Glossary
central objects merge
A process that blends a customer's modifications to the objects in a current release with objects in a new release.
checksum
A fixed-size datum computed from an arbitrary block of digital data for the purpose of detecting accidental errors that may have been introduced during its transmission or storage. JD Edwards EnterpriseOne uses the checksum to verify the integrity of packages that have been downloaded by recomputing the checksum of the downloaded package and comparing it with the checksum of the original package. The procedure that yields the checksum from the data is called a checksum function or checksum algorithm. JD Edwards EnterpriseOne uses the MD5 and STA-1 checksum algorithms.
Control Table Workbench
An application that, during the Installation Workbench processing, runs the batch applications for the planned merges that update the data dictionary, user-defined codes, menus, and user override tables.
control tables merge
A process that blends a customer's modifications to the control tables with the data that accompanies a new release.
edit rule
A method used for formatting and validating user entries against a predefined rule or set of rules.
Object Librarian Merge
A process that blends any modifications to the Object Librarian in a previous release into the Object Librarian in a new release.
Specification merge
A merge that comprises three merges: Object Librarian merge, Versions List merge, and Central Objects merge. The merges blend customer modifications with data that accompanies a new release.
Specification Table Merge Workbench
An application that, during the Installation Workbench process, runs the batch applications that update the specification tables.
Table Conversion Workbench
An interoperability model that enables the exchange of information between JD Edwards EnterpriseOne and third-party systems using non-JD Edwards EnterpriseOne tables.
User Overrides merge
Adds new user override records into a customer's user override table.
Versions List merge
The Versions List merge preserves any non-XJDE and non-ZJDE version specifications for objects that are valid in the new release, as well as their processing options data.
