This chapter contains the following topics:
Section 1.1, "JD Edwards EnterpriseOne Table Conversion Overview"
Section 1.2, "JD Edwards EnterpriseOne Table Conversion Implementation Steps"
Oracle's JD Edwards EnterpriseOne Table Conversion is used to convert tables and copy data between tables.
In the planning phase of the implementation, take advantage of all JD Edwards EnterpriseOne sources of information, including the installation guides and troubleshooting information.
The following implementation steps need to be performed before working with JD Edwards EnterpriseOne Data Table Conversion:
Set up permissions to access and use JD Edwards EnterpriseOne Object Management Workbench (OMW) using JD Edwards EnterpriseOne Security Workbench.
See "Managing Application Security" in the JD Edwards EnterpriseOne Tools Security Administration Guide.
Add yourself to the system in a developer role so that you have permissions to create Oracle's JD Edwards EnterpriseOne objects.
See "Setting Up User Roles" in the JD Edwards EnterpriseOne Tools Object Management Workbench Guide.
Set up permissions to create OMW projects.
Set up the appropriate database permissions so that you can add tables to the database, drop tables, and add and modify data.
Work with the database administrator to set up these permissions.
