy
Report can be sent to a printer.
In a spreadsheet program
Reports can be exported to a spreadsheet program.
To help you meet all of your business needs, you can create versions of these reports. Using the JD Edwards EnterpriseOne Batch Versions application on either the Microsoft Windows client (P98305) or the web client (P98305W), you can create versions to present specific information that is vital to your business.
You cannot process a report without a batch version. From the Microsoft Windows client, batch versions are submitted for processing and can be processed either locally or on the server. Typically, servers are faster, so processing on a server is more efficient. From the web client, batch versions are submitted on the server only. Once submitted, a batch version runs without user interaction. You do not interact with the report again until processing is complete.
Once you have submitted a batch version for processing, you have no control over the flow of the attached logic. You must make changes to the flow of logic in Oracle's JD Edwards EnterpriseOne Report Design Aid (RDA) and resubmit the batch version.
You run table conversions by submitting batch versions. Table conversions are a type of batch process that enables you to rapidly manipulate the data in tables. Like batch applications, table conversions include a template and associated versions. You can override some of the properties within a version at runtime.
This table describes the conversion types used by the Oracle's JD Edwards EnterpriseOne Table Conversion tool to manipulate data:
See "Table Conversions" in the JD Edwards EnterpriseOne Tools Table Conversion Guide.
Output management refers to the different output options that you have available for reports, such as:
You can output reports to different file types such as, PDF, OSA, and CSV.
Printers
You can output a report to multiple printers, locally or globally. You can send versions of a report to different printer drawers or to printers across the country.
Forms and paper sizes
You can output reports to forms and define custom paper sizes.
JD Edwards EnterpriseOne accommodates simple output processes such as viewing a report online or sending it to a network printer.
SeeJD Edwards EnterpriseOne Tools Report Printing Administration Technologies Guide.
A report exists as a set of specifications that are read by the JD Edwards EnterpriseOne batch engine for processing. You can create variations of a report template using batch versions. The first step in creating a report is to create a report object within JD Edwards EnterpriseOne. This report is actually a template from which multiple versions can be created.
See JD Edwards EnterpriseOne Tools Report Design Aid Guide.
Report templates are the master specifications created in RDA. These specifications describe the report to the batch engine and define how the data is selected, sorted, displayed, and formatted.
RDA includes a Report Director that you can use to guide you through the report development process. You begin the report development process by selecting:
Sections to include in the report.
An appropriate business view.
Fields for the section layout.
Records to be included in the report.
Batch versions read the master specifications from the report template. The sections and fields that you select in the report template appear in the associated batch versions. However, batch versions typically differ slightly from the report template. You can define different data selection, data sequencing, and processing options for each batch version.
There are also several report specifications that can be overwritten at the version level, including:
Layout
Data selection
Event rules
Database output
Data sequencing
Batch versions enable you to preserve template integrity while providing custom processing to meet a specific business need. Instead of creating a separate report template to provide multiple variations of a report, you can create one report template with multiple batch versions. For example, you might design a monthly variance report that contains totals for the entire company. If you need to run a quarterly variance report that includes only data for the Western region, you can create a version of the report template and define data selection to meet the requirement.
Batch versions process the specifications read from the report template and any changes that are overwritten in the version. Batch versions first read the master specifications from the report template, then override these specification with the version specifications. You can create additional batch versions by either adding a new version or copying an existing version.
In JD Edwards EnterpriseOne, the design for report templates and batch processes are stored in the report template specifications. Batch versions are variations on the report template. They use all of the same report definition information as the template but can also contain changes to the way the report is processed or displayed. Depending on how security is applied to the JD Edwards EnterpriseOne applications, end users can select different batch versions or create new batch versions based on business requirements.
Versions are a powerful and convenient way to modify the behavior of reports. Typically, administrators control the creation, modification, and location of the initial batch version files. When you upgrade JD Edwards EnterpriseOne or a specific application to a new release level, you can apply the existing batch versions without additional modification.
When you process a batch application (that is, when you submit a batch job) you must use a batch version. Depending on how the report was designed, when you submit the batch version you might have the option to override:
Processing option values
Data sequencing
Data selection
Default locations
For example, you have a report that prints financial information that is required by two different audiences: an American subsidiary and a French subsidiary. For the American subsidiary, you can create a batch version that displays financial information in U.S. dollars for a specific time period and formats the report for American-sized paper. For the French subsidiary, you can create a version that displays financial information in euros for a different time period and formats the report for European-sized paper. You can also display additional information in the report by inserting additional fields into the batch version.
This table defines the characteristics of batch versions:
You can create new batch versions of a report on the web client. You can use the Add and Copy options on the Work With Batch Versions - Available Versions form to create a batch version. To change the data selection, data sequencing, or processing options of a version, select Data Selection, Data Sequencing, or Processing Options from the Row menu.
You cannot create a new version, or copy an existing version, of a table conversion on the web client.
To provide consistency for developers and users, all JD Edwards EnterpriseOne objects follow standard naming conventions. The naming conventions require that each object, such as a table, report, interactive application, or menu, has a unique name. The naming conventions help you identify object types and help prevent users from creating objects with duplicate names.
