Skip Headers
JD Edwards EnterpriseOne Tools Solution Explorer Guide
Release 9.1
Part Number E24261-01
Home
Book List
Index
Master Index
Contact Us
Next
PDF
Mobi
ePub
Contents
Title and Copyright Information
Preface
Audience
Documentation Accessibility
Related Documents
Conventions
1
Introduction to JD Edwards EnterpriseOne Solution Explorer
1.1
JD Edwards EnterpriseOne Solution Explorer Overview
1.2
JD Edwards EnterpriseOne Solution Explorer Implementation
1.2.1
JD Edwards EnterpriseOne Solution Explorer Implementation Steps
2
Using the Menu Design Mode
2.1
Understanding the Menu Design Mode
2.2
Understanding How to Set Up Task Views
2.3
Working with Task Views
2.3.1
Creating a New Task View
2.3.2
Changing a Task View
2.3.3
Deleting a Task View
2.4
Setting Up Tasks
2.4.1
Understanding Task Set Up
2.4.2
Finding JD Edwards EnterpriseOne Solution Explorer Task and Task Relationship Changes in Object Management Workbench
2.4.3
Creating a Task
2.4.4
Inserting an Existing Task
2.4.5
Applying Roles to a Task
2.4.6
Changing a Task
2.4.7
Deleting Tasks
2.4.7.1
Deleting an Instance of a Task
2.4.7.2
Deleting a Task from the Task Master Table (F9000)
2.4.8
Clearing Cache
3
Using the Menu Filtering Mode
3.1
Understanding Menu Filtering
3.1.1
Setting Up Menus with *ALL Role Filtering Considerations
3.1.1.1
Understanding how *ALL Role Filters Tasks
3.1.1.2
Deciding How Many Roles to Assign Users
3.1.2
Understanding Task View Roles
3.1.3
Filtering a Task View by Role
3.1.4
Changing a Role's View of a Task View
4
Using the Task Launching Mode
Index
Scripting on this page enhances content navigation, but does not change the content in any way.
