9 Working with Attachments
This chapter contains the following topics:
9.1 Understanding Attachments
JD Edwards EnterpriseOne OMW enables you to add text, graphic, OLE, and file attachments to projects and to Object Librarian objects within projects. These attachments are available only through JD Edwards EnterpriseOne OMW; they neither affect the way in which the object functions nor are they available when a user employs the object. You use this feature to document the creation, purpose, and intended use of objects in the system.
9.2 Viewing Attachments
  • View attachments in the Design view.
  • View attachments in JD Edwards EnterpriseOne OMW.
9.2.1 Viewing Attachments in the Design View
Access JD Edwards EnterpriseOne OMW.
  1. In JD Edwards EnterpriseOne OMW, create an object or project, or select an existing object or project, and click the Design button in the center column.
  2. In the design form, click the Attachments.
9.2.2 Viewing Attachments in JD Edwards EnterpriseOne OMW
  1. In JD Edwards EnterpriseOne OMW, select a project.
  2. Click the News/Status.
  3. From the Row menu, select Attachments.
    If attachments exist, they appear in the information window.
