An optical machine-readable representation of data, which shows information about the object to which it is attached.
In JD Edwards EnterpriseOne, the way to process a report. Batch versions can be run locally on the Microsoft Windows client or submitted from any client to run on a server.
A specially formatted plain text file that stores spreadsheet or basic database-style information in a simple format, with one record on each line, and each field within that record separated by a comma.
An interoperability model that enables you to set up an interface for JD Edwards EnterpriseOne to pass data to another software package, such as Microsoft Excel, for processing.
Portable Document Format (PDF)
A worldwide standard for capturing and reviewing information from almost any application on any computer system and sharing it with virtually anyone, anywhere.
