Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Oracle ILOM Firmware Updates
Network Access Configuration
The Principle of Least Privilege
System Activity Monitoring
Security Information Updates
Basic Security Principles
Access Principles
Authentication Principles - User Accounts and Passwords
Authorization Principles
Accounting Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
Oracle Integrated Lights Out Manager (Oracle ILOM) is a preinstalled service processor on the Oracle server that enables you to locally or remotely configure and manage server components using a dedicated network port, a sideband port, or a local port. This section provides general and basic security principles for you to consider when using Oracle ILOM:
Follow these general security principles to ensure secure use of Oracle ILOM in your environment:
On a regular basis, verify that the most recent version of Oracle ILOM firmware is installed on the system. If a later version of the firmware is available, update the system to this later version. For information about updating Oracle ILOM firmware, see Oracle ILOM 3.1 Configuration and Maintenance Guide.
Use a firewall to restrict network access in your environment and configure the firewall to allow only the ports required by Oracle ILOM. The ports required by Oracle ILOM are listed in Services Enabled by Default.
The principle of least privilege states that, for good security practice, give a user the least amount of privileges to perform his or her job. Over-ambitious granting of responsibilities, roles, grants, and so on (especially early in the life cycle of an organization), can leave a system open for abuse. Review user privileges periodically to determine relevance to current job responsibilities.
The best system security typically addresses these areas:
System monitoring, such as auditing and reviewing audit records, targets the third area of system security. Each component within a system has some degree of monitoring ability. For best security practice, follow the auditing recommendations in this documentation and regularly review Oracle ILOM audit logs.
Oracle continually improves its hardware, software, and documentation. Check Product Notes documentation frequently for the latest revisions to Oracle products and documentation.
Follow these basic security principles to ensure secure use of Oracle ILOM in your environment:
Access Principles
Enforce physical and virtual access limits to protect hardware and data from intrusion as follows:
Enforce user authentication in Oracle ILOM by creating a separate user account and assigning a complex password for each Oracle ILOM user. For example, when creating user accounts and passwords for Oracle ILOM users, consider these guidelines:
User Accounts Guidelines:
Passwords Guidelines for Local User Accounts:
For further information about how to create or modify user accounts in Oracle ILOM, see the Oracle ILOM Administrator Guide for Configuration and Maintenance.
Allow a company employee to work only with hardware and software that he or she is trained and qualified to use.
Oracle ILOM provides the ability to control user privileges for each user. Ensure that the appropriate permissions are assigned to each user, based on job role.
Use Oracle software and hardware features to monitor login activity and maintain hardware inventories.
