Skip Headers
JD Edwards EnterpriseOne Tools Translation Tools Guide
Release 9.1
Part Number E24263-01
Home
Book List
Index
Master Index
Contact Us
Next
PDF
Mobi
ePub
Contents
Title and Copyright Information
Preface
Audience
Documentation Accessibility
Related Documents
Conventions
1
Introduction to JD Edwards EnterpriseOne Translation Tools
1.1
JD Edwards Translation Tools Overview
1.2
JD Edwards Translation Tools Implementation
1.2.1
JD Edwards Translation Tools Implementation Steps
2
Understanding JD Edwards EnterpriseOne Software
2.1
Prerequisite
2.2
3
Using JD Edwards Translation Tools
3.1
Understanding JD Edwards Translation Tools
3.1.1
Consistency Features
3.1.2
Suggestions
3.1.3
Space Constraints
3.1.4
Translating Controls
3.1.5
Search and Replace
3.1.6
Spell Check
3.1.7
Default Codes
3.1.8
Translatable JD Edwards Items
3.2
Understanding the JD Edwards Translation Tools Interface
3.2.1
Information Common to All Tabs
3.2.1.1
View
3.2.1.2
Audit
3.2.1.3
Glossary
3.2.2
Source and Target Panes
3.3
Accessing JD Edwards Translation Tools
3.3.1
Understanding Translation Tool Navigation
3.3.2
3.4
Reviewing Audit Information for a Delta Process
3.5
Setting JD Edwards Translation Tools Options
3.5.1
Setting Display Options
3.5.2
Select the Move by Status Feature
3.5.3
Moving from Item to Item
3.5.3.1
Using the Move Previous or Move Next Options
3.5.3.2
Using the Previous and Next Options
3.5.4
Using Auto Hot Keys
3.6
Checking the Spelling of Translations
3.6.1
Prerequisite
3.6.2
Checking Spelling Manually
3.6.3
Checking Spelling Automatically
3.7
Changing Item Status
3.7.1
Understanding Item Status
3.7.2
Changing Item Status Manually
3.8
Entering Translations Manually
3.8.1
Understanding Manual Translation
3.8.2
3.9
Copying Translations
3.9.1
Understanding Translation Copying
3.9.2
Copying the Source Item
3.10
Using Suggestions
3.10.1
Understanding Suggestions
3.10.1.1
Searching for Suggestions Manually
3.10.1.2
Searching for Suggestions Automatically
3.10.1.3
Updating and Deleting Suggestions
3.10.2
3.10.3
3.10.4
Adding Translations as Suggestions
3.10.5
3.11
Using Source and Target Preview
3.12
Using Keyboard Shortcuts
3.13
Searching and Replacing Text
3.13.1
Understanding the Search and Replace Workspace
3.13.1.1
General Tab
3.13.1.2
Application Tab
3.13.1.3
Search Text Tab
3.13.1.4
Find and Replace Tab
3.13.2
Using Wildcard Characters
3.13.3
Defining General Search Criteria
3.13.4
Defining Search Text
3.13.5
Finding and Replacing Target Items
3.14
Approving Target Items
3.14.1
Prerequisite
3.14.2
3.15
Saving Translations
4
Translating Resource Text
4.1
Understanding Resource Files
4.2
Translating Service Pack Resources
4.2.1
Understanding Service Pack Resource Translation
4.2.2
4.3
4.3.1
Understanding Resource Text Translation
4.3.2
5
Translating the Data Dictionary
5.1
Understanding Data Dictionary Translation
5.1.1
Data Dictionary Items
5.1.2
The Data Dictionary Translation Process
5.1.3
Data Dictionary Items and the FDA Translation Tool
5.1.4
The *SAME Shortcut
5.1.5
Data Dictionary Translation Tools
5.1.6
Data Dictionary Item Navigation
5.1.7
Data Dictionary Space Constraints
5.2
Translating Alpha, Row, and Column Descriptions
5.2.1
Understanding Alpha, Row, and Column Descriptions
5.2.2
Editing Data Dictionary Alpha, Row, and Column Entries
5.3
Translating Glossary Entries
5.3.1
Understanding Glossary Translation
5.3.1.1
File Naming Conventions for Exported Glossaries
5.3.2
5.3.3
Filtering Glossaries
5.3.4
Exporting Glossaries
5.3.5
Translating Glossaries in a Translation Memory Tool
5.3.6
Importing Glossaries
5.3.7
Validating Glossaries
5.4
Copying Existing Items
6
Translating Processing Options
6.1
Understanding Processing Option Translation
6.1.1
The Processing Option Translation Process
6.1.2
The Processing Option Translation Tool Interface
6.1.2.1
Processing Option View Tab
6.1.2.2
Processing Option Audit
6.1.2.3
Processing Option Glossary
6.1.3
Processing Option Tool Features
6.1.3.1
Get Specs
6.1.3.2
Top
6.1.3.3
Data Dictionary Glossary Exit
6.2
Displaying Processing Option Items
6.3
6.3.1
Understanding Processing Option Space Constraints
6.3.2
Copying Description Data
6.4
7
Translating Forms
7.1
Understanding Form Translation
7.1.1
Form Translation
7.1.2
The Form Translation Process
7.1.3
Single Line Items
7.1.4
The Form Design Aid (FDA) Translation Tool
7.1.4.1
Form Design Aid View
7.1.4.2
Form Design Aid Audit
7.1.4.3
Form Design Aid Task
7.1.4.4
Form Design Aid Data Dictionary
7.1.4.5
Form Design Aid Glossary
7.1.4.6
Form Design Aid Processing Options
7.2
Translating Forms
7.2.1
Understanding Form Space Constraints
7.2.2
Translating Tabs, Controls, and Titles
7.2.3
Translating Menu Hyper Items
7.2.4
Translating Grid Items
7.3
Using Overrides
7.3.1
Using Overrides
7.3.2
Removing Overrides
8
Translating Reports
8.1
Understanding Report Translation
8.1.1
Report Translation
8.1.2
The Report Translation Process
8.1.3
Report Versions
8.1.4
The Report Design Aid (RDA) Translation Tool Interface
8.1.4.1
Report Design Aid View Tab
8.1.4.2
Report Design Aid Audit Tab
8.1.4.3
Report Design Aid Tasks Tab
8.1.4.4
Report Design Aid Data Dictionary Tab
8.1.4.5
Report Design Aid Glossary Tab
8.1.4.6
Report Design Aid Processing Options Tab
8.2
Translating Report Information
8.3
Using Overrides
8.3.1
Using Overrides
8.3.2
Removing Overrides
9
Translating Solution Explorer Tasks
9.1
Understanding Task Translation
9.1.1
Task Translation
9.1.2
The Solution Explorer Task Translation Process
9.1.3
The Solution Explorer Task Translation Tool
9.1.3.1
The Work With Task Translations Form
9.1.3.2
The Task Translation Form
9.2
Translating Menu or Task Items
10
Translating User Defined Codes
10.1
Understanding User Defined Code Translation
10.1.1
10.1.2
User Defined Code Translation Tools
10.1.2.1
Work With User Defined Code Type Language Translation Form and Work With User Defined Code Language Translation Form
10.1.2.2
User Defined Codes Translation Form
10.2
Accessing Items to Translate
10.3
Reviewing Glossary Information
10.4
Translating User Defined Code Items
10.4.1
Understanding Space Constraints
10.4.2
10.4.3
11
Translating Across Multiple Releases or Environments
11.1
Understanding Translation for Multiple Releases
11.2
Matching Criteria for Updates and Audits in the Multiple Release Exact Match Program (P7903)
11.2.1
Understanding Matching Criteria
11.2.2
12
Quick Reference for Product Codes
12.1
Understanding JD Edwards EnterpriseOne Product Codes
12.2
Product Codes
13
Quick Reference for Status Codes
13.1
Understanding Status Codes
13.2
Using Codes
13.2.1
Status Codes
13.2.2
Reason Codes
13.2.3
Skip Codes
14
Understanding Jargon and Overrides
14.1
Overrides and Jargon
15
Understanding the Data Dictionary
15.1
The Data Dictionary
15.2
Data Dictionary Jargon
15.2.1
Jargon Fundamentals
15.2.2
Alpha Jargon
15.2.3
Row and Column Jargon
15.3
FDA Overrides
15.3.1
English Overrides
15.3.2
Language Overrides
Index
Scripting on this page enhances content navigation, but does not change the content in any way.
