Skip Headers
JD Edwards EnterpriseOne Tools Product Packaging Guide
Release 9.1
Part Number E24257-01
Home
Book List
Index
Master Index
Contact Us
Next
PDF
Mobi
ePub
Contents
List of Figures
Title and Copyright Information
Preface
Audience
Documentation Accessibility
Related Documents
Conventions
1
Introduction to JD Edwards EnterpriseOne Product Packaging
1.1
JD Edwards EnterpriseOne Product Packaging Overview
1.2
JD Edwards EnterpriseOne Product Packaging Implementation
2
Understanding Product Packaging
2.1
Software Change Management
2.2
Distributed Development
2.3
Object Packaging
2.4
Software Mastering Tools
3
Working with Object Packaging
3.1
Using Object Packaging in JD Edwards EnterpriseOne Object Management Workbench
3.1.1
Understanding JD Edwards EnterpriseOne Object Management Workbench
3.1.2
Understanding Object Packaging
3.1.3
Saving an Object to a PAR File
3.1.4
Restoring an Object from a PAR File
3.2
Using Object Packaging in JD Edwards EnterpriseOne Configuration Assistant
3.2.1
Understanding JD Edwards EnterpriseOne Configuration Assistant
3.2.2
Including JD Edwards EnterpriseOne Objects in a Configuration
4
Working with Software Masters
4.1
Understanding Software Master Creation
4.2
Preparing for Software Master Creation
4.2.1
Setting Up the System TEMP Directory
4.2.2
Setting Up the UBEs
4.2.3
Creating Pristine Control Tables
4.2.4
Creating a Data Dictionary in the Pristine Data Source
4.2.5
Creating Change Tables
4.2.6
Verifying the Creation of Change Tables
4.3
Creating a Software Master
4.3.1
Understanding Software Master Definitions
4.3.1.1
Custom Data Inclusions in the Software Definition
4.3.1.2
Custom Table Inclusions
4.3.1.3
Custom Media Object Inclusions
4.3.1.4
Change Table Configuration
4.3.1.5
Final Master Creation
4.3.2
Prerequisite
4.3.3
Defining a Software Master
4.3.4
Configuring Change Tables
4.3.5
Setting the Package Build Application to the Mastering Mode
4.3.6
Validating a Software Master Definition
4.3.7
Creating a Final Software Master
4.3.8
Confirming the Software Master
4.3.9
Moving the Software Master to a CD ROM
4.3.10
Updating JD Edwards EnterpriseOne with the Software Master
4.4
Deleting a Software Master
4.4.1
Form Used to Delete Software Masters
4.5
Working with a Software Master Definition
4.5.1
Understanding Software Master Revisions
4.5.2
Understanding Software Master Validation
4.5.3
Forms Used to Revise Software Masters
4.5.4
Revising a Software Master Definition
4.5.4.1
CD Information
4.5.4.2
Build Steps
4.5.4.3
Directory Structure
4.5.4.4
Task List
4.5.5
Loading a Subdirectory from an Enterprise Network Directory
4.5.6
Copying a Software Master Definition
4.5.7
Proofing a Software Master Definition
4.6
Working with Software Master Templates
4.6.1
Understanding Software Master Templates
4.6.2
Understanding the All Build Step Processes
4.6.2.1
Undefined
4.6.2.2
Create CD File Structure
4.6.2.3
Package Build
4.6.2.4
Manual Build Step
4.6.2.5
Pre-Build Package
4.6.2.6
Pre-Build Pristine
4.6.2.7
Build Cross-Reference
4.6.2.8
Build Data Dictionary
4.6.2.9
Build In-House Package Database
4.6.2.10
Build Planner Database
4.6.2.11
Build Pristine Database
4.6.2.12
Build Store & Forward Database
4.6.2.13
Build Standalone Database
4.6.2.14
Build Change Tables
4.6.2.15
Master Central Objects
4.6.2.16
Compress
4.6.2.17
Create INF
4.6.2.18
Copy CD Directory Files
4.6.2.19
Virus Check
4.6.2.20
Windows Executable
4.6.2.21
Data Cleanup
4.6.2.22
Build Package Database
4.6.2.23
Batch Process
4.6.3
Understanding the ASU CD Template
4.7
Working with Custom CD Templates
4.7.1
Forms Used to Work with Software Master Templates
5
Working with Change Table Configurations
5.1
Understanding Change Table Revisions
5.2
5.2.1
Forms Used to Work with Change Tables
5.2.2
Setting Up Change Table Definitions
5.3
Working with Change Table Director
5.3.1
Forms Used to Work With Change Table Director
5.3.2
Adding a Change Table Definition
5.3.2.1
5.3.2.2
Target Release Selection
5.3.2.3
Source Environment Selection
5.3.2.4
Batch Application Selection
5.3.2.5
Additional Change Table Definitions
6
Working with the Data Cleanup Procedure Application
6.1
Understanding the Data Cleanup Procedure Application
6.2
6.2.1
Forms Used to Work with Data Cleanup Procedures
6.2.2
Using the Data Cleanup Procedure Application
6.3
Adding a Data Cleanup Procedure
6.3.1
Forms Used to Add a Data Cleanup Procedure
6.3.2
Adding Data Cleanup Procedures
6.3.2.1
Procedure Definition Director
6.3.2.2
Add Procedure
6.3.2.3
Procedure Revision Information
6.3.2.4
Procedure Revision Steps
6.4
Copying a Data Cleanup Procedure
6.4.1
Forms Used to Copy a Data Cleanup Procedure
6.4.2
6.5
Executing a Data Cleanup Procedure and Build Step
6.5.1
Forms Used to Execute a Data Cleanup Procedure and Build Step
6.5.2
7
Working with Advanced Operations
7.1
Working with CD Templates
7.1.1
Understanding CD Templates
7.1.2
Forms Used with Mastering Templates
7.1.3
Setting Up CD Templates
7.1.4
Adding a New CD Template
7.1.4.1
Template Director
7.1.4.2
Template Information
7.1.4.3
CD Revisions
7.1.5
Copying CD Configuration
7.2
Converting Relative and Absolute Paths
7.2.1
Understanding Path Tokens
7.2.2
Forms Used to Work With Relative and Absolute Paths
7.2.3
Using Relative Path Tokens
7.2.4
7.3
Working with Data Cleanup Procedure Templates
7.3.1
Forms Used with Data Cleanup Procedure Templates
7.3.2
Setting Up Data Cleanup Procedure Templates
7.3.3
7.3.3.1
7.3.3.2
Add Procedure
7.3.3.3
Procedure Revision
7.3.4
7.4
Viewing a Table Change Table
7.4.1
Forms Used to Work with Table Change Table
7.4.2
Viewing the Table Change Table
7.5
Viewing the Index Change Tables
7.5.1
Forms Used to Work with Index Change Table
7.5.2
7.6
Viewing the Control Change Tables
7.6.1
Forms Used with Software Update Control Tables
7.6.2
Viewing the Software Update Control Tables
8
Working with Translation Updates
8.1
Understanding Translation Updates
8.2
Creating Translation Update Templates
8.2.1
Understanding Translation Update Templates
8.2.2
Prerequisites
8.2.3
Setting Processing Options for the Translation Update Template (R95160)
8.2.3.1
Template Options
8.3
Collecting Translation Updates
8.3.1
Forms Used to Collect Translation Updates
8.3.2
Creating a Translation Updates Database
8.3.2.1
Work With Language Groups
8.3.2.2
Language Group Information
8.3.2.3
Work with OMW Project Detail
8.3.2.4
OMW Project Search & Select
8.3.2.5
Select Languages
8.4
Creating an Update Package
8.4.1
Understanding Package Updates
8.4.2
Prerequisites
8.4.3
Forms Used to Create an Update Package
8.4.4
8.4.4.1
Work With Software Mastering
8.4.4.2
CD Configuration Director
8.4.4.3
CD Revisions
A
Troubleshooting Product Packaging
A.1
Failure During the Check Mastering Items Step
A.1.1
Solution
A.2
Failure to Build the Feature INF File
A.2.1
Solution
A.3
Failure to Copy Change Tables
A.3.1
Solution
A.4
Failure to Copy Custom Tables
A.4.1
Solution
A.5
Unable to Find Product Package After Installation
A.5.1
Solution
A.6
Problems with Object Librarian Records
A.6.1
Solution
Glossary
Index
Scripting on this page enhances content navigation, but does not change the content in any way.
